 Steering column help
PostSubject: Steering column help   Mon Jul 08, 2013 11:01 pm
Since I have ZERO headlights now, and my car will be stuck at work until sunrise, I started taking the plastic covers off the turn signal area.
Once off, a strange looking plastic piece looked as if we're floating around inside, but wasn't hooked up to anything. It came right out.
There's a rod there that bends and goes into the underside of the column. Not sure what that goes to.
Also, it looks like there's 2 contacts underneath. 1 possibly engaged by the stalk lever, which is now inop. The contact is pushed all the way in and I can't get it out.
Any help with how this all functions and goes back together?
PostSubject: Re: Steering column help   Mon Jul 08, 2013 11:08 pm
sounds like your dimmer switch rod,..
nick
PostSubject: Re: Steering column help   Mon Jul 08, 2013 11:49 pm
You're probably right, Nick.
Any idea how all of it goes back together?
I'm not 100% on it as it looked like that plastic piece is rather broken or was out of place to begin with.
PostSubject: Re: Steering column help   Tue Jul 09, 2013 7:57 am
This might help, more than you'll ever need to know about a saginaw column:
http://www.crankshaftcoalition.com/wiki/images/d/d6/Jazzman_Steering_Rack_Rebuild.pdf
bladerunner
PostSubject: Re: Steering column help   Tue Jul 09, 2013 9:20 am
Wow, I wish I had that guide last year when I attempted to rebuild my sloppy column! My results were less than optimal and I just ended up buying a rebuild column instead.
PostSubject: Re: Steering column help   Tue Jul 09, 2013 12:26 pm
Thanks Dave!! That looks like what I'm in need of.
PostSubject: Re: Steering column help   Tue Jul 09, 2013 12:58 pm
Hope it helps, it was a life saver when I tore apart my Caddy's column. Once that high beam switch falls out it's hard to figure out where those pieces go.
PostSubject: Re: Steering column help   Tue Jul 09, 2013 3:35 pm
Yes, thanks, thats hard core info right there.
I might start fixing problems instead of throwing them in a pile...Razz
