| DuaL Electric cooling fans conversion | |
Waldo617
| Subject: DuaL Electric cooling fans conversion Tue Oct 26, 2010 3:44 pm | |
| Has anyone ever converted a 96 caprice with the belt driven fan to the dual electric fan set up? I found a 96 roadmaster with dual fans in the junkyard and I want to do the conversion if someone with experience doing it is willing yo help
Thanks | |
| Subject: Re: DuaL Electric cooling fans conversion Tue Oct 26, 2010 3:47 pm | |
| I did it in my Caprice. Just remove the mechanical fan crap. Then install the fans. They should just plug right in. I think you need to program your computer for it. Mine is not programmed and my fans stay on all the time. I don't think thats a good thing.
Make sure you grab the water pump bolts from the donor car I think they are shorter. | |
| Subject: Re: DuaL Electric cooling fans conversion Tue Oct 26, 2010 3:54 pm | |
| The bracket that clips on the top and bottom of the radiator are different. The dual fan clips have the mounting points for the second fan.
There's a wiring kit that you can buy to make the second fan work correctly. Crovo can explain it better. | |
| Subject: Re: DuaL Electric cooling fans conversion Tue Oct 26, 2010 4:14 pm | |
| Here's the guide from the Wagon forum. This is one of those things on my "to do eventually" list.
http://gmlongroof.4umer.com/engine-f28/mechanical-fan-delete-t57.htm | |
| Subject: Re: DuaL Electric cooling fans conversion Tue Oct 26, 2010 4:39 pm | |
| I've converted to the 2 fans system, following Bob Ignash's directions, the link posted by Justin. Follow them and you won't have any problems.
The bracket clips are the same on both types of radiators. At the junk yard take the 2 fans and the top radiator support piece and any wiring that you can. I had the PCM reprogrammed to have the primary fan come on sooner; but even if you don't they will still work.
Take your time and make sure you do the wiring correct.
Tom C.
| Subject: Re: DuaL Electric cooling fans conversion Tue Oct 26, 2010 5:25 pm | |
| you dont need both fans, just the one in place of the mech. Fan.. If your looking at the engine bay from the front of the car, the fan on your left is what you need. Water Pump bolts ARE longer for the mech. fan bracket, so get the shorter ones. | |
| Subject: Re: DuaL Electric cooling fans conversion Tue Oct 26, 2010 5:58 pm | |
| If your secondary fan goes, you'll be sorry you didn't take the second fan.
Tom C.
Last edited by silverfox103 on Tue Oct 26, 2010 6:50 pm; edited 1 time in total | |
| Subject: Re: DuaL Electric cooling fans conversion Tue Oct 26, 2010 6:47 pm | |
| Don't they all have the secondary fan? I'm ONLY running the stock secondary fan right, for the roundup and everything, mech. Fan deleted, e-fan in, but not hooked up or wired yet | |
| Subject: Re: DuaL Electric cooling fans conversion Tue Oct 26, 2010 6:50 pm | |
| Subject: Re: DuaL Electric cooling fans conversion Tue Oct 26, 2010 6:56 pm | |
| Bottom clip is different. I almost ended up with the single fan clip and switched it out at the last second when I realized it didn't have the provision for the second fan. Doug can show you the difference if you ever try to snag one from him. | |
| Subject: Re: DuaL Electric cooling fans conversion Tue Oct 26, 2010 7:13 pm | |
| - bammax wrote:
- Bottom clip is different. I almost ended up with the single fan clip and switched it out at the last second when I realized it didn't have the provision for the second fan. Doug can show you the difference if you ever try to snag one from him.
My car(95) had the metal mount that slides into the fan on the bottom already. Stock. | |
| Subject: Re: DuaL Electric cooling fans conversion Tue Oct 26, 2010 7:20 pm | |
| Some of them only have a single offset tab for the single fan. You can't assume they all had the dual tabs because then you may be screwed when it comes time to do the swap. Just like you can't assume that the bolts that hold the fan to the tanks will come out. Sometimes you need to cut them out and then search your parts bin for a new bolt that's close enough to work. I almost lost an eye playing that game | |
Waldo617
| Subject: Re: DuaL Electric cooling fans conversion Tue Oct 26, 2010 8:42 pm | |
| Ok so unplugged the fans and removed both fans. I also removed the piece from the bottom of the radiator that has the two tabs on it I got the top radiator support and the piece from the top of the radiator that the fans bolt to... | |
| Subject: Re: DuaL Electric cooling fans conversion Tue Oct 26, 2010 8:50 pm | |
| Now you just need to swap it all in and then do the wiring. Like mentioned you can get the shorter bolts too since you don't need them to hold the fan on anymore. | |
| Subject: Re: DuaL Electric cooling fans conversion | |
