| Wagon Guys | |
+31984twodoor Tomz9C1 sdstick 7 posters |
| Subject: Wagon Guys Fri May 29, 2015 3:20 pm | |
| Who sells rear brakelines for the RMW's? Or do you just bend them yourselves? | |
| Subject: Re: Wagon Guys Fri May 29, 2015 10:45 pm | |
| Would they be the same as Caprice assuming they have rear drums? The wheel base is the same. I plan on doing the rear disc brake mod , so Stainless lines are in the plans for my RMW. | |
| Subject: Re: Wagon Guys Sat May 30, 2015 9:15 am | |
| Thats the question I guess...Who's are axle spec guy? | |
| Subject: Re: Wagon Guys Sat May 30, 2015 6:30 pm | |
| AFAIK they are the same beast. Inline tube or classic tube will probably be the best bet for prebent lines. I'd start there.
A wagon would most likely have an 8.5" rear with drums unless someone swapped it out. Don't take it as a sure thing though, I'm just assuming. | |
| Subject: Re: Wagon Guys Sun May 31, 2015 12:25 pm | |
| wagon axle is wider by about 3 inches. | |
| Subject: Re: Wagon Guys Sun May 31, 2015 12:28 pm | |
| So, I guess I make the lines? Thought there must be a quick answer to this...that didnt involve me spending time Damn... | |
| Subject: Re: Wagon Guys Sun May 31, 2015 6:22 pm | |
| Or swap in an Impala SS / 9C1 rear. | |
| Subject: Re: Wagon Guys Mon Jun 01, 2015 12:17 pm | |
| Those lines won't take you long. The bitch is flaring the ends if you don't have the right tool. I had to take mine out a an take them over and have ends put on and flaired. Some double flair shit. I don't know | |
| Subject: Re: Wagon Guys Mon Jun 01, 2015 12:53 pm | |
| I've had good luck with a cheap Performance Tool double flaring tool from autozone, oreillys, etc. Worked better than a Craftsman tool that a friend gave me. | |
| Subject: Re: Wagon Guys Mon Jun 01, 2015 2:31 pm | |
| OK thanks, guess I can handle it. Do the parts stores sell that sleeved (protective coil) brake line? Cant remember if I've seen it there or not | |
| Subject: Re: Wagon Guys Tue Jun 02, 2015 1:30 pm | |
| I don't recall seeing it there. NAPA in Nashua can help you, I'm sure. They're great! | |
| Subject: Re: Wagon Guys Wed Jun 03, 2015 12:15 am | |
| From Gerry (95wagon) on that other forum before the "crash":
Ok, I just looked at and measured EVERY line and fitting from a 95 Every flare is bubble except on the diff housing.
Although likely metric I am going to call the tube size in inches , as in 3/16 and ¼
The Master is 10-1.50 3/16 12-1.00 1/4 The combo valve. In is 10-1.50 3/16 and 12-1.00 1/4
Out is 10-1.00 3/16 and 12-1.50 1/4
ABS In is : front 10-1.00 3/16 rear 12-1.00 1/4 Out is : front left 12-1.00 3/16 front right 10-1.00 3/16 rear 12-1.00 1/4
I don’t have the rear line here but know it is bubble and am fairly sure it is 12-1.00 at the flex hose end. On the diff housing they are 3/16 inverted flare in the center and ( with drums) 3/16 inverted flare at the wheel cylinders. ( with discs) bubble flare 10-1.00 thread at the wheel flex hoses double check your sizes but I believe this info to be correct. Because of some of the odd sizes you might want to save your old nuts where ever possible.
| Subject: Re: Wagon Guys Wed Jun 03, 2015 1:16 pm | |
- I don't recall seeing it there. NAPA in Nashua can help you, I'm sure. They're great!
.. .. .. ...Tellem Chris sent you for the special pricing Well...actually...the price is the same but... you get a sales slip & return slip & another sales slip so.... because it cost THEM more to charge YOU the same, you got a deal...right? - boojum wrote:
OK thanks Jim. I know the answer is in there...somewhere...uumm.. who am I kidding, I'll never figure ^^THAT^^ out. | |
| Subject: Re: Wagon Guys | |
| Wagon Guys | |
