 electronic issue (turn signals, shift interlock..)
PostSubject: electronic issue (turn signals, shift interlock..)   Sun Sep 23, 2012 11:30 pm
So the turn signals, brake transmission shift interlock and auto lock unlock with shift quit working at once.
I can shift out of park without touching the brake. Doors do not lock/unlock going out out or into park. Turn signals don't work at all. Hazards work.cornering lights come on. Running lights and brake lights work. What could have broken? Thanks.
PostSubject: Re: electronic issue (turn signals, shift interlock..)   Sun Sep 23, 2012 11:32 pm
Did you check all the fuses?
PostSubject: Re: electronic issue (turn signals, shift interlock..)   Mon Sep 24, 2012 5:21 am
Fuse or relay.
PostSubject: Re: electronic issue (turn signals, shift interlock..)   Mon Sep 24, 2012 10:10 am
I didn't have a chance to look at anything when I posted this. I just looked at some wire diagrams and it seems the brake transmission interlock switch and the turn signal lamp flasher use the same fuse. T/SIG 15A.
» Constant power to wipers/turn signals
» VALVE ELECTRONIC
» Won't turn on?
» Turn Turtle Mitt - crochet
» Electronic symbols online
