» Anybody out there?
WTB/WTT manual window door panel EmptyToday at 10:41 am by BostonChevy
WTB/WTT manual window door panel EmptyWed Oct 19, 2022 1:27 pm by scot
WTB/WTT manual window door panel EmptyTue Oct 18, 2022 8:58 pm by silverfox103
WTB/WTT manual window door panel EmptyTue Sep 28, 2021 11:01 pm by silverfox103
WTB/WTT manual window door panel EmptyFri Sep 24, 2021 9:53 am by ElKy
WTB/WTT manual window door panel EmptySun Sep 19, 2021 6:22 pm by black blur 96
WTB/WTT manual window door panel EmptySun Jun 20, 2021 11:37 am by scot
WTB/WTT manual window door panel EmptyFri Jun 11, 2021 10:41 am by scot
WTB/WTT manual window door panel EmptyWed Jun 09, 2021 9:41 pm by Chris Klein
May 2024
4 posters
PostSubject: WTB/WTT manual window door panel   WTB/WTT manual window door panel EmptyTue May 15, 2012 10:10 pm
I know, needle in a hay stack. Glen had a passenger side one for me so its not impossible. It's gotta be a drivers side for 94-96 (lt1) LAB in color (most 9c1s). Manual crank windows with plastic speaker grill. Vinyl/cloth top dont matter. I'd like to swap what I have cuz the factory decided it was a good idea to put carpet over the door speakers. TIA.
PostSubject: Re: WTB/WTT manual window door panel   WTB/WTT manual window door panel EmptyMon Jun 18, 2012 5:46 pm
Bumperooski. Willing to use a different color panel and SEM it. Btw, does anyone know how to remove the crank handles?
PostSubject: Re: WTB/WTT manual window door panel   WTB/WTT manual window door panel EmptyMon Jun 18, 2012 6:31 pm
If they are like the old gm style you can pry out on the handle a little and use a butterknife or flat tool to push out the metal clip that retains it. Theres a tool for it but can be done without.
PostSubject: Re: WTB/WTT manual window door panel   WTB/WTT manual window door panel EmptyMon Jun 18, 2012 6:38 pm
If theyre the same as the good ole days, the handle pushes on a splined shaft.
The handle has 2 slots (one on either side of the handle portion) where it engages the shaft.
There is a clip that looks somewhat like a horshoe & it slides into the slots & locks into a recess cut around the diameter of the splined shaft.
To remove, get a paperclip bent 90 deg about 1/8 long, push in on the door panel & fing the non-open end of the horseshoe, hook it & pull (using needle nose on the paperclip for strength.
Clear as mud? maybe you can goggle image a pic or something?
PostSubject: Re: WTB/WTT manual window door panel   WTB/WTT manual window door panel EmptyMon Jun 18, 2012 6:42 pm
I'll show him at the junk yard tomorrow on one of the old c10's or such.....
PostSubject: Re: WTB/WTT manual window door panel   WTB/WTT manual window door panel EmptyMon Jun 18, 2012 6:53 pm
Thanks for the help gents. Don't want to break these. Thanks for implying the mental handicap btw....duuuuuuuuh.......
PostSubject: Re: WTB/WTT manual window door panel   WTB/WTT manual window door panel EmptyTue Jun 19, 2012 12:24 am
http://www.harborfreight.com/4-piece-windshield-door-trim-tool-set-38386.html
The one on the right. Used to be able to get them at any auto parts store for a few bucks.
» manual window doors for box
» Door Panel Clips
» Wanted:plastic door panel insert
» Rocker panel needed
» need a sail panel
