| 96 dggm impala ss 1800.00 | |
+4phantom 309 95brmw 8bud freeways 8 posters |
freeways
Posts : 49 Join date : 2012-08-07 Age : 59 Location : Brockton,Ma
| Subject: 96 dggm impala ss 1800.00 Sun Aug 12, 2012 8:31 am | |
| this one is rough.needs a tranny and lots more.i cant figure how to post pics here so e-mail me and ill get you some.call for honest description.508-587-1107 located in brockton,ma | |
| Subject: Re: 96 dggm impala ss 1800.00 Sun Aug 12, 2012 10:21 am | |
| Put the link to your craigslist ad. Car doesn't look too bad for the money. GLWS. | |
| Subject: Re: 96 dggm impala ss 1800.00 Sun Aug 12, 2012 10:52 am | |
| Found the ad. Really doesn't look bad for the money. GLWS http://boston.craigslist.org/sob/cto/3196550723.html | |
| Subject: Re: 96 dggm impala ss 1800.00 Sun Aug 12, 2012 12:30 pm | |
| - 95brmw wrote:
- Found the ad. Really doesn't look bad for the money. GLWS
http://boston.craigslist.org/sob/cto/3196550723.html seats and console shifter etc,. has me thinking itsa clone,. Nick | |
IMPALADAKID Admin
| Subject: Re: 96 dggm impala ss 1800.00 Sun Aug 12, 2012 1:06 pm | |
| Seats look like cadillac/buick late FWD versions? | |
freeways
| Subject: no clone Sun Aug 12, 2012 1:39 pm | |
| i had some doubts too as the trunk is not original but the door decal has the correct tire size,the console mounts are factory spot welded and then i ran the vin on the comp nine decoder and it is an ss.i put 2000 impala seats in as the original fronts are torn up[still have them]i needed the console for my 95 imp.i have since obtained a partial console and shifter from a 96. | |
| Subject: Re: 96 dggm impala ss 1800.00 Sun Aug 12, 2012 8:04 pm | |
| Those are wimpala seats? How hard were they to install? | |
| Subject: Re: 96 dggm impala ss 1800.00 Sun Aug 12, 2012 8:42 pm | |
| Those seats look awesome! Kind of have a little of the bolstering effect of the Bonneville seats, but seem wider? | |
freeways
| Subject: impala seats install Sun Aug 12, 2012 10:09 pm | |
| i wanted to try this for a while-leather power,heated seats 100.00 for the pair at the jy.the 96 tracks bolt right up-well almost.you have to install 3/8 inch spacer between the track and seat.also,because the 99-2005? seats sit lower,you have to trim 3/4 or more from the skirt.easily done.although these seats are power-heated,while at the jy i picked up a set of non power seat skirts-they pop off after removing front plastic clip,rear philips screw and the tilt mech.handle comes off after removing the u-clip[same clip used on the handle of roll-up windows]pull clip down.the non power skirts will need a hole for the lumbar knob on drivers side although i had not got to that yet.the color is exact and the pattern is close with the 96.i tried to find black but not an option except on fwd ss models and even then,i believe the pattern changed-but try to find ss seats from any year at the local jy for 100.00.i have some picts posted on another ss site.oh ya,the head rests are the open type-KIND OF LOOK SPORTY AND TAKE THE PLACE OF THE MISSING LOGO EMBOSSED HEADRESTS FROM 96-ps,i have a perfect set located at a brockton jy but they want 130.00.if anyone tries this swap,ditch the oem seat tracks[but save the wiring and relays for the heat option. | |
| Subject: Re: 96 dggm impala ss 1800.00 Mon Aug 13, 2012 3:53 pm | |
| Agh if only I had the room, I have a low mile trans for it and everything, plus it's the best color SS! | |
freeways
| Subject: dggm ss Mon Aug 13, 2012 9:16 pm | |
| i will let you keep it here and i will drive it for you! it needs a tranny because it went offroad and cracked the bellhousing. | |
| Subject: Re: 96 dggm impala ss 1800.00 Mon Aug 13, 2012 10:05 pm | |
| Maybe I missed it, but what all makes this " ss " a rough shape cheap sale? There's more to it here. You mentioned it went offroad??? | |
freeways
| Subject: rough shape Mon Aug 13, 2012 11:25 pm | |
| ive had it for 3 weeks.the shady dude i bought it from lied or at least hid the truth.it needed a flywheel and when i started to unbolt the tranny i saw the cracked housing and some under carriage scrapes so i put 2+2 and this is what musta happened.also engine has erratic idle,hood dented, rot in lower 25s,starter drive on its way out...blah blah blah.it does have some pluses though-working power doors and door panels,floor and trunk nice,posi disc rear[oh,the pinion seal is leaking]anyway it has potential and is a real ss .oh,salvage title from 1997-have the car fax thanks to bladerunner. | |
| Subject: Re: 96 dggm impala ss 1800.00 Mon Aug 13, 2012 11:46 pm | |
| Ah. I see now. It's definitely worth the $ with what we know it needs. If I was in the market for another B, I'd buy this. Best color too. Dggm ftw. Good luck with the sale. If not, I'm positive we can help you fix it the first time, correctly, and budget friendly. | |
freeways
| Subject: thank you Tue Aug 14, 2012 12:11 am | |
| i'm new to this site and any site actually but you all seem to be a bunch of nice,ready to help b-guys.my main love right now is my rare BLACK[ya you read that right}95 imp that ive had since 99.ive done more mods to it in the last 2 months than in the last 13 years-2 tone sem job[black and gray]z cluster,2" steel cowl hood,spohn extended controls with ford shaft,monte stear wheel,and maybe some 18 or 20 irocs-whens the last time you saw them on an impala!!?? anyway,if there is something somebody needs,i love junk yard hunting and will scout it out if i can-freddie | |
| Subject: Re: 96 dggm impala ss 1800.00 Tue Aug 14, 2012 12:18 am | |
| I live in attleboro, if you find a road master wagon with a good blue leather passenger seat Please let me know in a Pm | |
| Subject: Re: 96 dggm impala ss 1800.00 | |
