 Looking for a tune (bin file) for a heads/cam/4L60E/comverter OBD1 car
PostSubject: Looking for a tune (bin file) for a heads/cam/4L60E/comverter OBD1 car   Thu Apr 18, 2013 7:46 pm
Hey Guys,
I've got a bit of a bum tune in the wagon and am looking to see if one of you guys may have a tune you're happy with. And if so, might you be willing to hook me up with a copy?
I'd take any tune with a cam and a converter and see how it goes.
The lowdown on my car's setup in case you may have more than one option.
Standard bore 350 LT1
Comp 305 cam
1.6 RR's
30 lb SVO injectors (red tops)
intake/headers/2.5" exhaust
EGR delete
160* stat
4L60E with 2600 stall
3.42's
295/35/18's
6000 RPM redline, so shift called for at like 5600?
I also have a 52mm TB to add if you have a tune for that.
If your tire size or gears or fans are different, that's ok. I have tunercat and can change those myself, but I do not have the know-how to get into the real meat of the tune and deal with the tranny programs and such.
And of course, I would be willing to compensate you for it, if you want. Smile
I had a kickass dyno tune for this motor in my 6speed car, but a quickie translation to an automatic tranny file didn't quite jive right. If you want to see that file and play with it, I can get it to you.
Thanks for any help!
PostSubject: Re: Looking for a tune (bin file) for a heads/cam/4L60E/comverter OBD1 car   Thu Apr 18, 2013 8:57 pm
Oh. So someone DOES use a 52mm TB...
PostSubject: Re: Looking for a tune (bin file) for a heads/cam/4L60E/comverter OBD1 car   Thu Apr 18, 2013 9:02 pm
Not yet. Wink
PostSubject: Re: Looking for a tune (bin file) for a heads/cam/4L60E/comverter OBD1 car   Thu Apr 18, 2013 9:04 pm
Who reads anymore??? I like to look at the pictures Wink
I see what just happened.
Anyway, good luck with your search.
PostSubject: Re: Looking for a tune (bin file) for a heads/cam/4L60E/comverter OBD1 car   Thu Apr 18, 2013 9:07 pm
You're quick! You got in before the edit. Didn't want to seem too snappy so I got rid of that. Wink
Oh, and I didn't open that post because I wasn't running one yet. I just read it. Yeah, what Al said. Wink
PostSubject: Re: Looking for a tune (bin file) for a heads/cam/4L60E/comverter OBD1 car   Thu Apr 18, 2013 9:08 pm
Can you use the file from the Impala, and add the 1A2 tranny program? Or does it not work like that, and I should go sit down and let the adults talk?
PostSubject: Re: Looking for a tune (bin file) for a heads/cam/4L60E/comverter OBD1 car   Thu Apr 18, 2013 9:12 pm
That's what I'd like to do. And I don't know all the tables, etc, to do it myself. I talked to a couple other guys and they didn't trust themselves enough to do it. And besides, that 1A2 tranny program is for a stock converter. I think a higher stall converter messes with the idle and tip in and needs to be adjusted for... Again... I ain't got da skillz...
PostSubject: Re: Looking for a tune (bin file) for a heads/cam/4L60E/comverter OBD1 car   Thu Apr 18, 2013 10:19 pm
Just send a pcm to PCMperformance.com They do good work. I have been happy with the three tunes they did for me.
PostSubject: Re: Looking for a tune (bin file) for a heads/cam/4L60E/comverter OBD1 car   Thu Apr 18, 2013 10:34 pm
Yeah, I've worked with Anthony and (i forget his name) in the past. They're good guys. But paying for another tune is out of the budget right now.
PostSubject: Re: Looking for a tune (bin file) for a heads/cam/4L60E/comverter OBD1 car   Thu Apr 18, 2013 10:41 pm
I hear ya. My boat budget was blown by over a grand, and still climbing for little things.
The other guy is Alex.
» Trick with Half or Nothing, use Vayu to tune on the field
» Can anyone tune out AIR/EGR in NE??? (OBDII)
» Lt1 tune up - help needed!
» "Tune By Tuna" car show, Spfld. MA, Smith and Wesson grounds
» All Nokia BB5 MCU PPM CNT Flash File Here By ..::sunny boy::..
