| Door Panel Clips | |
| Subject: Door Panel Clips Sun Jan 13, 2013 8:56 am | |
| Getting ready to install my front door speakers. Want to order some replacement clips incase I destroy some. What is the p/n on those and how many are on each panel?
TIA! | |
| Subject: Re: Door Panel Clips Sun Jan 13, 2013 9:22 am | |
| Justin, I take it you mean those "tree" things. If that is the case, you can buy those at most auto supply stores, I buy them at NAPA (#665-1107)
Tom | |
| Subject: Re: Door Panel Clips Sun Jan 13, 2013 10:55 am | |
| - silverfox103 wrote:
- Justin, I take it you mean those "tree" things. If that is the case, you can buy those at most auto supply stores, I buy them at NAPA (#665-1107)
Tom I do, Thanks Tom! | |
| Subject: Re: Door Panel Clips Sun Jan 13, 2013 10:58 am | |
| They are also at Vato Zone if that is easier for you... | |
| Subject: Re: Door Panel Clips Sun Jan 13, 2013 11:01 am | |
| - Matt Trakker wrote:
- They are also at Vato Zone if that is easier for you...
They're closer, but more expensive. Napa has 12 for $5, Vatozone is like 4 for $5 | |
| Subject: Re: Door Panel Clips Sun Jan 13, 2013 11:31 am | |
| If its your first time taking the panels off use every precaution. Make sure you have the right tools. I'm always paranoid to break them. The door panels have never been off my caprice since I've owned it because of this lol.. | |
| Subject: Re: Door Panel Clips Sun Jan 13, 2013 11:37 am | |
| - GasTT wrote:
- Make sure you have the right tools.
Make sure you have the tool for removing the "trees"; something like a forked screwdriver, about $7. Don't force anything! Tom | |
| Subject: Re: Door Panel Clips Sun Jan 13, 2013 12:45 pm | |
| Panels have never been off in the front, at least, i've never taken them off. Going to buy the panel removal kit from Harbor Freight. May order some rollers and do those since I'm in there already. | |
| Subject: Re: Door Panel Clips Sun Jan 13, 2013 1:36 pm | |
| They were probably taken off when the tint was done. | |
| Subject: Re: Door Panel Clips Sun Jan 13, 2013 3:31 pm | |
| I bought one of those tools from Advance Auto. I bought it online to get a discount, then picked it up in person, lol.
The door panels on the white Caprice were solid as a rock and never made a sound/rattle. The one in the SS for the driver's door has that common crack starting and they jiggle a little, I will probably pull that one again and see if I can tighten it up and use some plastic bonding stuff on the back of the crack, etc. | |
| Subject: Re: Door Panel Clips | |
