» Anybody out there?
should I tune my car? EmptyToday at 10:41 am by BostonChevy
should I tune my car? EmptyWed Oct 19, 2022 1:27 pm by scot
should I tune my car? EmptyTue Oct 18, 2022 8:58 pm by silverfox103
should I tune my car? EmptyTue Sep 28, 2021 11:01 pm by silverfox103
should I tune my car? EmptyFri Sep 24, 2021 9:53 am by ElKy
should I tune my car? EmptySun Sep 19, 2021 6:22 pm by black blur 96
should I tune my car? EmptySun Jun 20, 2021 11:37 am by scot
should I tune my car? EmptyFri Jun 11, 2021 10:41 am by scot
should I tune my car? EmptyWed Jun 09, 2021 9:41 pm by Chris Klein
May 2024
chapel
6 posters
chapel
chapel
PostSubject: should I tune my car?   should I tune my car? EmptyMon Oct 31, 2011 9:16 pm
I was curious if there's any benefit to getting a tune on a stock engine?
I've always tuned my stock engines to at least get some advance in the spark to get some more efficiency and throttle response.
PostSubject: Re: should I tune my car?   should I tune my car? EmptyMon Oct 31, 2011 9:25 pm
Yes, Yes Yes!
http://pcmperformance.com/
Change VIN
=Disable VATS
=Change RPM or speed limiters
=Speedometer recalibration for axle ratio or tire changes
=POWER TUNE = spark timing and fuel remapped for more hp/torque
=ECONOMY TUNE = improved mpg
=High or low octane programming
=Lower fan turn-on temp settings
=Remap shift patterns for performance or towing
=Remap shift pressures for firmer shifts
=Modify TCC lockup speeds for performance or towing
Compensate for high stall TC
Switch automatic to manual transmission or vice versa
Compensate for displacement changes
Adjust for different fuel injectors
Adjust for larger throttle body
Compensate for cam changes for driveability and power
=Delete emission functions and codes (EGR, AIR pump, EVAP, O2s, etc.)
=Program for MAFless operation = speed density mode
=Delete various nuisances (SKIP SHIFT, traction control ,etc.)
Remove or add torque management
Delete other miscellaneous functions and trouble codes (A/C, oil level, etc.)
Nitrous, forced induction and more...
Things marked = at the begining, are ones that you can do to a stock motor without any real mods.
Or there are some on here that can tune as well.
chapel
chapel
PostSubject: Re: should I tune my car?   should I tune my car? EmptyMon Oct 31, 2011 9:29 pm
Yes, Yes Yes!
Change VIN
why would I want to change my VIN?
Disable VATS
what's VATS?
Oooo
Do they have selectable tunes or is it one or the other?
MAFless? what other changes do you need to make? is there an existing MAP sensor that's got a high enough resolution to handle it or do you need an aftermarket sensor?
so, basically... yes, I should... Wink
I kinda wish I had OBD2 so I could flash it myself
PostSubject: Re: should I tune my car?   should I tune my car? EmptyTue Nov 01, 2011 2:22 pm
No.
PostSubject: Re: should I tune my car?   should I tune my car? EmptyTue Nov 01, 2011 3:34 pm
No.
But should he Dyno it? Wink
PostSubject: Re: should I tune my car?   should I tune my car? EmptyTue Nov 01, 2011 3:42 pm
No.
No
PostSubject: Re: should I tune my car?   should I tune my car? EmptyTue Nov 01, 2011 4:16 pm
chapel
chapel
PostSubject: Re: should I tune my car?   should I tune my car? EmptyTue Nov 01, 2011 8:35 pm
did someone get a bad tune and a blow up?
PostSubject: Re: should I tune my car?   should I tune my car? EmptyTue Nov 01, 2011 9:00 pm
OBD2 SUCKS ASS. Mad
chapel
chapel
PostSubject: Re: should I tune my car?   should I tune my car? EmptyTue Nov 01, 2011 9:02 pm
oh
I have OBD1... so no big deal.
I was wondering about those 'DIY' tuning kits. I think I saw something called TunerCAT or something?
PostSubject: Re: should I tune my car?   should I tune my car? EmptyTue Nov 01, 2011 10:29 pm
I bought the cable and used tunerCAT before, not too hard to use. I did only change fan temps and adjust my speedo though. Looks like you can do some fun stuff in there.
chapel
chapel
PostSubject: Re: should I tune my car?   should I tune my car? EmptyWed Nov 02, 2011 9:56 am
Is TunerCat locked to your ECU when you use it or if someone I know has TunerCAT and the cable, can they tune my car?
» Can anyone tune out AIR/EGR in NE??? (OBDII)
» Dyno tune
» Looking for a tune (bin file) for a heads/cam/4L60E/comverter OBD1 car
» Lt1 tune up - help needed!
» Tune by Tuna Car Show 8/14 in Springfield Ma
