| OMG!!!!! TRANNY LEAK | |
| Subject: OMG!!!!! TRANNY LEAK Mon Feb 22, 2010 9:43 am | |
| I have a trany leak not coming from the pan its coming from up front. could it be the lines? if so is that a hard repair? | |
| Subject: Re: OMG!!!!! TRANNY LEAK Mon Feb 22, 2010 10:25 am | |
| What do you mean by "up front"? It could be a blown cooler line running to the radiator. Those are pretty easy fixes if your not concerned with a concourse quality repair. You're going to have to climb under the car and take a look at where the leak is before anyone can help you fix it. | |
| Subject: Re: OMG!!!!! TRANNY LEAK Mon Feb 22, 2010 10:56 am | |
| WATERPUMP!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! LEAKING FROM THE BOTTOM THOUGH IT WAS TRANNY FLUID CAUSE OF THE COLOR | |
| Subject: Re: OMG!!!!! TRANNY LEAK Mon Feb 22, 2010 11:03 am | |
| Bummer dude. esy fix though i did mine in less than an hour | |
| Subject: Re: OMG!!!!! TRANNY LEAK Mon Feb 22, 2010 11:05 am | |
| If it is the line to the radiator, it is a very easy fix. Cut out the bad piece (preferably with a pipe cutter).
Go to the auto parts store and buy a piece of high pressure hose for tranny line repair and some small clamps. Put them together and your done.
If you had a flare tool you could flare the ends of the pipe just a little extra insurance. Make sure you slide the hose over the tube 1 1/2 or 2 inches.
Tom C. | |
| Subject: Re: OMG!!!!! TRANNY LEAK Mon Feb 22, 2010 11:06 am | |
| Just saw your posting, it's the waterpump. R & R.
Tom C. | |
| Subject: Re: OMG!!!!! TRANNY LEAK Mon Feb 22, 2010 11:07 am | |
| but its leaking from a like a weep hole. do i still need a new waterpump | |
| Subject: Re: OMG!!!!! TRANNY LEAK Mon Feb 22, 2010 11:26 am | |
| Leaking weep hole is how you know that you need a new pump. It'll still be driveable with a leak for a while. Just don't let it go too long or the pump can start to fail mechanically and damage other stuff. | |
| Subject: Re: OMG!!!!! TRANNY LEAK Mon Feb 22, 2010 11:29 am | |
| yeaaaa... im going to go buy a new water pump heater core, and thermostat now. Do i need to replace that wp seal.. i dont want to get deep into stuff that i will not be able to complete | |
| Subject: Re: OMG!!!!! TRANNY LEAK Mon Feb 22, 2010 12:40 pm | |
| I replaced my seal, glad i did. | |
| Subject: Re: OMG!!!!! TRANNY LEAK Mon Feb 22, 2010 12:51 pm | |
| When I did mine I noticed the grove where the seal sits and that there wasn't a seal there. So I said screw it and left it off. Never had any issues and that was years ago when I first got the car. I think it's just to keep corrosion from locking the adapter to the pump threads. I've seen sealed units that are still corroded on so I don't worry about it. | |
| Subject: Re: OMG!!!!! TRANNY LEAK Mon Feb 22, 2010 1:37 pm | |
| Just got back from napa. Going to tackle it now I'll let ya know how it went. | |
| Subject: Re: OMG!!!!! TRANNY LEAK Mon Feb 22, 2010 5:27 pm | |
| Done yet Rich ? | |
| Subject: Re: OMG!!!!! TRANNY LEAK Mon Feb 22, 2010 6:32 pm | |
| I DONT GET IT.. THE PART SHOWING IS THE SAME PART THAT IS ON THE WATERPUMP. WHICH ONE COMES OUT...... | |
| Subject: Re: OMG!!!!! TRANNY LEAK Mon Feb 22, 2010 6:37 pm | |
| the shaft stays, you have to get that seal off if your changing it | |
| Subject: Re: OMG!!!!! TRANNY LEAK Mon Feb 22, 2010 6:39 pm | |
| butthere is a shaft on the waterpump also | |
| Subject: Re: OMG!!!!! TRANNY LEAK Mon Feb 22, 2010 6:43 pm | |
| your not doing the water pump seal its a new pump right | |
| Subject: Re: OMG!!!!! TRANNY LEAK Mon Feb 22, 2010 6:45 pm | |
| Subject: Re: OMG!!!!! TRANNY LEAK Mon Feb 22, 2010 6:48 pm | |
| do you have the seal installer,there was a post in the Impala forum showing how to make 1 | |
| Might as well do the wp drive shaft seal as well. |
| Subject: Re: OMG!!!!! TRANNY LEAK Mon Feb 22, 2010 6:51 pm | |
| i have 2 shafts one on the pump and one in the picture... how would i install it. it doesnt make sense | |
| Subject: Re: OMG!!!!! TRANNY LEAK Mon Feb 22, 2010 6:53 pm | |
| they are the same. one cant go into another | |
| Subject: Re: OMG!!!!! TRANNY LEAK Mon Feb 22, 2010 6:56 pm | |
| - BoSStonsSS wrote:
- i have 2 shafts one on the pump and one in the picture... how would i install it. it doesnt make sense
The one in the picture. But you will need to make a install tool from a magic marker, as the seal has two sealing points (inner, and outer), and if you just try to push it on without a tool, it will leak. |
| Subject: Re: OMG!!!!! TRANNY LEAK Mon Feb 22, 2010 7:02 pm | |
| here you go Rich
http://www.impalassforum.com/vBulletin/showthread.php?t=227694&highlight=water+pump+seal+install | |
| Subject: Re: OMG!!!!! TRANNY LEAK Mon Feb 22, 2010 7:10 pm | |
| How is this going into te shaft | |
| Subject: Re: OMG!!!!! TRANNY LEAK Mon Feb 22, 2010 7:12 pm | |
| you dropped the coupler look under the car or stuck on the old water pump | |
| Subject: Re: OMG!!!!! TRANNY LEAK Mon Feb 22, 2010 7:20 pm | |
| its on the old one.. wow didnt know .. do i just wrestle that off | |
| Subject: Re: OMG!!!!! TRANNY LEAK Mon Feb 22, 2010 7:22 pm | |
| Here's the part your looking for Rich http://rmsautoparts.com/proddetail.php?prod=10128334 | |
| Subject: Re: OMG!!!!! TRANNY LEAK Mon Feb 22, 2010 7:23 pm | |
| what ever it takes, pry, heat,hammer
you might need new o-rings for the inside of the coupler if it has them. my car has electric WP I don't have any of that stuff
| Subject: Re: OMG!!!!! TRANNY LEAK Mon Feb 22, 2010 7:25 pm | |
| Yea wrestle away.Pb blaster etc And i would change that seal if you've got it and have confidence in getting it done I didn't do it on my car and it leaked | |
| Subject: Re: OMG!!!!! TRANNY LEAK Mon Feb 22, 2010 8:27 pm | |
| cant finish coupling will not come off.. wish i had the right toools i wouldve been done awhile ago.. looks like i have to wait a couple days for a new coupling ... DEFEATED | |
| Subject: Re: OMG!!!!! TRANNY LEAK Mon Feb 22, 2010 8:31 pm | |
| find someone with a vise, clamp the coupler in it and with a punch and hammer hit the shaft inside | |
| Subject: Re: OMG!!!!! TRANNY LEAK Mon Feb 22, 2010 8:32 pm | |
| - BoSStonsSS wrote:
- cant finish coupling will not come off.. wish i had the right toools i wouldve been done awhile ago.. looks like i have to wait a couple days for a new coupling ...
DEFEATED If it is stuck to the wp, just heat it up with a torch, and pry it with a big azz screw driver. But aim it down so it does not take off. |
| Subject: Re: OMG!!!!! TRANNY LEAK Mon Feb 22, 2010 9:03 pm | |
DEFEATED Rich i got a couple kicking around .Could mail one out Headed to fedex tommorow LMK | |
| Subject: Re: OMG!!!!! TRANNY LEAK Tue Feb 23, 2010 2:50 pm | |
| ALL DONE BUT JUST NOTICE I DIDNT DO THE DAMN HEATER CORE!!!!!!!!!!!!!!!!!!!!!!!!! COOLANT LIGHT STILL ON | |
| Subject: Re: OMG!!!!! TRANNY LEAK Tue Feb 23, 2010 4:01 pm | |
| The coupler freezing on is why I don't put much stock in replacing the seals and such when doing the swap. Seams like there's not much upside to bothering since the rust and crap is going to find its way in anyhow. I hope you remembered to put teflon tape on any bolts going into water jackets during the reinstall | |
| Subject: Re: OMG!!!!! TRANNY LEAK | |
