| Subject: Redrilling wheels Fri Oct 29, 2010 7:43 pm | |
| Redrilling wheels.. anyone know of a local place capable of this? thanks | |
| Subject: Re: Redrilling wheels Fri Oct 29, 2010 8:32 pm | |
| - laidlow91 wrote:
- Redrilling wheels..
anyone know of a local place capable of this? thanks Use an old rotor as a guide,.knock the studs out,. or cut the flange off an old axle shaft,.knck the studs out,.as long as the wheel is HUBcentric not STUDcentric,. Nick | |
| Subject: Re: Redrilling wheels Fri Oct 29, 2010 10:42 pm | |
| rimpro.com is a company used by most dealerships....... located in Tewksbury Mass (978) 851-6080...... they pick up and drop off ...... get a quote and monday i can call from the shop and see if the dealership gets it cheaper... | |
| Subject: Re: Redrilling wheels Mon Nov 01, 2010 12:45 pm | |
- bowtiepimp wrote:
- rimpro.com is a company used by most dealerships....... located in Tewksbury Mass (978) 851-6080...... they pick up and drop off
...... get a quote and monday i can call from the shop and see if the dealership gets it cheaper... Nick and Chris, thanks for the suggestions. ive decided to scrap the wheel idea i had and move on. - 96Brougham wrote:
What are you doin with the Wires Paul, they will be for sale minus the tires before spring,CHEAP. | |
| Subject: Re: Redrilling wheels Mon Nov 01, 2010 12:57 pm | |
| Put me in line first for the wheels I work at a tire shop so I don't need tires!(I can get them super cheap!) | |
| Subject: Re: Redrilling wheels Mon Nov 01, 2010 5:59 pm | |
| 18 inch wires with tires ..... $500 ...... if interested | |
| Subject: Re: Redrilling wheels | |
