Musty smell from vents EmptyWed Oct 19, 2022 1:27 pm by scot
Musty smell from vents EmptyTue Oct 18, 2022 8:58 pm by silverfox103
Musty smell from vents EmptyTue Sep 28, 2021 11:01 pm by silverfox103
Musty smell from vents EmptyFri Sep 24, 2021 9:53 am by ElKy
Musty smell from vents EmptySun Sep 19, 2021 6:22 pm by black blur 96
Musty smell from vents EmptySun Jun 20, 2021 11:37 am by scot
Musty smell from vents EmptyFri Jun 11, 2021 10:41 am by scot
Musty smell from vents EmptyWed Jun 09, 2021 9:41 pm by Chris Klein
Musty smell from vents EmptyWed Jun 02, 2021 9:02 pm by Chris Klein
4 posters
chapel
chapel
PostSubject: Musty smell from vents   Musty smell from vents EmptyWed Aug 22, 2012 6:53 pm
My car is slowly starting to stink... I keep it clean, but it's getting worse... a very musty smell emanates from the vents
What could be causing this? I'd really like to de-stink the car
PostSubject: Re: Musty smell from vents   Musty smell from vents EmptyWed Aug 22, 2012 8:03 pm
Does it only stink when you're in the car? Could be nasty rodents and such got into your hvac. See if there's a difference in smell between outside air blowing vs cabin recirculation. Don't be fooled, these cars have no cabin filter. Make sure your cowl is clean too.
chapel
chapel
PostSubject: Re: Musty smell from vents   Musty smell from vents EmptyWed Aug 22, 2012 8:53 pm
Its like stagnant water.
PostSubject: Re: Musty smell from vents   Musty smell from vents EmptyWed Aug 22, 2012 8:58 pm
Is the passenger side floor wet by any chance? Do you have your ac running all the time? If so, take a look under the hood, passenger side of the firewall. There is a little rubber 90 degree elbow down near the heater hoses. If not, your drip tray could be leaking inside the car. If you need one I'll toss one in the mail for you. I've got like, a hundred.
chapel
chapel
PostSubject: Re: Musty smell from vents   Musty smell from vents EmptyWed Aug 22, 2012 9:02 pm
Yeah. It has been a little wet. I'll take a look. I've had the ac on constant
PostSubject: Re: Musty smell from vents   Musty smell from vents EmptyWed Aug 22, 2012 9:09 pm
If its not there, then definitely replace it. Check and if you need one, I will ship one out tm. Just pm me your info. I hope this helps out. I went through this when I first got my 9c1 in 2009. Water puddled on the pass side. I had the the interior out 6 times, drove from socal to mass, and got wicked pissed off before I figured it out. I didn't know a whole lot about these cars at the time. Let's at least eliminate this free quick fix from your list, or move on to the next cause.
chapel
chapel
PostSubject: Re: Musty smell from vents   Musty smell from vents EmptyWed Aug 22, 2012 9:24 pm
thanks, I'll check tomorrow when I'm home
PostSubject: Re: Musty smell from vents   Musty smell from vents EmptyWed Aug 22, 2012 9:49 pm
Sounds good
chapel
chapel
PostSubject: Re: Musty smell from vents   Musty smell from vents EmptySat Aug 25, 2012 2:19 pm
I see no hoses.
PostSubject: Re: Musty smell from vents   Musty smell from vents EmptySat Aug 25, 2012 2:26 pm
http://www.impalassforum.com/vBulletin/showthread.php?t=227722&highlight=drip+hose
chapel
chapel
PostSubject: Re: Musty smell from vents   Musty smell from vents EmptySat Aug 25, 2012 3:10 pm
Musty smell from vents 546001_10151022761141984_1814138136_n
PostSubject: Re: Musty smell from vents   Musty smell from vents EmptySat Aug 25, 2012 3:13 pm
Looks like you are missing it no?
chapel
chapel
PostSubject: Re: Musty smell from vents   Musty smell from vents EmptySat Aug 25, 2012 3:15 pm
I would say I'm missing it, yes. Very Happy
PostSubject: Re: Musty smell from vents   Musty smell from vents EmptySat Aug 25, 2012 3:21 pm
Pm me your info. I'll send you two just in case you ever need another.
chapel
chapel
PostSubject: Re: Musty smell from vents   Musty smell from vents EmptySat Aug 25, 2012 3:24 pm
emailed. thanks
PostSubject: Re: Musty smell from vents   Musty smell from vents EmptySat Aug 25, 2012 3:33 pm
Replied
PostSubject: Re: Musty smell from vents   Musty smell from vents EmptySat Aug 25, 2012 4:39 pm
FYI you can buy a 90 degree elbow at AZ (or where eva) for $2.49
Ya...
I made that price up but its cheap & available immediately
& you can actually accomplish it in 5 seconds
just feel the size of the outlet...
walk in....buy the right size...
go into the lot & push it on....
just sayin...
And just so you know, in case you didnt see it written in the ISSF post (that I didnt read), when your DRIVING is when the wind blows onto that outlet & forces the condensate in instead of letting it drip out.
» Musty interior
» smell oil and stalling
» Caprice Wagon gas smell
» Where'd the ball vents go?
» luke warm from vents all the time.................
