Just dropping the front an inch or two? EmptyWed Oct 19, 2022 1:27 pm by scot
Just dropping the front an inch or two? EmptyTue Oct 18, 2022 8:58 pm by silverfox103
Just dropping the front an inch or two? EmptyTue Sep 28, 2021 11:01 pm by silverfox103
Just dropping the front an inch or two? EmptyFri Sep 24, 2021 9:53 am by ElKy
Just dropping the front an inch or two? EmptySun Sep 19, 2021 6:22 pm by black blur 96
Just dropping the front an inch or two? EmptySun Jun 20, 2021 11:37 am by scot
Just dropping the front an inch or two? EmptyFri Jun 11, 2021 10:41 am by scot
Just dropping the front an inch or two? EmptyWed Jun 09, 2021 9:41 pm by Chris Klein
Just dropping the front an inch or two? EmptyWed Jun 02, 2021 9:02 pm by Chris Klein
UberWagon
JRS9C1
9 posters
JRS9C1
JRS9C1
PostSubject: Just dropping the front an inch or two?   Just dropping the front an inch or two? EmptyWed Mar 11, 2009 10:00 pm
If this is dumb, tell me now! I want a mild "rake" - could I just go with two front springs to bring the front down a little? The gap between the tire and fender is driving me nuts! If this is not the way to go, let me know what else I should do. I love the level the back end is at right now so I would like to leave it.
I want the front to have a gap exactly the same as this SS! How much of a drop would that be?
Just dropping the front an inch or two? P1020110
Thanks! Cool
PostSubject: Re: Just dropping the front an inch or two?   Just dropping the front an inch or two? EmptyWed Mar 11, 2009 10:25 pm
Try a set of 9C1 springs with 1 to 1.5 coils cut. Should put you where you want to be. I'm sure you can find a set of those springs for free somewhere. Smile
PostSubject: Re: Just dropping the front an inch or two?   Just dropping the front an inch or two? EmptyThu Mar 12, 2009 10:47 am
Find someone parting out an SS and get the front springs from them. I hate cutting springs since it changes the characteristics of the spring. Better off finding some that are already at the hight you want.
Just don't use dramatic tire sizes to provide a rake since it'll screw up your abs function.
UberWagon
PostSubject: Re: Just dropping the front an inch or two?   Just dropping the front an inch or two? EmptyThu Mar 12, 2009 11:28 am
If you do cut the springs be sure to add different shocks. The ride of the car is determined more by the shocks then people think. Any of the performance/regular replacement shocks for the Impala SS will fit an function fine on your Roadmaster sedan.
While I didn't get to drive my car very far or very fast after the H&R springs were installed. I also added Edeldbrock IAS front shocks and Bilstien rear shocks, and that made all the difference on the world. The cushy bouncy ride was gone, the car rebounded only once but not harshly over bumps. I was so looking forward to giving it a nice long drive through some twisty roads but the poor little 305 had different ideas and decided to spin a bearing on the maiden trip after the install.
Why do my cars always break when I am just leisurely driving them? I have yet to break a car while I have been beating on it, go figure.
JRS9C1
JRS9C1
PostSubject: Re: Just dropping the front an inch or two?   Just dropping the front an inch or two? EmptyThu Mar 12, 2009 5:20 pm
Will SS springs give me the kind of drop I want? The gap between the tire and the fender seems to get bigger everyday scratch lol!
I would like at least 2 inches gone. What aftermarket springs would do the job?
PostSubject: Re: Just dropping the front an inch or two?   Just dropping the front an inch or two? EmptyThu Mar 12, 2009 5:26 pm
Vogtland springs ftw.....
SS springs in the front will definitely drop two inches off a RMS spring. If that RMS spring is sagging, the different will be less.
JRS9C1
JRS9C1
PostSubject: Re: Just dropping the front an inch or two?   Just dropping the front an inch or two? EmptyThu Mar 12, 2009 5:43 pm
^^^ The gap is big enough for me to believe they were replaced quite recently before I bought it. It has the gran touring suspension and is bouncy and rides like a cloud.
Just dropping the front an inch or two? Photo_10
What is that, like a 9 inch gap?!?! Shocked It's driving me crazy!
PostSubject: Re: Just dropping the front an inch or two?   Just dropping the front an inch or two? EmptyThu Mar 12, 2009 5:54 pm
If I was you, I would find a set used of ss springs, or Bill's idea of cutting one coil off a set of 9c1 springs. After this weekend, I may have a set of ss springs with 80k on them for sale. Just have to see if mine are sitting correctly in the lower pockets. If they are not and need adjustment, or are upside down, I will not need my extra set. If I find they are sitting correctly and I still have the gap I do now, I will need to change them out.
And get a set of Monroe Severe Service shocks. This with the ss springs will give a lower stance and ride firm, but not harsh.
JRS9C1
JRS9C1
PostSubject: Re: Just dropping the front an inch or two?   Just dropping the front an inch or two? EmptyThu Mar 12, 2009 6:11 pm
How will the ride be if I keep the stock shocks in?
PostSubject: Re: Just dropping the front an inch or two?   Just dropping the front an inch or two? EmptyThu Mar 12, 2009 6:29 pm
The problem with the fronts, is getting them off. I usually have to brake them to get them out. If you can get them out without damage go for it. But you are not going to feel the full affect of the springs till you get a firmer than stock shock under there. It will sit lower, but still may be floaty.
JRS9C1
JRS9C1
PostSubject: Re: Just dropping the front an inch or two?   Just dropping the front an inch or two? EmptyThu Mar 12, 2009 6:46 pm
How much are the shocks for the front? Anyone got a link?
PostSubject: Re: Just dropping the front an inch or two?   Just dropping the front an inch or two? EmptyThu Mar 12, 2009 6:51 pm
shox.com has the best deal on Bilsteins.
JRS9C1
JRS9C1
PostSubject: Re: Just dropping the front an inch or two?   Just dropping the front an inch or two? EmptyThu Mar 12, 2009 7:00 pm
$309 for bilsteins (set of four) Shocked Should I just replace all four or is it an option to do just two?
PostSubject: Re: Just dropping the front an inch or two?   Just dropping the front an inch or two? EmptyThu Mar 12, 2009 7:49 pm
Hey, I'd run the cut springs. Nothing wrong with it. It may increase the rate just a bit, but who cares? I don't think the SS springs will give you the drop you are after. I'd also go with the Gabriel HD shocks for 20 bucks a piece with a lifetime warranty from Autozone. Dropped and firmed up for 40 bucks?
But hey... that's just me. Wink
JRS9C1
JRS9C1
PostSubject: Re: Just dropping the front an inch or two?   Just dropping the front an inch or two? EmptyThu Mar 12, 2009 7:59 pm
I am thinking about cutting them just to be cheap - but I don't know how No
PostSubject: Re: Just dropping the front an inch or two?   Just dropping the front an inch or two? EmptyThu Mar 12, 2009 8:09 pm
jus wait for mod day im sure someone will help ya !!!!!!!!
PostSubject: Re: Just dropping the front an inch or two?   Just dropping the front an inch or two? EmptyThu Mar 12, 2009 9:01 pm
Don't cut your stockers Tom
You want to cut 9c1 springs.
Starting with the side that sits in the lower A-arm pocket. Just look at the very end of the coil, and cut straight down to the coil below. This will remove one coil.
If still in doubt, like Rich said, wait for mod day.
PostSubject: Re: Just dropping the front an inch or two?   Just dropping the front an inch or two? EmptyThu Mar 12, 2009 9:09 pm
Definately!!! Do NOT cut those mushy crap stockers!!! Cut 9C1 springs. Smile
JRS9C1
JRS9C1
PostSubject: Re: Just dropping the front an inch or two?   Just dropping the front an inch or two? EmptyThu Mar 12, 2009 10:19 pm
No I'm not cutting the stock springs - Maybe SR has some 9C1 springs around here...
hooptycaprice
hooptycaprice
PostSubject: Re: Just dropping the front an inch or two?   Just dropping the front an inch or two? EmptyFri Mar 13, 2009 9:15 pm
Here is my Caprice with hotchkis springs and stock wheels. It gave a nice rake, which i wasn't looking for. I have more pictures, I just can't find them at the moment.
[img]Just dropping the front an inch or two? 20[/img]
PostSubject: Re: Just dropping the front an inch or two?   Just dropping the front an inch or two? EmptyFri Mar 13, 2009 9:50 pm
btw my caprice always seemed to have a low front rake to it,never thought much of it until i got got the 17" 55 series tires on it, then i noticed the air dam would scrap my dirt driveway, driveway is at a good angle to the sideway,took a shovel to that (i rent so i cant do to much)i was going to drop it 2" until i seen how much clearance i had with the stillen front bumper to the sidewalk ,which i couldnt slide my hand between the 2, yeah its that close,if i went with 45 series tires, it would of never worked.. so im guess im saying is think about the areas u drive around in etc
hooptycaprice
hooptycaprice
PostSubject: Re: Just dropping the front an inch or two?   Just dropping the front an inch or two? EmptyFri Mar 13, 2009 10:16 pm
I agree with wayne. Thats why I took them out. I would scrape the air dam going into 80% of all driveways. Then I took the air dam off, which made the car look like crap. I had enough and just returned it back to stock and sold the 20" wheels I had on it.
PostSubject: Re: Just dropping the front an inch or two?   Just dropping the front an inch or two? EmptyFri Mar 13, 2009 11:12 pm
Look at this rake with stock suspension. My old 91 I had a few months back.
Just dropping the front an inch or two? 31124950007_large
PostSubject: Re: Just dropping the front an inch or two?   Just dropping the front an inch or two? EmptySat Mar 14, 2009 8:07 am
With any lowered car you have to be more aware of your surroundings and be more careful pulling into driveways and parking lots and over speed bumps... Small trade-off AFAIC. Smile I think any lower than 2" from stock SS height will be tough to drive around on, as you will find most shallow inclines to be "too steep." Lower than that, go with air. Smile
PostSubject: Re: Just dropping the front an inch or two?   Just dropping the front an inch or two? EmptySat Mar 14, 2009 8:58 am
yep gastt ,the same,nice memory , the same color as mine was b4 i painted it dcm
» WTB Front UCA shafts
» WTB Front 9C1 Calipers
» PPM front end rebuild kit
»  Should I put the SS front springs in my 94 9C1?
» need front springs..
