 Broken Gauge Cluster
JW94SSLT1
PostSubject: Broken Gauge Cluster   Sun Mar 06, 2011 11:49 am
My digital display is not working I swapped it out with an other one but it still wont work any ideas on what might be wrong with it ?
PostSubject: Re: Broken Gauge Cluster   Sun Mar 06, 2011 1:37 pm
You probably just need to re-flow the solder on the back of the circuit board.
http://www.impalassforum.com/vBulletin/showthread.php?t=244052
JW94SSLT1
PostSubject: Broken Gauge Cluster   Sun Mar 06, 2011 1:50 pm
Thanks ill try that out
PostSubject: Re: Broken Gauge Cluster   Sun Mar 06, 2011 2:37 pm
I've got some spare clusters kicking around if you need parts.
I actually work in Windham/Club 302.
Let me know if i can help.
PostSubject: Re: Broken Gauge Cluster   Sun Mar 06, 2011 3:40 pm
This is probably gonna sound remedial but did you check the fuses and the wiring for any shorts/blown fuses? If you had a bad gauge and replaced it and its still not working, I would assume its probably a wiring problem. Also what kind of gauge did you replace it with, someone once said that a 9c gauge wouldn't work with a civi car because of the blackout option or something, idk as I never owned a 9c1. I'd pull every fuse just to look, also check the relays. Maybe just a pinched wire in the harness left connector B2 is the ign feed (pink wire) the ground is B3 (black) on the right connector the ign feed is located @ A5 (brown wire) and the ground is A6 (black and white) and also B4 (black). I'd start there!
JW94SSLT1
PostSubject: Broken Gauge Cluster   Sun Mar 06, 2011 3:50 pm
I looked real quick at the fuses but didn't take each one out and look at it but I'm going to just to be sure
PostSubject: Re: Broken Gauge Cluster   Sun Mar 06, 2011 3:55 pm
If its just the digital display out and all the guges work and idiot lights are ok then check the right side harness B2 its a yellow wire that's the one for the digital display.
JW94SSLT1
PostSubject: Broken Gauge Cluster   Sun Mar 06, 2011 4:52 pm
yeah everything works its just the digital display so ill have to check out that yellow wire thanks for your help!!
» Finally Did The 9C1 Cluster Swap
» Gauge upgrade
» Z28 Cluster Gauge Overlay - $45
» Camaro gauge for caprice/impala mod
» Help needed for Tender Locomotive 5" gauge Kit - Stolen Boiler
