In total there are 3 users online :: 2 Registered, 0 Hidden and 1 Guest :: 1 Bot
Cadet57, Tomz9C1
» Digital cluster repair
Today at 3:21 am by Ironfistdog
» Awesome "Tuning for Dummies" website!
Today at 12:58 am by GasTT
» CraigsList car finder
Yesterday at 6:54 pm by MASShole9C1
»  Rear disc flex hose bracket?
Yesterday at 6:01 pm by Tomz9C1
» Set of Z71 Tahoe wheels and tires
Yesterday at 5:33 pm by Matt Trakker
» Random parts for sale
Yesterday at 5:19 pm by Matt Trakker
» 1968 Impala build
Yesterday at 2:39 pm by 8bud
» Curious who has what....
Yesterday at 12:49 pm by bfurches
» Schematics
Yesterday at 10:18 am by MASShole9C1
May 2013
Share | .
 No turn signals, high beams, brake lights or speedo
PostSubject: No turn signals, high beams, brake lights or speedo   Fri Oct 14, 2011 12:29 pm
All this stuff is out on my caprice. I need to drive to the cape tonight. I can't without brake lights. I'm hoping someone can chime in asap. I've got work in the cape at 8am. I checked fuses. I have headlights and running lights. What is the green box under the dash? Is it just for the key/lights chime? I pulled it out a few days ago due to it chiming for no reason while I was driving. Although it is not related. This is a new problem. Please help!!!!!!!
PostSubject: Re: No turn signals, high beams, brake lights or speedo   Fri Oct 14, 2011 12:55 pm
Do the hazard lights blink /work?
PostSubject: Re: No turn signals, high beams, brake lights or speedo   Fri Oct 14, 2011 1:04 pm
No
PostSubject: Re: No turn signals, high beams, brake lights or speedo   Fri Oct 14, 2011 1:53 pm
I know you said you checked fuses which would be:
#6, #11, #13, #20, #31, #33, #37, #41,#42, #43
correct?
Did you put the chime module back in to see if it made a difference?
Did you check for power with a test light at the #43 fuse?
PostSubject: Re: No turn signals, high beams, brake lights or speedo   Sat Jan 28, 2012 6:00 pm
Follow up:
Turn signal switch was bad.
PostSubject: Re: No turn signals, high beams, brake lights or speedo   Sun Jan 29, 2012 3:07 am
Glad to hear that got fixed. What a PITA it must have been finding all of that didnt work. These cars are something else. More so at the worst possible times. Shocked
PostSubject: Re: No turn signals, high beams, brake lights or speedo   Sun Jan 29, 2012 3:11 am
Yea, and it happened at night when I needed to drive the car an hour and a half. Ended up having to get a ride.
Repair shown here.
» Max lights
» First turn quasar kill
» Sting Turn's 60 & Reveals A New Do On Letterman
» How to turn of one specific lamp in tutorial 8
» New Fluval Edge has LED lights, as does the MkI version.
