Are the TBI 9C1 and Civi odometers the same? EmptyWed Oct 19, 2022 1:27 pm by scot
Are the TBI 9C1 and Civi odometers the same? EmptyTue Oct 18, 2022 8:58 pm by silverfox103
Are the TBI 9C1 and Civi odometers the same? EmptyTue Sep 28, 2021 11:01 pm by silverfox103
Are the TBI 9C1 and Civi odometers the same? EmptyFri Sep 24, 2021 9:53 am by ElKy
Are the TBI 9C1 and Civi odometers the same? EmptySun Sep 19, 2021 6:22 pm by black blur 96
Are the TBI 9C1 and Civi odometers the same? EmptySun Jun 20, 2021 11:37 am by scot
Are the TBI 9C1 and Civi odometers the same? EmptyFri Jun 11, 2021 10:41 am by scot
Are the TBI 9C1 and Civi odometers the same? EmptyWed Jun 09, 2021 9:41 pm by Chris Klein
Are the TBI 9C1 and Civi odometers the same? EmptyWed Jun 02, 2021 9:02 pm by Chris Klein
PostSubject: Are the TBI 9C1 and Civi odometers the same?   Are the TBI 9C1 and Civi odometers the same? EmptySun Feb 19, 2012 8:34 am
I've been spinning my 9C1 cluster to my cars mileage with a drill, and there has to be an easier way. It took me like 20 minutes to go 3,000 miles. And I have to go from 216k all the way back to 135k. So then I took one of my spare clusters apart and found the actual "drum" with the numbers looks similar to the civilian one. Are they? If thats the case I think I may just swap the two to save the hassle of having to spin the odometer manually.
PostSubject: Re: Are the TBI 9C1 and Civi odometers the same?   Are the TBI 9C1 and Civi odometers the same? EmptySun Feb 19, 2012 9:18 am
I would imagine they are. Carefully pull both clusters apart, and look at the inner workings. Also check for dead bulbs while you are there. I can't see GM using different parts on something like that.
PostSubject: Re: Are the TBI 9C1 and Civi odometers the same?   Are the TBI 9C1 and Civi odometers the same? EmptySun Feb 19, 2012 9:23 am
I already have the 9C1 cluster I plan to use semi disassembled in case I luck out and the odos are the same. I'll take the Civi one apart right before we start the swap. Already pulled all the bulbs and replaced dead ones. There were only 2, amazingly Arrow
» WTB Civi air dams+ Hardware
» 1995 civi caprice body
» Full grey civi trunk mat.
» 94 Civi, interior lights staying on
» Center caps and trim rings for civi wheels?
