| removing the Home Base bracket | |
chapel
| Subject: removing the Home Base bracket Mon Jun 18, 2012 12:31 pm | |
| Can you guys show me how you secured the wires after removing that bracket? | |
| Subject: Re: removing the Home Base bracket Mon Jun 18, 2012 1:08 pm | |
| I've done 2 without going any further. Just remove the bracket let them lay where they want OR Dress them however you see fit Only thing I watched for were the injector wires.....go easy _________________ Steve 96BBB 28K 3.42 Bolt-ons 95BBB 100K 3.73 383 New DD...already broke fixt the 4L60E twice 95 Black WB4 Hole...ee...grail 96 Black WB4 No holes in this 95BBB 189K 3.08 Old DD Stolen...by Matt. Whine..eee...Silver LS6 | |
| Subject: Re: removing the Home Base bracket Mon Jun 18, 2012 1:11 pm | |
| If you remove that, what will you hook the engine crane to if you have to remove the motor? _________________ 1996 Impala SS - 45K original miles - 5.3 LS swap - Brand new Bilsteins...WHAT A DIFFERENCE!
chapel
| Subject: Re: removing the Home Base bracket Mon Jun 18, 2012 1:16 pm | |
| not really planning on removing the motor, but I'll keep it around | |
| Subject: Re: removing the Home Base bracket Mon Jun 18, 2012 1:25 pm | |
| Subject: Re: removing the Home Base bracket Mon Jun 18, 2012 2:11 pm | |
| - Pooge wrote:
- If you remove that, what will you hook the engine crane to if you have to remove the motor?
- MASShole9C1 wrote:
- Really???
I was kidding, that was my best attempt at a Jim dry-humor special. To the OP - There are several relatively cheap decorative clamps that you could probably find a bolt that would fit in the stock holes and then a pretty loom that could snake through the clamps. I have never actually removed one, but my last Impala had it removed and I don't remember where the wires were routed to... EDIT... This is exactly how mine were run. Good write up. http://www.impalaclub.com/naisso/Forum2009/topic.asp?TOPIC_ID=45970 Doug _________________ 1996 Impala SS - 45K original miles - 5.3 LS swap - Brand new Bilsteins...WHAT A DIFFERENCE!
chapel
| Subject: Re: removing the Home Base bracket Mon Jun 18, 2012 2:13 pm | |
| where are they run on a Camaro or a Corvette? | |
| Subject: Re: removing the Home Base bracket Mon Jun 18, 2012 3:20 pm | |
| - chapel wrote:
- where are they run on a Camaro or a Corvette?
Did you read the article? It attempted to do in the Impala (or Roadmaster Wagon) what was done in the corvetteOr did I mis-read your question? - Pooge wrote:
Doug _________________ Steve 96BBB 28K 3.42 Bolt-ons 95BBB 100K 3.73 383 New DD...already broke fixt the 4L60E twice 95 Black WB4 Hole...ee...grail 96 Black WB4 No holes in this 95BBB 189K 3.08 Old DD Stolen...by Matt. Whine..eee...Silver LS6 | |
| Subject: Re: removing the Home Base bracket Mon Jun 18, 2012 3:22 pm | |
Did you read the article? It attempted to do in the Impala (or Roadmaster Wagon) what was done in the corvette Or did I mis-read your question?
Doug Did you read the time-stamp? I posted the edit after he posted that question _________________ 1996 Impala SS - 45K original miles - 5.3 LS swap - Brand new Bilsteins...WHAT A DIFFERENCE!
chapel
| Subject: Re: removing the Home Base bracket Mon Jun 18, 2012 3:23 pm | |
Doug I did not find that article. I wasn't even aware of that site until just now. Thanks | |
| Subject: Re: removing the Home Base bracket Mon Jun 18, 2012 3:25 pm | |
| Well OK then....good thing I didnt hit it hard then....whoa _________________ Steve 96BBB 28K 3.42 Bolt-ons 95BBB 100K 3.73 383 New DD...already broke fixt the 4L60E twice 95 Black WB4 Hole...ee...grail 96 Black WB4 No holes in this 95BBB 189K 3.08 Old DD Stolen...by Matt. Whine..eee...Silver LS6 | |
| Subject: Re: removing the Home Base bracket Mon Jun 18, 2012 3:29 pm | |
- Well OK then....good thing I didnt hit it hard then....whoa
It's funny how things come across through technology. Depending on how I read your previous post, it came across as you intended or "Hey jackass, someone already answered the question, use your head" Thankfully I know you are not some internet know-it-all tough guy from ISSF. _________________ 1996 Impala SS - 45K original miles - 5.3 LS swap - Brand new Bilsteins...WHAT A DIFFERENCE!
| Subject: Re: removing the Home Base bracket Mon Jun 18, 2012 3:33 pm | |
| HA...thats why I put....or did I mis-read your question. I do occaisionally put my foot in my mouth But your right....no ITG here know it all....maybe _________________ Steve 96BBB 28K 3.42 Bolt-ons 95BBB 100K 3.73 383 New DD...already broke fixt the 4L60E twice 95 Black WB4 Hole...ee...grail 96 Black WB4 No holes in this 95BBB 189K 3.08 Old DD Stolen...by Matt. Whine..eee...Silver LS6 | |
| Subject: Re: removing the Home Base bracket | |
