BRAke power  booster!!! EmptyWed Oct 19, 2022 1:27 pm by scot
BRAke power  booster!!! EmptyTue Oct 18, 2022 8:58 pm by silverfox103
BRAke power  booster!!! EmptyTue Sep 28, 2021 11:01 pm by silverfox103
BRAke power  booster!!! EmptyFri Sep 24, 2021 9:53 am by ElKy
BRAke power  booster!!! EmptySun Sep 19, 2021 6:22 pm by black blur 96
BRAke power  booster!!! EmptySun Jun 20, 2021 11:37 am by scot
BRAke power  booster!!! EmptyFri Jun 11, 2021 10:41 am by scot
BRAke power  booster!!! EmptyWed Jun 09, 2021 9:41 pm by Chris Klein
BRAke power  booster!!! EmptyWed Jun 02, 2021 9:02 pm by Chris Klein
3 posters
PostSubject: BRAke power booster!!!   BRAke power  booster!!! EmptySat Mar 21, 2009 11:42 pm
i think im in need of one.. got my master cylinder changed about a 1month and soome change ago.
when driving I hear like air going through up front then when i appply brakes it stops by kind of spongy
could it be the brake booster? scratch
PostSubject: Re: BRAke power booster!!!   BRAke power  booster!!! EmptySat Mar 21, 2009 11:59 pm
You have to bleed the brakes. There's most likely air in the lines from the last brake work you did, or from a blown line.
UberWagon
PostSubject: Re: BRAke power booster!!!   BRAke power  booster!!! EmptySun Mar 22, 2009 11:58 am
If there is a problem with the power booster for the brakes you should have issues with idle when you are braking.
Most engines do not like having that large of a vacuum leak and will begin to idle poorly or die when there is a problem with the booster. Usually a sign of the booster going out is the brakes are harder to push, as there is less assistance from the booster.
I found the easiest way to bleed the brakes on my car is with it running, this way the ABS pump has power and is functioning while you are bleeding it, you said you replaced your master cylinder. If a master cylinder is not bench bled properly prior to installing it, there will be a lot of air forced through the entire system making it soft.
PostSubject: Re: BRAke power booster!!!   BRAke power  booster!!! EmptySun Mar 22, 2009 12:31 pm
alright koo ill have it checked out 2morrow
thanx ya'll
» Power brake booster
» Brake questions
» Octane booster or premium unleaded?
» OTC Brake Rotors
» Need brake part
