Ok guys....heres your chance to jump on a good deal!
I have a complete running package from a 2003 GMC Savanna Van that supposedly had 40k miles on it.
This package includes 5.3L Vortec (ls1 based engine), which is roughly equivelant to the modern day 327. The engine is complete from intake to pan, minus the accessory brackets. It has the truck intake, fuel injectors, throttle body (drive by wire), coil packs and oem plug wires, truck oil pan (6.5qt vs the 5.5 car pan), and it has the 706 casting aluminum heads. Also included is the alternator, water pump and starter, but NO brackets. Transmission is a 4L60E 2wd unit that I had listed as well seperatley before. Flexplate is still on the engine, and convertor is in the transmission. OEM truck exhaust manifolds are also included (non air injection style).
I currently have one cylinder head off for inspection (also to prove that the engine is in fact a 5.3. 4.8's have flat top pistons, while cast iron 5.3 blocks have dished pistons).
This is everything you will need minus the computer/ harness.
I am asking 800.00 for the package! This is a steal at this price. This would be a perfect transplant for some boost, and there is plenty of documentation of these motors making HUGE power on stock bottom ends.
again, 800 PICKED UP
No delivery.
Motor is the one on the right. Pics of the trans are in the other post here in the classifieds.
