| 94 pontiac b-body. What if? | |
+3GasTT toomanytoyz 1984twodoor 7 posters |
| Subject: 94 pontiac b-body. What if? Thu Oct 28, 2010 8:57 pm | |
| Thoughts |
| Subject: Re: 94 pontiac b-body. What if? Thu Oct 28, 2010 8:58 pm | |
| DO IT! Then Bonnies would make SOOOO much more sense lol | |
| Subject: Re: 94 pontiac b-body. What if? Thu Oct 28, 2010 9:39 pm | |
- Thoughts
That you need more photoshop practice. | |
| Subject: Re: 94 pontiac b-body. What if? Thu Oct 28, 2010 9:40 pm | |
- Thoughts
That you need more photoshop practice. I am not that high tech. I used windows "paint" |
| Subject: Re: 94 pontiac b-body. What if? Thu Oct 28, 2010 9:45 pm | |
- Thoughts
That you need more photoshop practice. I am not that high tech. I used windows "paint" Oh. Then you did a hell of a job. Nice work. | |
| Subject: Re: 94 pontiac b-body. What if? Thu Oct 28, 2010 9:49 pm | |
| Doesn't look like the CC grill agrees with that. Would be much easer using a Caprice grill. | |
| Subject: Re: 94 pontiac b-body. What if? Thu Oct 28, 2010 10:12 pm | |
Too easy. I have always wondered what one would look like had gm continued the pontiac into the last bodystyle. I bet it would have had a unique front facia with fog lights and some cladding similar to the OCC. Maybe a Can-am hipo option. |
| Subject: Re: 94 pontiac b-body. What if? Thu Oct 28, 2010 10:45 pm | |
- Too easy. I have always wondered what one would look like had gm continued the pontiac into the last bodystyle. I bet it would have had a unique front facia with fog lights and some cladding similar to the OCC. Maybe a Can-am hipo option.
You should get a grille shell and use some honeycomb material and the split grille "beak". Either way Chrome doesn't seem to fit the 90's pontiac feel. Maybe there would be a way to adapt a bonnie grill onto that shell or to fit a caprice? Or a grille from any Pontiac that's large enough to adapt? But if you use the stock chrome grilles the side have to be blacked out. I think your idea of what they would have/should have done is perfect though. Trim would be a bare minimum and the could either use a pontiac style wheel or an ss wheel with a center cap. 17inch rally II wheels would work for me if I was doing it Many possibilities, if you do it, good luck | |
| Subject: Re: 94 pontiac b-body. What if? Thu Oct 28, 2010 10:55 pm | |
- Thoughts
That you need more photoshop practice. I am not that high tech. I used windows "paint" Maybe someone that has taken a computers class could give you a few pointers? Fix the headlights while you're at it! | |
| Subject: Re: 94 pontiac b-body. What if? Thu Oct 28, 2010 11:00 pm | |
| Subject: Re: 94 pontiac b-body. What if? Thu Oct 28, 2010 11:25 pm | |
| cut it up and have it fit in the shell that Anthony used before he switched to roadmaster front end metal. I know...lamest pontiac ever, but it seems like it could fit with modifications. | |
LiveFreeorDieTryin
| Subject: Re: 94 pontiac b-body. What if? Thu Oct 28, 2010 11:30 pm | |
| modified impala grille? | |
| Subject: Re: 94 pontiac b-body. What if? Fri Oct 29, 2010 10:03 am | |
| - LiveFreeorDieTryin wrote:
- modified impala grille?
A aftermarket ss grill could be used to duplicate this. I might try this down the road. |
| Subject: Re: 94 pontiac b-body. What if? Fri Oct 29, 2010 10:36 am | |
| You need to get a hobby, way to much time on your hands. | |
| Subject: Re: 94 pontiac b-body. What if? Fri Oct 29, 2010 10:44 am | |
| - No Moa wrote:
- You need to get a hobby, way to much time on your hands.
I will look into it. |
| Subject: Re: 94 pontiac b-body. What if? Fri Oct 29, 2010 12:16 pm | |
- Thoughts
That you need more photoshop practice. I am not that high tech. I used windows "paint" Maybe someone that has taken a computers class could give you a few pointers? Was that easier then typing ........ - Cadet57 wrote:
- "Computer technology and certifications 2" or something like that.
Well Bill, when you have your idea all figured, show up at my shop & we'll make it out of aluminum & fit it to the B shell (& bring your welder so while you wait you can fix Matts rear 1/4's & rockers..... ) | |
| Subject: Re: 94 pontiac b-body. What if? Fri Oct 29, 2010 1:22 pm | |
A aftermarket ss grill could be used to duplicate this. I might try this down the road. i like this idea. | |
| Subject: Re: 94 pontiac b-body. What if? | |
