| | Header gaskets | |
| Subject: Header gaskets Sun Mar 17, 2013 10:55 pm | |
| Anyone ever find a secret sauce that can be applied to header gaskets to get that 100% garaunteed seal?
I know I probably over torqued the header (because I HATE exhaust leaks) causing leaks under #3 & 5 ....but I want QUIET this go round
What cha know? | |
| Subject: Re: Header gaskets Sun Mar 17, 2013 10:57 pm | |
| I use the Percy's aluminum ones. They are like 5 or 6 pieces of thin aluminum (like foil) that compress as you tighten em up. I've had very good luck with no leaks. | |
| | | Ironfistdog
| Subject: Re: Header gaskets Sun Mar 17, 2013 11:57 pm | |
| I got a set of those aluminum ones in my garage, they fought me for 40 minutes trying to install the headers on my c10, you want them you cN have them steve.
some one told me once to use that copper spray gasket on the gaskets but ive never done it, | |
| | | V8Killer
| Subject: Re: Header gaskets Mon Mar 18, 2013 3:32 pm | |
- Anyone ever find a secret sauce that can be applied to header gaskets to get that 100% garaunteed seal?
What cha know? When you find out let me know. Never had anything that was 100% positive. Make sure to check the the header flange with a staright-edge. They will NEVER seal if the flanges are bent. | |
| | | sdstick
| Subject: Re: Header gaskets Mon Mar 18, 2013 4:08 pm | |
| Based on my use of Earls pressuremaster & the SCE coppers, I have to assume operator error See....I figured tighten those mofos so they'll never leak (it being 1/4" thk material) Gotta assume based on the location of the bolts on the centerline & the leak UNDER 2 cylinders, I OVER torqued Wont make that mistake again. BTW these were Dans Stainless Tri Y's so......yah....I'll be checking surface flatness & RE-surfacing if required this time | |
| Subject: Re: Header gaskets Mon Mar 18, 2013 8:31 pm | |
| I've had good luck with the Mr Gasket Ultra Seal ones, too.
Stay away from the copper gaskets, I've never been able to get those to work!
And those Percy's ones I mentioned... I've reused them a couple times and they still didn't leak. | |
| | | 96slowss
| Subject: Re: Header gaskets Tue Mar 19, 2013 8:16 pm | |
| I have the percy's as well. same ones for over 2 years with my headers, never had a leak | |
| Subject: Re: Header gaskets | |
| | | | Header gaskets | |
