» Hey Guys. Newbie diggin the site!
Today at 6:19 pm by boojum
Today at 4:50 pm by 1984twodoor
» CraigsList car finder
Today at 4:35 pm by 1984twodoor
» Wish I had the other 3 :-(
Today at 4:32 pm by 1984twodoor
» LS1Tech Member Builds 8.9L V12 LS Engine
Today at 4:30 pm by 1984twodoor
» digital speedometer question
Today at 2:34 pm by MASShole9C1
» 2.5" mufflers needed asap!
Today at 2:26 pm by toomanytoyz
» Digital cluster repair
Today at 2:15 pm by MASShole9C1
» Set of Z71 Tahoe wheels and tires
Today at 1:54 pm by sdstick
May 2013
Share | .
 Need to make my 1-2 shift faster
JRS9C1
PostSubject: Need to make my 1-2 shift faster   Mon Apr 25, 2011 2:33 pm
Right now 1-2 shift takes about 0.68 - 0.7 seconds and I'd like to see .3 taken off that time before drag day. What kit can I get that speeds up only 1-2 shift? 2-3, as well as 3-4 are quick enough and don't need any modification.
PostSubject: Re: Need to make my 1-2 shift faster   Wed Apr 27, 2011 9:21 am
If you already have a trans that has higher mileage on it, & has a long 1-2 shift you might be out of luck. If the band is already cooked your going to have a up-hill battle.
A shift-kit should help, as well as bringing up the line pressure (which can be achieved several ways), a trans flush is a good idea too. As far as servos go you need at least the Corvette servo.
JRS9C1
PostSubject: Re: Need to make my 1-2 shift faster   Wed Apr 27, 2011 9:33 am
Al,
Trans has 119k on it, has increased line pressure through a tune. 4.11s help take the load off it a bit. 2-3 and 3-4 shift great but it's just my 1-2.
Car has the vette servo in it. I was just thinking of shimming the spring in the 1-2 accumulator to acheive a quicker shift. Ideally I'd like to have it done for drag day Arrow
PostSubject: Re: Need to make my 1-2 shift faster   Wed Apr 27, 2011 10:08 am
Replace the trans with one that doesn't have 120k.
PostSubject: Re: Need to make my 1-2 shift faster   Wed Apr 27, 2011 12:26 pm
JRS9C1 wrote:
Al,
You can shim the accumulator, heck B&M shift kits remove the springs & you install sleeves so the piston does'nt move at all! The down side when you do that is part-throttle shifts, and down shifts are WAAY to hard. Makes the car suck to drive.
JRS9C1
PostSubject: Re: Need to make my 1-2 shift faster   Wed Apr 27, 2011 1:18 pm
Ok gotcha. So let me ask you this...does removing accumulation hurt the transmission/hard parts? Am I going to be damaging anything @ part throttle with accumulation deleted altogether? I think I remember reading it's simply put there in the first place so the customer has an 'enjoyable' shift.
PostSubject: Re: Need to make my 1-2 shift faster   Thu Apr 28, 2011 6:14 am
Faster gears? affraid
......... thats scary....... I seen what you did to the old mans tranny....... Razz
OUCH!......
JRS9C1
PostSubject: Re: Need to make my 1-2 shift faster   Thu Apr 28, 2011 9:35 am
Yup that was me...
» More gear to shift !
» How To make some changes.
» make me a mod
» how can make a gun for me?
» how to make a bonsai ?
