 any one ever use a b&m Shift Plus electronic Shift Improver?
94classicss
PostSubject: any one ever use a b&m Shift Plus electronic Shift Improver?   Thu Mar 08, 2012 12:47 pm
i was replacing a fuse on my viper remote start/alarm and i saw a few wires wrapped around a box i had never noticed before so i pulled it down and followed the wires and theres another box with a 3 position switch under the little removable tray next to the ashtray took the numbers off of it and looked it up online its a B&M ShiftPlus electronic Shift Improver. Has anyone ever used one of these things? its seems to be a 50/50 online for reviews some say its great others blame it for trans problems....... thanks in advance
PostSubject: Re: any one ever use a b&m Shift Plus electronic Shift Improver?   Thu Mar 08, 2012 1:05 pm
Never seen one, but have to guess that all it's really doing in upping the line pressure. The same can be done with an ECM reprogram.
As far as hurting a trans, doubt it. Raising the line pressure will put more of a shock on the hard parts, but the clutches and band will live longer. I will also lower trans temps due to less slipping.
94classicss
PostSubject: Re: any one ever use a b&m Shift Plus electronic Shift Improver?   Thu Mar 08, 2012 2:32 pm
then i guess ill hook it back up and see if i can even tell the difference thanks
