Need some suspension suggestions EmptyWed Oct 19, 2022 1:27 pm by scot
Need some suspension suggestions EmptyTue Oct 18, 2022 8:58 pm by silverfox103
Need some suspension suggestions EmptyTue Sep 28, 2021 11:01 pm by silverfox103
Need some suspension suggestions EmptyFri Sep 24, 2021 9:53 am by ElKy
Need some suspension suggestions EmptySun Sep 19, 2021 6:22 pm by black blur 96
Need some suspension suggestions EmptySun Jun 20, 2021 11:37 am by scot
Need some suspension suggestions EmptyFri Jun 11, 2021 10:41 am by scot
Need some suspension suggestions EmptyWed Jun 09, 2021 9:41 pm by Chris Klein
Need some suspension suggestions EmptyWed Jun 02, 2021 9:02 pm by Chris Klein
5 posters
chapel
chapel
PostSubject: Need some suspension suggestions   Need some suspension suggestions EmptySun Apr 15, 2012 8:28 pm
my shocks seem pretty worn and I know the rear air shock has a leak or something... either way, the car's a bit overly rollie-poly over bumps and I wanted to get something SLIGHTLY more stiff and in control. I'm not sure how old the springs are, but I might as well replace those too if I can afford to.
I'd LIKE to remove the air suspension if I can too and make it simpler.
PostSubject: Re: Need some suspension suggestions   Need some suspension suggestions EmptySun Apr 15, 2012 8:39 pm
Gabrial Ultras at autozone are a decent inexpensive shock that will get rid of the bounce.
Regular front and rear
front
http://www.autozone.com/autozone/parts/Gabriel-Ultra-Shock-Strut-Front/1994-Chevrolet-Caprice/_/N-j0wemZ8oxxw?itemIdentifier=220145_172635_7413_2183
rear
http://www.autozone.com/autozone/parts/Gabriel-Ultra-Shock-Strut-Rear/1994-Chevrolet-Caprice/_/N-j0wemZ8oxxx?itemIdentifier=358820_6880_7413_2183
Police/taxi
front
http://www.autozone.com/autozone/parts/Gabriel-Ultra-Shock-Strut-Front/1994-Chevrolet-Caprice/_/N-j0wemZ8oxxw?itemIdentifier=62851_172635_7413_3899
rear
http://www.autozone.com/autozone/parts/Gabriel-Ultra-Shock-Strut-Rear/1994-Chevrolet-Caprice/_/N-j0wemZ8oxxx?itemIdentifier=258467_6880_7413_3899
chapel
chapel
PostSubject: Re: Need some suspension suggestions   Need some suspension suggestions EmptySun Apr 15, 2012 8:48 pm
Police/Taxi are heavier duty and good for a wagon?
Arrow Wink
chapel
chapel
PostSubject: Re: Need some suspension suggestions   Need some suspension suggestions EmptySun Apr 15, 2012 8:49 pm
anything fancy I need to do to disable the air assist for the rear? Just pull a fuse or are there lines I need to remove?
PostSubject: Re: Need some suspension suggestions   Need some suspension suggestions EmptySun Apr 15, 2012 9:24 pm
Just unplug the compressor and you'll be fine
chapel
chapel
PostSubject: Re: Need some suspension suggestions   Need some suspension suggestions EmptySun Apr 15, 2012 9:27 pm
that's what I figured.
you never did the suspension on it, right?
PostSubject: Re: Need some suspension suggestions   Need some suspension suggestions EmptyTue Apr 17, 2012 12:51 pm
I have the Gabriel Ultra's in the rear of my wagon. VERY nice shock. Coupled with the CC623 variable rate spring the ride sits and rides great now Arrow
chapel
chapel
PostSubject: Re: Need some suspension suggestions   Need some suspension suggestions EmptyTue Apr 17, 2012 12:58 pm
where do you get those springs from?
is that coil# both front and rear?
PostSubject: Re: Need some suspension suggestions   Need some suspension suggestions EmptyTue Apr 17, 2012 1:00 pm
Rockauto. But if you give Autozone/Advance that part number they can order them too.
chapel
chapel
PostSubject: Re: Need some suspension suggestions   Need some suspension suggestions EmptyTue Apr 17, 2012 1:01 pm
is that coil part# both front and rear?
PostSubject: Re: Need some suspension suggestions   Need some suspension suggestions EmptyTue Apr 17, 2012 1:09 pm
No. CC623 is for the rear. I have 5030 for the front which is a 9C1 spring.
chapel
chapel
PostSubject: Re: Need some suspension suggestions   Need some suspension suggestions EmptyTue Apr 17, 2012 1:17 pm
awesome, thanks.
so it looks like about $100 for shocks and $100 for springs?
anything else that needs to be replaced when doing those? any 'non reusable bolts/nuts' or bushings?
PostSubject: Re: Need some suspension suggestions   Need some suspension suggestions EmptyTue Apr 17, 2012 1:21 pm
awesome, thanks.
The Ultra's will come with all new hardware.
chapel
chapel
PostSubject: Re: Need some suspension suggestions   Need some suspension suggestions EmptyTue Apr 17, 2012 1:26 pm
jeez, you guys are lucky how cheap this can be...
$200 with my old cars got you used parts.
PostSubject: Re: Need some suspension suggestions   Need some suspension suggestions EmptyTue Apr 17, 2012 1:28 pm
I still own the 1.8T. I know... I know.... Laughing
chapel
chapel
PostSubject: Re: Need some suspension suggestions   Need some suspension suggestions EmptyWed Apr 18, 2012 12:39 pm
are the shocks and springs replaceable without an alignment?
and, seeing as I'm at work without my shop manual, how difficult on a scale of 1 to GODF***INGDAMNIT is changing the suspension?
PostSubject: Re: Need some suspension suggestions   Need some suspension suggestions EmptyWed Apr 18, 2012 3:07 pm
It is highly recommended when a front steering component is replaced that an alignment should follow.
PostSubject: Re: Need some suspension suggestions   Need some suspension suggestions EmptyWed Apr 18, 2012 11:06 pm
Toms right about alignment.
Replacing the springs (front) can be a little scary (only because of the power),
but, with a helping hand its no problem. New suspensions FTW cheers
On the scale....4
....ONLY because of the front springs & one time battle with upper rear shock mounts.
chapel
chapel
PostSubject: Re: Need some suspension suggestions   Need some suspension suggestions EmptyWed Apr 18, 2012 11:07 pm
any special tools required? spring compressor?
Is this 'Shock Absorber Socket' necessary?
http://www.handsontools.com/Kent-Moore-J-25591-Front-Shock-Absorber-Socket_p_22877.html?utm_source=googlebase&utm_medium=CSE&utm_term=Kent-Moore%20J-25591%20Front%20Shock%20Absorber%20Socket&utm_campaign=BROI
PostSubject: Re: Need some suspension suggestions   Need some suspension suggestions EmptyWed Apr 18, 2012 11:19 pm
Nope.
I found theyre more trouble to properly implement then theyre worth.
Remove the tire & shock
Jack under the LCA, loosen BJ castle nut (tap to seperate)
Lower jack slowly & remove spring
Assemble in reverse.
How far are you going?...BJ's too?
PostSubject: Re: Need some suspension suggestions   Need some suspension suggestions EmptyWed Apr 18, 2012 11:23 pm
Cant tell what that shock socket is.
There is a good one for that.
Old shocks I just break it off & go (if your talking fronts).
Rears are only because of location & access to both sides of the nut / bolt
PostSubject: Re: Need some suspension suggestions   Need some suspension suggestions EmptyThu Apr 19, 2012 5:32 am
I just use a deep 9/16 socket with 12"-18" of extension on it. Place the socket with the extension over the top bolt of the front shock, and move the extension back and forth until the bolt fractures. Could take 5 times. Could take twenty times. Make sure you get at least 6-12" of fore and aft movement.
chapel
chapel
PostSubject: Re: Need some suspension suggestions   Need some suspension suggestions EmptyMon Jun 18, 2012 1:27 pm
I need to get this done next. I gave the front bumper a boot and the car was rolling for days Very Happy
chapel
chapel
PostSubject: Re: Need some suspension suggestions   Need some suspension suggestions EmptyThu Jun 21, 2012 12:21 pm
just curious... is there sort of a 'performance' suspension option?
I know I'm not gonna make a corner carver... but I'd like to have something a bit more stable
» WTB - new suspension
» Suspension!!
» Issues I have with ride/suspension
» RUH ROH SHAGGY #@* We might have gone too far this time.
» Suspension Downgrade
