» Box body parts in east providence
Today at 11:07 am by MASShole9C1
» I Wanna Do Bad Things With You
Today at 8:49 am by boojum
» WTB air dam
Today at 7:49 am by MASShole9C1
» CraigsList car finder
Today at 7:14 am by Matt Trakker
» AAAAARRRGGGGHHHH!
Yesterday at 11:18 pm by toomanytoyz
» For JIM
Yesterday at 3:56 pm by boojum
» Lowering ideas??
Yesterday at 3:21 pm by MASShole9C1
» Project: Absinthe (The Green Goblin)
Yesterday at 3:15 pm by toomanytoyz
» Found my miss
Yesterday at 2:03 pm by MASShole9C1
May 2013
Share | .
 Steering box
PostSubject: Steering box   Tue Nov 02, 2010 10:51 am
I will be looking for a new steering box for my wagon soon. I read someplace that AGR is questionable at best, yet they seem to be the only people making a high performance 12:1 box I can find. What part number is the correct one for our cars from AGR?
Thank you
Bill
PostSubject: Re: Steering box   Tue Nov 02, 2010 11:16 am
That one I sent you go bad already?
1996 Impala SS - 44K original miles - 5.3 LS swap ALMOST DONE!
1996 Nissan Hardbody 2WD...LS powered project
PostSubject: Re: Steering box   Tue Nov 02, 2010 11:20 am
It was much better than the one in the car, but still had some play, and I have grown sick of it.
Certainly no reflection on you Doug. Arrow
PostSubject: Re: Steering box   Tue Nov 02, 2010 11:22 am
well, I'm kind of a sloppy guy... Razz
There are a few posts on the national forum about the aftermarket truck boxes or something like that, lots of good info from Navy Lifer if I recall.
PostSubject: Re: Steering box   Wed Nov 03, 2010 3:37 am
I have been searching over there, but have not found any truck stuff, and limited info on steering boxes in general.
PostSubject: Re: Steering box   Sun Nov 28, 2010 1:24 am
After much research hunting for a box for my 96 9C1, and messing around with these types of things for more years than I'd like to admit to, THIS is the box, if you are considering buying a new unit. I bought it from Mark here: . . . http://www.scandc.com/leesteering.htm . . . BTW, I bought the 670 12:1 @ $515.00 It is a better and lighter box according to the "best & brightest" advisors I've spoken to! Check it out if your looseness still bugz you.
Last edited by Machine-De-Zine on Thu Dec 02, 2010 3:06 am; edited 1 time in total
PostSubject: Re: Steering box   Sun Nov 28, 2010 1:32 am
Rumor has it, and I have done some measuring to make sure of it. The 92-98 Jeep Grand Cherokees all came with a 12.7:1 box. It is Identical as far as I can tell to the box found in the b-body. This means I can buy reman boxes for the jeep without fear of getting the wrong box. With the caprice/impala, there is no way of knowing until it is bolted up, and you turn the wheel.
I can get a reman steering box for under $130 through my work. With my discount, I pay about $100. Big savings over the AGR.
PostSubject: Re: Steering box   Sun Nov 28, 2010 9:33 am
After you clarify the requirements for the end result in descending order of priority, then you must locate the components that fulfill those criteria. For me, first is safety/reliability. A car containing my family, hurdling down the highway at legal speed, and ANY issues with the steering are a BIG deal. Second, what kind of performance expectation is there, and that's not just the desired ratio (assuming the RANGE of travel in degrees is correct, 82 deg. in our B-body I believe), and the effort required based on the installed torsion bar, not to mention the Buick "variable effort steering" option compatibility, OR, , , did the re-manufacturer's minimum wage employee simply pull one more carcass off of the bone-yard sourced "IN" pile just before lunch on friday & decide it looked too clean to merit hooking it up to the "test-bench" and so he just plops it into the ready for paint cage so that he can be first in line at Taco-Bell moments later! Hey man, welcome to the real world of "re-man"! Examine what you truly DO receive when you pay whatever you pay. I KNOW what I am getting from an establishment like Lee Performance Steering Boxes. Read the description of what they actually do in the preparation of your steering gear box! And the word "performance" for me means my family's safety has NOT been compromised by my choice in some component based upon cost savings. Thats not to say that your vehicle won't be safe with every other choice of steering box. A KNOWN GOOD steering system on my car definitely qualifies as sound insurance policy!
Last edited by Machine-De-Zine on Sun Nov 28, 2010 11:59 am; edited 1 time in total
JaySS
PostSubject: Re: Steering box   Sun Nov 28, 2010 10:53 am
58 posts in 12 days of membership. Hmm.
So far you’ve written some informative and well thought out posts.
It is fine to raise questions regarding the source of the remanufactured parts, and constructive criticism is always appreciated. But leave the axes to grind and the political discussion at the door. This is the Problems/Maintenance section.
- J
PostSubject: Re: Steering box   Sun Nov 28, 2010 11:43 am
- J
Might be going for Fred Kiehl's record! 2000 posts in less than a year (wagon site)
Tom C.
PostSubject: Re: Steering box   Sun Nov 28, 2010 12:21 pm
There is an easy way to determine what the ratio is for sure. I just take a couple cam degree wheels and mount them to the steering gear shafts lock it in a vise and rotate. You will learn the actual lock to lock range at the sector shaft, the lock to lock range for the steering wheel as well as the true ratio. This will not tell you the effort of the box because that is determined by the input torsion bar inside - Thicker bar means higher effort. . . . http://www.carcraft.com/techarticles/ccrp_0901_gm_steering_box_upgrade/power_steering.html
Steering box
» Need a Steering box
» 91-93 vs 94-96 Caprice Steering Wheel
» Steering box
» PIPE CLAMPS AND STEERING CHAINS
