So I got the SS running today! EmptyWed Oct 19, 2022 1:27 pm by scot
So I got the SS running today! EmptyTue Oct 18, 2022 8:58 pm by silverfox103
So I got the SS running today! EmptyTue Sep 28, 2021 11:01 pm by silverfox103
So I got the SS running today! EmptyFri Sep 24, 2021 9:53 am by ElKy
So I got the SS running today! EmptySun Sep 19, 2021 6:22 pm by black blur 96
So I got the SS running today! EmptySun Jun 20, 2021 11:37 am by scot
So I got the SS running today! EmptyFri Jun 11, 2021 10:41 am by scot
So I got the SS running today! EmptyWed Jun 09, 2021 9:41 pm by Chris Klein
So I got the SS running today! EmptyWed Jun 02, 2021 9:02 pm by Chris Klein
druzdcm
LandMaster
onehunglo
10 posters
PostSubject: So I got the SS running today!   So I got the SS running today! EmptySun Mar 28, 2010 9:46 pm
It was a short lived run, but she DID RUN TODAY!!!!! Very Happy
WOOOOOO HOOOOOOO!!!!!
I'm getting there. Wink
I finally finished installing the new plugs and wires and got the passenger header back on. I also swapped out the hub and harmonic balancer with an SFI one. Got it all back together, hooked up the battery, cranked it up and she fired right up! It did seem to still have a stumble off idle, but did not seem to be popping through the intake anymore. But I only ran it for like a minute and a half because I couldn't hook the pass header up to the exhaust system. Somehow the pipe is a 1/2" too far forward now and I can't get it to clear the header flange without an assist... Grrrr... Always something! But at least she's running again!!! Very Happy
Once I get the pipe hooked up I plan to relash the valves and replace the MAF with another used one I just got and cross my fingers that that fixes it! I sure do miss driving it! If it doesn't, I may just have to give up and bring it to my mechanic. Finding time to work on it myself has proven to be very difficult!
onehunglo
onehunglo
PostSubject: Re: So I got the SS running today!   So I got the SS running today! EmptySun Mar 28, 2010 10:15 pm
Sweet! Very Happy
LandMaster
LandMaster
PostSubject: Re: So I got the SS running today!   So I got the SS running today! EmptySun Mar 28, 2010 10:23 pm
HIGH FIVE!
PostSubject: Re: So I got the SS running today!   So I got the SS running today! EmptySun Mar 28, 2010 10:25 pm
Have you ruled out the opti at this point or is that still a possibility?
druzdcm
druzdcm
PostSubject: Re: So I got the SS running today!   So I got the SS running today! EmptyMon Mar 29, 2010 6:39 am
I know Bill-I had a now trusted shop weld my catback(it's been clamped) and told them to toss my tubular Xmember on while it was on the lift.
It was a good ride home with my boy and I noticed a coolant leak on the drivers side...after looking/feeling it is the rear(#7) cylinder bolt that the head is to the block. I am sure this was also caused by the same cylinder's last header bolt completely backed out. I need gaskets, bolt(s), and a TIME!
I am starting to work a busier season both hours or work so working on this crap ends up put off for a weekend but I have to before this weekend.
Have to loosen header to acess bolts across the bottom so that adds to the fun No
PostSubject: Re: So I got the SS running today!   So I got the SS running today! EmptyMon Mar 29, 2010 4:20 pm
I'm on my second "known good" opti that replaced the brandy new 5K miler that was in there when this started. So yeah, pretty sure it's not the opti.
I just need some more time to hook up the exhaust and then see how it runs. It may be better. It may not be, too. At this point, I am unsure. Smile
PostSubject: Re: So I got the SS running today!   So I got the SS running today! EmptyMon Mar 29, 2010 6:26 pm
I'm trying to work off of memory here so I might be a bit sketchy. If it's one cylinder not firing and you know it's not the opti/wire/plug then it would have to be an issue with the fuel injector on that cylinder. If things don't get cleared up try swapping the injectors and see if the issue moves. If not then look very closely at the wiring for that specific cylinders injector and see if there's a bad spot in it or something.
Like how I give you advice as if you know nothing about cars Laughing
Just trying to run through some of the easier diagnostic stuff since it's as far as my knowledge can go Wink
druzdcm
druzdcm
PostSubject: Re: So I got the SS running today!   So I got the SS running today! EmptyMon Mar 29, 2010 7:02 pm
Sorry, I was not trying to jack your thread Bill Surprised
what plugs are you running for your engine?
My setup seems similar and Chad said Autolite 103s for mine.
Last edited by druzdcm on Mon Mar 29, 2010 7:47 pm; edited 1 time in total (Reason for editing : less text)
PostSubject: Re: So I got the SS running today!   So I got the SS running today! EmptyMon Mar 29, 2010 7:10 pm
Get the For Sale sign ready!
druzdcm
druzdcm
PostSubject: Re: So I got the SS running today!   So I got the SS running today! EmptyMon Mar 29, 2010 7:13 pm
Me-or Bill?
It had (has?) a roaming misfire (changes cylinders randomly) and a bad stumble and would pop/backfire through the intake. If it made it past 3 grand, it'd rev to the moon fine. Also killed two new batteries (so flat they wouldn't take a charge) over the course of 5 months. Good vacuum. Good fuel pressure. No codes. All grounds good. No burnt wires or evidence of burnt harness or anything anywhere. Valvetrain is quiet. Replaced every sensor with the motor swap. 3 optis. 3 opti harnesses. 2 brand new coils and a known good. 3 icm's. on it's 2nd pcm. 2nd F-MAF. New Bosch platinums and 2nd set of new wires (stock Duralasts this time) just installed this weekend. Installed a new hub and SFI harmonic balancer this weekend too.
My last ditch effort will be to relash the valves if the troubles is still there after I get the exhaust hooked up.
PostSubject: Re: So I got the SS running today!   So I got the SS running today! EmptyMon Mar 29, 2010 7:17 pm
druzdcm wrote:
Me-or Bill?
Bill
druzdcm
druzdcm
PostSubject: Re: So I got the SS running today!   So I got the SS running today! EmptyMon Mar 29, 2010 7:23 pm
Sometimes I am tempted when things break
Twisted Evil
PostSubject: Re: So I got the SS running today!   So I got the SS running today! EmptyMon Mar 29, 2010 7:28 pm
Well everything happend suddenly at the track during the third or so round. Maybe you have a broke spring. At the very least, I would check vacuum.
PostSubject: Re: So I got the SS running today!   So I got the SS running today! EmptyMon Mar 29, 2010 7:39 pm
we check the vacuum it was good, he needs to data log it and see if the O2's
drop down to double digits that would be loss of spark
PostSubject: Re: So I got the SS running today!   So I got the SS running today! EmptyMon Mar 29, 2010 10:01 pm
I don't have the unlock code for datamaster. Anyone gimme a hand with that? Wink
PostSubject: Re: So I got the SS running today!   So I got the SS running today! EmptyWed Mar 31, 2010 5:15 pm
Twisted Evil
Well let me know when you do, I like your car Smile
druzdcm
druzdcm
PostSubject: Re: So I got the SS running today!   So I got the SS running today! EmptyWed Mar 31, 2010 8:13 pm
Sure-I I like it too, but not when things go bad. I am probly going to put on my new trans pan-hit mine on the way up to the meet and mine's the Deepest one I think. I just got on my tubular Xmember on last week and he welded my xhaust while it was up in the air.
PostSubject: Re: So I got the SS running today!   So I got the SS running today! EmptyWed Mar 31, 2010 8:14 pm
Threadjacker. cherry
druzdcm
druzdcm
PostSubject: Re: So I got the SS running today!   So I got the SS running today! EmptyWed Mar 31, 2010 8:16 pm
So what do you think is the issue with your SS?
PostSubject: Re: So I got the SS running today!   So I got the SS running today! EmptyWed Mar 31, 2010 8:18 pm
Lack of time.
Sad
druzdcm
druzdcm
PostSubject: Re: So I got the SS running today!   So I got the SS running today! EmptyWed Mar 31, 2010 8:22 pm
Hey-same here Very Happy
My wife has some dancing class M-W but last night Passover so my week has been feeding Jack and then bedtime so after that I get wiped out...till tomorrow after a trip to Children's Hospital hopefully!
PostSubject: Re: So I got the SS running today!   So I got the SS running today! EmptyWed Apr 07, 2010 5:06 pm
Little update... Running great and no more run-ins with Smokey. Wink
She's running the balls. Not popping up the intake anymore that I can tell... Woot!
uhm... You guys'll bail me out when I get popped, right?
druzdcm
druzdcm
PostSubject: Re: So I got the SS running today!   So I got the SS running today! EmptyWed Apr 07, 2010 9:13 pm
So how come you switched the wheels?
PostSubject: Re: So I got the SS running today!   So I got the SS running today! EmptyWed Apr 07, 2010 9:17 pm
Because the Rallyes wouldn't fit on the Marshmallow yet.
PostSubject: Re: So I got the SS running today!   So I got the SS running today! EmptyWed Apr 07, 2010 9:28 pm
I like the ralleys on the SS. Very Happy
PostSubject: Re: So I got the SS running today!   So I got the SS running today! EmptyWed Apr 07, 2010 9:36 pm
I like the Marshmallow. Very Happy
druzdcm
druzdcm
PostSubject: Re: So I got the SS running today!   So I got the SS running today! EmptyWed Apr 07, 2010 9:46 pm
Just curious-either car those Coyz are on looks hot.
PostSubject: Re: So I got the SS running today!   So I got the SS running today! EmptyWed Apr 07, 2010 10:06 pm
Yet?? care to follow up?
» Who's running a 52 mm TB?
» LT1 runs fine when first started then runs crappy after warming up
» Running Lean
» running issue
» Level III is in and running!
