| Front passenger window rolls down REAL slow. is this a sign of failure? | |
chapel
| Subject: Front passenger window rolls down REAL slow. is this a sign of failure? Fri Dec 09, 2011 8:36 am | |
| I noticed the other day when I was rolling down the windows, the passenger one is REALLY slow compared to the others what does this indicate? | |
| Subject: Re: Front passenger window rolls down REAL slow. is this a sign of failure? Fri Dec 09, 2011 10:41 am | |
| - chapel wrote:
- I noticed the other day when I was rolling down the windows, the passenger one is REALLY slow compared to the others
what does this indicate? Tracks and channels need lube & or the motor is dying | |
chapel
| Subject: Re: Front passenger window rolls down REAL slow. is this a sign of failure? Fri Dec 09, 2011 10:47 am | |
| I assume both fixes are a 'panel off' affair either way? | |
| Subject: Re: Front passenger window rolls down REAL slow. is this a sign of failure? Fri Dec 09, 2011 10:55 am | |
| Yes IMO motor failure is a regulator out affair too | |
chapel
| Subject: Re: Front passenger window rolls down REAL slow. is this a sign of failure? Fri Dec 09, 2011 10:58 am | |
| is that a pain in the ass to do? If I'm yanking door panels, I might upgrade my speakers and get new clips to hold the doors on. | |
| Subject: Re: Front passenger window rolls down REAL slow. is this a sign of failure? Fri Dec 09, 2011 11:12 am | |
| - chapel wrote:
- is that a pain in the ass to do?
For you? or your mechanic?...... You'll feel like a gynecologist. You'll understand when you go to do it. | |
chapel
| Subject: Re: Front passenger window rolls down REAL slow. is this a sign of failure? Fri Dec 09, 2011 11:13 am | |
| I assume you're talking about the vapor barrier. | |
chapel
| Subject: Re: Front passenger window rolls down REAL slow. is this a sign of failure? Fri Dec 09, 2011 11:15 am | |
| also, is this one of those instances where the window may crash down into the door unexpectedly? | |
| Subject: Re: Front passenger window rolls down REAL slow. is this a sign of failure? Fri Dec 09, 2011 12:45 pm | |
| - chapel wrote:
- I assume you're talking about the vapor barrier.
No, you'll be working up to your elbows thru a hole, .. ....you made me say it didnt you - chapel wrote:
- also, is this one of those instances where the window may crash down into the door unexpectedly?
The window crashes only if it disconnects from its plastic slides. Rarely do they both go at once, you get that tip before all out crash. The slides get replaced with plastic rollers when they fail. Its only a pia but only because of the access. Set aside some time & work slowly, it'll keep from bleeding as much | |
chapel
| Subject: Re: Front passenger window rolls down REAL slow. is this a sign of failure? Fri Dec 09, 2011 2:01 pm | |
| - chapel wrote:
- ..... I have issues ......
Agreed. - chapel wrote:
- I'm just gonna leave that there
And I'm gonna let you... I'm trying to flash back. I think there are 4 holes, IIR the lower holes are larger...IDK. None of which are small enough to let you in but not out. If you can take the door panels off to get a look, your 1/2 way there. Either way the door panels have to come off. Maybe theres a UTube? | |
chapel
| Subject: Re: Front passenger window rolls down REAL slow. is this a sign of failure? Fri Dec 09, 2011 2:05 pm | |
| yeah, I'm not too worried. I got access to little armed fellas in a pinch (at some point today I'll make a point without any innuendo, I swear)
I'm not too worried though, I've worked in cramped door panels before without issue, but I know it can be frustrating. | |
| Subject: Re: Front passenger window rolls down REAL slow. is this a sign of failure? | |
