Did some work on the car last week thought I'd share a few tips for wiper removal and repair.What happened was the tip of the hose coming out of the wiper cowl had broken and I got 1 from No moa.Installed it 2 weeks ago and tried to put the hose on it and it would'nt reach I realized i had installed it wrong.
#1 Remove wiper blades .Easier to move the arms with them off.
#2 Pry off the plastic covers over the wiper arm bolts.They will break !
#3 Lift up on the wiper arm and install *PIN or nail in the hole in the side of arm.
*Don't know the size guess you'll have to guesstimate.I installed new OEM arms
and they came with new pins.
#4 remove the nut
I'll check later for the size.
#5 wiggle the arm .It should pop right off.
