Broken Manifold Bolt - Don't Try This At Home! EmptyWed Oct 19, 2022 1:27 pm by scot
Broken Manifold Bolt - Don't Try This At Home! EmptyTue Oct 18, 2022 8:58 pm by silverfox103
Broken Manifold Bolt - Don't Try This At Home! EmptyTue Sep 28, 2021 11:01 pm by silverfox103
Broken Manifold Bolt - Don't Try This At Home! EmptyFri Sep 24, 2021 9:53 am by ElKy
Broken Manifold Bolt - Don't Try This At Home! EmptySun Sep 19, 2021 6:22 pm by black blur 96
Broken Manifold Bolt - Don't Try This At Home! EmptySun Jun 20, 2021 11:37 am by scot
Broken Manifold Bolt - Don't Try This At Home! EmptyFri Jun 11, 2021 10:41 am by scot
Broken Manifold Bolt - Don't Try This At Home! EmptyWed Jun 09, 2021 9:41 pm by Chris Klein
Broken Manifold Bolt - Don't Try This At Home! EmptyWed Jun 02, 2021 9:02 pm by Chris Klein
14 posters
PostSubject: Broken Manifold Bolt - Don't Try This At Home!   Broken Manifold Bolt - Don't Try This At Home! EmptySat Jul 04, 2009 9:28 pm
Broken exhaust manifold bolt in a iron head.
Broken Manifold Bolt - Don't Try This At Home! Bolt1_I
Clean the end of the bolt.
Broken Manifold Bolt - Don't Try This At Home! Bolt2_I
Hold a washer and a 7/16th nut in place with magnets and weld.
Broken Manifold Bolt - Don't Try This At Home! Bolt3_I
Almost done.
Broken Manifold Bolt - Don't Try This At Home! Bolt4_I
Broken bolt out.
Broken Manifold Bolt - Don't Try This At Home! Bolt5_I
Done.
Broken Manifold Bolt - Don't Try This At Home! Bolt6
Notes:
It took longer to resize and post the photos then it did to do the whole job.
Engine removal was done for demonstation purposes only. You don't need to remove the engine from the car.
This bolt came out fairly easy.
I have had some stubbon ones in the past that broke multiple times.
A MIG welder is nice but I've done this with a stick welder in past.
PostSubject: dont try this at home   Broken Manifold Bolt - Don't Try This At Home! EmptySat Jul 04, 2009 9:32 pm
wow you did good. gold star to you.
PostSubject: Re: Broken Manifold Bolt - Don't Try This At Home!   Broken Manifold Bolt - Don't Try This At Home! EmptySat Jul 04, 2009 9:38 pm
We now know where to send our cars when we break bolts off. Good work. You did say it was easier than it seemed.
PostSubject: Re: Broken Manifold Bolt - Don't Try This At Home!   Broken Manifold Bolt - Don't Try This At Home! EmptySat Jul 04, 2009 9:45 pm
Nice pics, Jim! Looks like the technique has improved with experience! Very Happy
(not sure if that's a good thing or not... Wink)
PostSubject: Re: Broken Manifold Bolt - Don't Try This At Home!   Broken Manifold Bolt - Don't Try This At Home! EmptySat Jul 04, 2009 9:46 pm
I'm impressed. Couldn't begin to imagine what a shop would charge for a job like that.
PostSubject: Re: Broken Manifold Bolt - Don't Try This At Home!   Broken Manifold Bolt - Don't Try This At Home! EmptySat Jul 04, 2009 10:18 pm
did you get rid of the flux core and use gas ?
PostSubject: Re: Broken Manifold Bolt - Don't Try This At Home!   Broken Manifold Bolt - Don't Try This At Home! EmptySat Jul 04, 2009 11:01 pm
If your car is anything like mine welding the nut on is the easy part. I usually have to cut the nuts off the manifold studs, replace the studs, and break or cut the cat to imtermediate pipe bolts.
I'll bet it would cost more than the cost of a welder for a shop to do it. Seems most want to pull the head.
I got gas. It was expensive to buy the tank but I should be able to weld thinner metal and clean up is much easier.
Bill I still have the first bolt with a broken extractor in it. Smile That was on the driver's side of my current car. That's the one I did with a stick welder. Much later I did the passenger side and had 4 bolts break. One of them broke 3 times after welding on a nut. I used up my entire stock of 7/16th nuts on that job.
I posted this because a few folks on that other forum either didn't want to try or couldn't get a welder willing to do it and ended up pulling the head. Of course you could always buy headers but that assumes you won't break any other bolts.
Almost forgot, I unplug the PCM before welding just in case.
And don't worry I'll replace those Delco plugs with some nice Bosch plugs. Smile
PostSubject: Re: Broken Manifold Bolt - Don't Try This At Home!   Broken Manifold Bolt - Don't Try This At Home! EmptySun Jul 05, 2009 11:12 pm
I used a MIG welder on mine. Basically the same method, with the exhaust manifold off (of course). I didn't think of using magnets though, just held the nut and tacked it up. Great job guys!
PostSubject: Re: Broken Manifold Bolt - Don't Try This At Home!   Broken Manifold Bolt - Don't Try This At Home! EmptySun Oct 04, 2009 9:38 am
Works for broken brake caliper bolts too. Smile
PostSubject: Re: Broken Manifold Bolt - Don't Try This At Home!   Broken Manifold Bolt - Don't Try This At Home! EmptySun Oct 04, 2009 6:07 pm
That's an awesome trick
PostSubject: Re: Broken Manifold Bolt - Don't Try This At Home!   Broken Manifold Bolt - Don't Try This At Home! EmptySun Dec 06, 2009 1:38 am
Works on rusy differential cover bolts too. The magnets loose their magnetism after a few heat cycles.
Broken Manifold Bolt - Don't Try This At Home! Bolts
PostSubject: Re: Broken Manifold Bolt - Don't Try This At Home!   Broken Manifold Bolt - Don't Try This At Home! EmptySun Dec 06, 2009 8:59 pm
Freakin awesome job Dude. I got a couple broken manifold bolts that need to come out next summer. This information is priceless. cheers
PostSubject: Re: Broken Manifold Bolt - Don't Try This At Home!   Broken Manifold Bolt - Don't Try This At Home! EmptyWed Sep 19, 2012 12:39 am
I now use Harbor Freight rare earth magnets. Strong little suckers. One or two heat cycles and they lose most of their magnetism.
PostSubject: Re: Broken Manifold Bolt - Don't Try This At Home!   Broken Manifold Bolt - Don't Try This At Home! EmptyWed Sep 19, 2012 12:42 pm
Great job! Will a MIG like the one below do the job? I have the same one but never used it for anything besides light exhaust work. Even with that I still have no welding skills Surprised
http://www.sears.com/craftsman-wire-feed-welder-gasless/p-00920568000P?prdNo=2&blockNo=2&blockType=G2
Bull
Bull
PostSubject: Re: Broken Manifold Bolt - Don't Try This At Home!   Broken Manifold Bolt - Don't Try This At Home! EmptyThu Jul 25, 2013 9:05 pm
I'm glad you posted this and provided good pictures. I can see that the rear bolt on the DS seems to be missing, so I'm guessing that when the manifold comes off I'm going to find a broken bolt in the hole.
Time to learn how to use my welder.
Is there ever a problem with the weld fusing the washer to the head itself if everything isn't lined up exactly right, thereby creating a greater FUBAR situation?
PostSubject: Re: Broken Manifold Bolt - Don't Try This At Home!   Broken Manifold Bolt - Don't Try This At Home! EmptyThu Jul 25, 2013 10:49 pm
No problems on the 6 or so that I have done. With cast heads I think you'd have to really try hard to weld to them.
Bull
Bull
PostSubject: Re: Broken Manifold Bolt - Don't Try This At Home!   Broken Manifold Bolt - Don't Try This At Home! EmptyThu Jul 25, 2013 11:02 pm
Cool.
How much practice does someone need with a flux core welder before they can do this? Almost none, I hope.
PostSubject: Re: Broken Manifold Bolt - Don't Try This At Home!   Broken Manifold Bolt - Don't Try This At Home! EmptyThu Jul 25, 2013 11:32 pm
I don't really know, try it on a bolt in a vise. Often the rear bolt is actuall very loose after the head is sheared off.
FUN-9C1
FUN-9C1
PostSubject: Re: Broken Manifold Bolt - Don't Try This At Home!   Broken Manifold Bolt - Don't Try This At Home! EmptyFri Jul 26, 2013 12:28 pm
Nice job.
Another piece of advice for anyone with a broken exh man bolt that I learned the hard way. Don't assume that just because it's broken that it's stuck. A few years ago I took my cylinder head off my 9C1 to drill it out only to find that the bolt came right out by hand. The manifold had warped and popped the head of the bolt off, but the threads were still fine. Try it by hand first, you might get lucky! Smile
Bull
Bull
PostSubject: Re: Broken Manifold Bolt - Don't Try This At Home!   Broken Manifold Bolt - Don't Try This At Home! EmptyFri Jul 26, 2013 4:27 pm
I pulled the DS manifold off today. There were only 4 out of 6 bolts holding the thing to the head; the back two bolts were missing because they had snapped off in the head at some point. So obviously that back exhaust port was sealing very poorly and creating a large leak.
I gotta get my welder back from the friend whom I loaned it to and practice some real basic maneuvers so I can get this job done. One bolt is broken off about flush with the block, maybe just a little less and the other is inside the bolt hole a ways.
Yippee!
MancheSSterJake
MancheSSterJake
PostSubject: Re: Broken Manifold Bolt - Don't Try This At Home!   Broken Manifold Bolt - Don't Try This At Home! EmptyFri Jul 26, 2013 5:33 pm
Impressive work.  This could lead to $$ for you doing this for those of us that have suffered!!
PostSubject: Re: Broken Manifold Bolt - Don't Try This At Home!   Broken Manifold Bolt - Don't Try This At Home! EmptyFri Jul 26, 2013 10:13 pm
Wonder how many times you've made money doing this in the last 4 years since this was posted Jim?????????
» Broken manifold bolt "MOD"
» Exhaust manifold bolt fix
» The home improvement thread. Everything home improvement related goes here or else i'm tellin
» INTAKE MANIFOLD GASKET
» Driveshaft
