Fixed the Jeep. EmptyWed Oct 19, 2022 1:27 pm by scot
Fixed the Jeep. EmptyTue Oct 18, 2022 8:58 pm by silverfox103
Fixed the Jeep. EmptyTue Sep 28, 2021 11:01 pm by silverfox103
Fixed the Jeep. EmptyFri Sep 24, 2021 9:53 am by ElKy
Fixed the Jeep. EmptySun Sep 19, 2021 6:22 pm by black blur 96
Fixed the Jeep. EmptySun Jun 20, 2021 11:37 am by scot
Fixed the Jeep. EmptyFri Jun 11, 2021 10:41 am by scot
Fixed the Jeep. EmptyWed Jun 09, 2021 9:41 pm by Chris Klein
Fixed the Jeep. EmptyWed Jun 02, 2021 9:02 pm by Chris Klein
 Fixed the Jeep.
2 posters
PostSubject: Fixed the Jeep.   Fixed the Jeep. EmptySun Aug 09, 2009 7:16 pm
Finally got around to working on my broken down Jeep Cherokee.
It completely died on the highway about a month ago.
I thought it might be the fuel pump.
Disconnected at the fuel filter and turned the key GAS spurted out each time.
I picked up a new coil ,figured it would be the easist,cheapest place to start.
Of course as usual a job that should have been 2 scews and a couple of connections turned into a 2 hour mess Had to pull the bracket that holds the coil.
Because the heads of the screws to mount the coil were all stripped,But i got it in and she fired right up.
I didn't think a coil would totally die like that.
Now i gotta figure out how to get the rear wheels off.Rusted right to the hub!!
So i can do the brakes,and put on a new muffler and tailpipe.
PostSubject: Re: Fixed the Jeep.   Fixed the Jeep. EmptySun Aug 09, 2009 8:00 pm
Never remove wheels this way......but I just loosen the lugs a bit and then drive in a circle away from the loosened wheels until I hear a loud bang. Then tighten the lugs on the side and loosen the other side and drive in a circle going the other way until you hear the bang. But never do that trick because it's not safe Wink
PostSubject: Re: Fixed the Jeep.   Fixed the Jeep. EmptySun Aug 09, 2009 8:25 pm
Sounds Dangerous I'll try it Twisted Evil
Fixed the Jeep.
» Jeep Cherokee??
» digital speedometer question
» Jeep steering shaft
» 95 FWB wipers won't shut off until key is turned off/on again
» Well my car is fixed.
