Need to make my 1-2 shift faster EmptyWed Oct 19, 2022 1:27 pm by scot
Need to make my 1-2 shift faster EmptyTue Oct 18, 2022 8:58 pm by silverfox103
Need to make my 1-2 shift faster EmptyTue Sep 28, 2021 11:01 pm by silverfox103
Need to make my 1-2 shift faster EmptyFri Sep 24, 2021 9:53 am by ElKy
Need to make my 1-2 shift faster EmptySun Sep 19, 2021 6:22 pm by black blur 96
Need to make my 1-2 shift faster EmptySun Jun 20, 2021 11:37 am by scot
Need to make my 1-2 shift faster EmptyFri Jun 11, 2021 10:41 am by scot
Need to make my 1-2 shift faster EmptyWed Jun 09, 2021 9:41 pm by Chris Klein
Need to make my 1-2 shift faster EmptyWed Jun 02, 2021 9:02 pm by Chris Klein
4 posters
JRS9C1
JRS9C1
PostSubject: Need to make my 1-2 shift faster   Need to make my 1-2 shift faster EmptyMon Apr 25, 2011 9:33 pm
Right now 1-2 shift takes about 0.68 - 0.7 seconds and I'd like to see .3 taken off that time before drag day. What kit can I get that speeds up only 1-2 shift? 2-3, as well as 3-4 are quick enough and don't need any modification.
PostSubject: Re: Need to make my 1-2 shift faster   Need to make my 1-2 shift faster EmptyWed Apr 27, 2011 4:21 pm
If you already have a trans that has higher mileage on it, & has a long 1-2 shift you might be out of luck. If the band is already cooked your going to have a up-hill battle.
A shift-kit should help, as well as bringing up the line pressure (which can be achieved several ways), a trans flush is a good idea too. As far as servos go you need at least the Corvette servo.
JRS9C1
JRS9C1
PostSubject: Re: Need to make my 1-2 shift faster   Need to make my 1-2 shift faster EmptyWed Apr 27, 2011 4:33 pm
Al,
Trans has 119k on it, has increased line pressure through a tune. 4.11s help take the load off it a bit. 2-3 and 3-4 shift great but it's just my 1-2.
Car has the vette servo in it. I was just thinking of shimming the spring in the 1-2 accumulator to acheive a quicker shift. Ideally I'd like to have it done for drag day Arrow
PostSubject: Re: Need to make my 1-2 shift faster   Need to make my 1-2 shift faster EmptyWed Apr 27, 2011 5:08 pm
Replace the trans with one that doesn't have 120k.
PostSubject: Re: Need to make my 1-2 shift faster   Need to make my 1-2 shift faster EmptyWed Apr 27, 2011 7:26 pm
JRS9C1 wrote:
Al,
You can shim the accumulator, heck B&M shift kits remove the springs & you install sleeves so the piston does'nt move at all! The down side when you do that is part-throttle shifts, and down shifts are WAAY to hard. Makes the car suck to drive.
JRS9C1
JRS9C1
PostSubject: Re: Need to make my 1-2 shift faster   Need to make my 1-2 shift faster EmptyWed Apr 27, 2011 8:18 pm
Ok gotcha. So let me ask you this...does removing accumulation hurt the transmission/hard parts? Am I going to be damaging anything @ part throttle with accumulation deleted altogether? I think I remember reading it's simply put there in the first place so the customer has an 'enjoyable' shift.
PostSubject: Re: Need to make my 1-2 shift faster   Need to make my 1-2 shift faster EmptyThu Apr 28, 2011 1:14 pm
Faster gears? affraid
......... thats scary....... I seen what you did to the old mans tranny....... Razz
Need to make my 1-2 shift faster 03302111
OUCH!......
JRS9C1
JRS9C1
PostSubject: Re: Need to make my 1-2 shift faster   Need to make my 1-2 shift faster EmptyThu Apr 28, 2011 4:35 pm
Yup that was me...
» Does this make it go faster?
» So I sold my laptop to make my car go faster...LOL!
» any one ever use a b&m Shift Plus electronic Shift Improver?
» auto meter shift light
» shift issue
