| Author | Message |
ginnamo96
Posts: 6 Join date: 2010-05-20
 | Subject: Running Lean Fri May 28, 2010 4:14 am | |
| I just installed CIA tri y gen II headers with no cats, RAISS intake with a 3.5 MAF and I can not figure out why I am running lean. I am running lean from both banks so I have searched and searched for vacuum leaks found one on a hose that goes from the front of the intake to the drivers side fixed that and light still came on. I had the PCM programed by PCMFORLESS and they insist it wasnt from them they say they do a ton of tunes like that. I was wondering if anyone has had problems with them or if I would need a tune with that few mods? I plan on checking the fuel pressure when i get a chance to grab a gauge but was hoping I could get more ideas of how to fix this on here. Thanks |
Posts: 651 Join date: 2009-02-12 Age: 66 Location: south portland maine
 | Subject: Running Lean Fri May 28, 2010 7:36 am | |
| ive used both alex at (PCMperformance) and brian (PCMFORLESS) there both excellent. ive had no problems with either one. im sending my spare to be reflashed to brian. because hes worked on it once. so i wont to have to pay for a complete rework. was it running lean before you did all the work? when the guys get off work later today. there help you a lot more then me. im(guessing)  only its a sensor. keep us posted. ron. |
 | Subject: Re: Running Lean Fri May 28, 2010 8:53 am | |
| Any chance you can put your old tune in to see if it runs normal again? Odds are very good that it could be Brian's work...  _________________ Bill "The Verb" Crovo - Resident Car Slut 04 CTS-V -The Big Bad Wolf- 500RWHP, Maggie, Kook's, Magnaflow, etc... 95 White WB4 "GS" -The Marshmallow- Lotsa stuff done, lots more to come... 00 Sierra 2500 ECSB -The Big Slut- H2's & 33's, TB crank, CAI, Magnaflow, Cowl'd, etc... 94 Miata- Project Cone Killer- Manual everything. No cone is safe. No more Subarus. Ever. EVAR! American Ricerwww.badassofne.net "Ooooh! Look! Something shiny!" |
 | Subject: Re: Running Lean Fri May 28, 2010 9:19 am | |
| If you open up the breathing as much as you did then you need to get the fuel tables tuned for all of that. That would suggest it's not tuned quite right. At the same time if one of the sensors in the intake or an o2 sensor isn't hooked up right then that would cause the same issue. I'd check the o2's first and make sure they're connected well and there's nothing burnt up in the wiring. Then I'd check the intake sensors (iat, maf, etc) and make sure they're all plugged in and functioning. Then I'd check again for leaks using the carb cleaner method. Finally I'd look into the tune. Don't get too frustrated. It's easier to solve these sort of problems with a detective mentality as opposed to being a raging nutcase. I speak from experience  |
ginnamo96
 | Subject: Re: Running Lean Fri May 28, 2010 4:49 pm | |
| It wasnt running lean before i did all this work. and I can not put in the old tune cause i sent mine out then they sent it back. PCMFORLESS said it was definetly caused by the breather filter i put in so i reconnected the tube to throttle body but that didnt work
I will go threw everything again tomorow cause i got plenty of time
I searched the code it is throwing and i found something were someone said in rare cases it can be thrown by a unseated dipstick which i would have never thought of cause i didnt realize that that could bring in air but mine is definetly unseated cause after the headers were in i couldnt get it all the way in so i just left it barelly in so i will find a way to get that all the way in but id be suprised if thats it!! has anyone heard of that causing a lean code??? |
 | Subject: Re: Running Lean Fri May 28, 2010 5:55 pm | |
| I've heard of weirder issues than that. If the dipstick isn't in place then air can be sucked into the crankcase which could then over pressurize the pcv and pump a stronger stream of vapor into the intake. Remember that the pcv system enters after the maf so the system can't compinsate for the increase in airflow since it doesn't see an increase at the maf. Hence a lean condition would be picked up at the plugs and at the o2's while the maf reads everything being normal. The question is why would your engine be pulling that much vacuum through the crankcase  |
Waldo617
Posts: 194 Join date: 2010-03-20 Age: 24 Location: Milton
 | Subject: Re: Running Lean Sat May 29, 2010 6:06 am | |
| if your not running cats then you need to get the PCM reprogrammed at a high performance shop |
ginnamo96
 | Subject: Re: Running Lean Wed Jun 02, 2010 6:37 am | |
| i checked everything and called pcmforless and finally got them to check the tune they did on the pcm and they realized they didnt tune it for the fbody maf which wasnt to big of a suprise to me! thanks for the suggestions tho |
 | Subject: running Lean Wed Jun 02, 2010 6:58 am | |
| is the problem solved? if thats what it was. im not going to send my spare to them. no matter if i lose some money. it will go to alex. like the one in the car now. thanks for letting us know. |
 | Subject: Re: Running Lean Wed Jun 02, 2010 7:49 am | |
| Where are you located? Doesnt matter unless you ask for hands on help Sometimes its easier then cybertroubleshooting Unless your wanted or something?  |
ginnamo96
 | Subject: Re: Running Lean Wed Jun 02, 2010 9:25 am | |
| i just sent it out today so i should have it by mid next week and they said they did not tune it for the bigger MAF which clearly was stated in the form i filled out so they just didnt look at the form closely. so thats definetly what threw the code but i will have it in next week then i will be 100% sure i will let u know when i put it in. lean was the only codes that were coming up so they did tune it correctly for the air egr and cats removal |
ginnamo96
 | Subject: Re: Running Lean Fri Jun 11, 2010 8:55 am | |
| still running lean they definetly didnt program it correctly the first time for the maf they said they missed that in the first tune! |
Posts: 655 Join date: 2009-02-25 Age: 54 Location: Nashua NH.
 | Subject: Re: Running Lean Fri Jun 11, 2010 9:16 am | |
| what is your fuel pressure ? you need about 43.5 lb with the vacuum line to fuel pressure regulator pluged |
 | Subject: Re: Running Lean Fri Jun 11, 2010 10:00 am | |
| I am going to stick my nose in and say you have too much air coming in, and not enough fuel to match. The 3.5 maf is probably the culprit I have been using PCMperformance.com since they started and all three of my tunes have been spot on for what I asked for. I have never read anything negative about their work. But I have read that pcmforless has had more than it's share of bad tunes as of late for some reason. |
ginnamo96
 | Subject: Re: Running Lean Tue Jun 15, 2010 5:01 am | |
| my fuel pressure is far to low changed fuel filter jumped up a bit to 38-39 light takes longer to come on now but still comes on when remove the vacuum line it jumps to about 42ish. im not to familiar with this but cause its only at 42 with the vacuum off means it would be the pump and not the regulator correct? i have a freeze frame scaner and the light always seems to come on at very low rpms |
