Can I use this electric fan? EmptyWed Oct 19, 2022 1:27 pm by scot
Can I use this electric fan? EmptyTue Oct 18, 2022 8:58 pm by silverfox103
Can I use this electric fan? EmptyTue Sep 28, 2021 11:01 pm by silverfox103
Can I use this electric fan? EmptyFri Sep 24, 2021 9:53 am by ElKy
Can I use this electric fan? EmptySun Sep 19, 2021 6:22 pm by black blur 96
Can I use this electric fan? EmptySun Jun 20, 2021 11:37 am by scot
Can I use this electric fan? EmptyFri Jun 11, 2021 10:41 am by scot
Can I use this electric fan? EmptyWed Jun 09, 2021 9:41 pm by Chris Klein
Can I use this electric fan? EmptyWed Jun 02, 2021 9:02 pm by Chris Klein
4 posters
chapel
chapel
PostSubject: Can I use this electric fan?   Can I use this electric fan? EmptySat Mar 03, 2012 1:46 pm
http://www.amazon.com/PROCOMP-ELECTRIC-COOLING-AUTOMOTIVE-RADIATOR/dp/B003U7UR3A/ref=sr_1_3?ie=UTF8&qid=1330800308&sr=8-3
or can I go bigger?
I really wanna get rid of that giant propeller on the front of my car...
PostSubject: Re: Can I use this electric fan?   Can I use this electric fan? EmptySat Mar 03, 2012 2:09 pm
Dont you already have an electric fan?
If so...delete the mechanical.
You need replacement waterpump bolts if you want to delete the bracket.
Just dump the fan & think about the bracket later
chapel
chapel
PostSubject: Re: Can I use this electric fan?   Can I use this electric fan? EmptySat Mar 03, 2012 3:15 pm
I've got the tow pack. Are there two fans with that?
PostSubject: Re: Can I use this electric fan?   Can I use this electric fan? EmptySat Mar 03, 2012 7:03 pm
1 mechanical & 1 electric as far as I know.
I'm not really a wagon guy.
BUT....
I know if I pop my hood I can find out EVERYTHING about it Arrow
PostSubject: Re: Can I use this electric fan?   Can I use this electric fan? EmptySat Mar 03, 2012 8:05 pm
Tow pack has 1 mech and 1 electric.
PostSubject: Re: Can I use this electric fan?   Can I use this electric fan? EmptySat Mar 03, 2012 8:28 pm
Remove mechanical fan and components, and drive with secondary fan only. I did that before with no ill affects.
chapel
chapel
PostSubject: Re: Can I use this electric fan?   Can I use this electric fan? EmptySat Mar 03, 2012 8:55 pm
I read somewhere on here that Crovo can retune the ECU to make the secondary the primary.
PostSubject: Re: Can I use this electric fan?   Can I use this electric fan? EmptySat Mar 03, 2012 11:04 pm
Or rip out the mechanical stuff and buy a harness from Gary's innovative wiring. Pickup a primary fan from the yard and install it. Did that on my RMW last summer.
chapel
chapel
PostSubject: Re: Can I use this electric fan?   Can I use this electric fan? EmptySat Mar 03, 2012 11:56 pm
I was thinking of that, but slapping a 12" or 16" flexalite in there with a thermoswitch would be like $50. The Innovative Wiring kit by itself is $85...
PostSubject: Re: Can I use this electric fan?   Can I use this electric fan? EmptySun Mar 04, 2012 8:21 am
Not worth it.
Worth it.
chapel
chapel
PostSubject: Re: Can I use this electric fan?   Can I use this electric fan? EmptySun Mar 04, 2012 9:39 am
any reason? I've had great luck with aftermarket fans and thermoswitches. Simple install and ultra quiet fans.
PostSubject: Re: Can I use this electric fan?   Can I use this electric fan? EmptySun Mar 04, 2012 10:14 am
I have yet to see an iron head LT1 overheat or loose a head gasket. I have never even heard of it happening. With that said, with a stock fan, replacement is easy, and plug and play. An aftermarket fan fails, it is not necessarily plug and play easy local replacement. I would prefer the PCM decide when the fan comes on. And Gary's wire harness is better than oem, so a chance if electrical fire is almost non existent.
chapel
chapel
PostSubject: Re: Can I use this electric fan?   Can I use this electric fan? EmptySun Mar 04, 2012 10:20 am
So, I'd need to get the Gary's harness and find the OEM fan stuff?
PostSubject: Re: Can I use this electric fan?   Can I use this electric fan? EmptySun Mar 04, 2012 10:36 am
You would need the harness, the primary fan, upper rad shroud off a non towpack car, and shorter bolts for the water pump when the bracket comes off. All these can be gotten off a car in the yard in once shot.
PostSubject: Re: Can I use this electric fan?   Can I use this electric fan? EmptySun Mar 04, 2012 11:11 am
Or, you could pull the existing shroud, remove the mechanical fan, reinstall the shroud & chaulk it up to 3/4's of a mod that you actually did. Arrow
How'd the exhaust come out?
chapel
chapel
PostSubject: Re: Can I use this electric fan?   Can I use this electric fan? EmptySun Mar 04, 2012 11:21 am
yeah, should probably minimize this pile of parts before I buy more stuff.
I have the entire last week of March off to catch up with stuff. Gonna do the exhaust, radio, subwoofer, get an alignment, yank the air pump for the exhaust off and slap the summer wheels back on
PostSubject: Re: Can I use this electric fan?   Can I use this electric fan? EmptySun Mar 04, 2012 11:44 am
Ya, I have the same problem.
A PILE of best intentions & all the things that get in the way to stop installation.
Thats why I'm TRYING to adopt the DO SOMETHING method.
These guys make me feel silly when I see thier progress & I'm stuck spinning my wheels.
Do what you can do asap & enjoy 1 thing at a time Arrow
» electric fans
» electric fan question
» DuaL Electric cooling fans conversion
» V8 Rumble for your 4 banger or electric car...
» Looking for auto electric in Maine/NH
