Broken Gauge cluster? EmptyWed Oct 19, 2022 1:27 pm by scot
Broken Gauge cluster? EmptyTue Oct 18, 2022 8:58 pm by silverfox103
Broken Gauge cluster? EmptyTue Sep 28, 2021 11:01 pm by silverfox103
Broken Gauge cluster? EmptyFri Sep 24, 2021 9:53 am by ElKy
Broken Gauge cluster? EmptySun Sep 19, 2021 6:22 pm by black blur 96
Broken Gauge cluster? EmptySun Jun 20, 2021 11:37 am by scot
Broken Gauge cluster? EmptyFri Jun 11, 2021 10:41 am by scot
Broken Gauge cluster? EmptyWed Jun 09, 2021 9:41 pm by Chris Klein
Broken Gauge cluster? EmptyWed Jun 02, 2021 9:02 pm by Chris Klein
2 posters
JW94SSLT1
JW94SSLT1
PostSubject: Broken Gauge cluster?   Broken Gauge cluster? EmptyWed Sep 07, 2011 7:23 am
I'm not sure what to do my speed and gas gauge work but nothing else Ive changed the cluster out once and nothing changed I have no engine temp it always reads cold and oil pressure reads nothing and the volts is high all the time any ideas should i just change to a z cluster?
PostSubject: Re: Broken Gauge cluster?   Broken Gauge cluster? EmptyWed Sep 07, 2011 8:42 am
Did you change the WHOLE cluster? or just the speedo piece?
I'd look at fuses first, then remove the whole assembly and clean the contacts. Maybe they are corroded a litte, i know mine in the 96 where.
Let me know what you need, i have a couple cars left with clusters. Come up and take a couple to try if you want.
Glen
JW94SSLT1
JW94SSLT1
PostSubject: Broken Gauge cluster?   Broken Gauge cluster? EmptyWed Sep 07, 2011 8:52 am
yeah mark gave me a whole cluster I guess ill have to try and check the fuses and contacts Ill let you know if I need anything Ill most likely be calling you soon to pick up that heater knob and ashtray if you have any left
PostSubject: Re: Broken Gauge cluster?   Broken Gauge cluster? EmptyWed Sep 07, 2011 9:19 am
Yea I got some for ya, the tray is blue but should work with some SEM paint
» Broken Gauge Cluster
» gas gauge stuck on full
» Temp Gauge Not Working....
» Water temp gauge Mechanical wher is a port I can use LT 1 Need some help
» Digital gauge
