Fuel pressure readings EmptyWed Oct 19, 2022 1:27 pm by scot
Fuel pressure readings EmptyTue Oct 18, 2022 8:58 pm by silverfox103
Fuel pressure readings EmptyTue Sep 28, 2021 11:01 pm by silverfox103
Fuel pressure readings EmptyFri Sep 24, 2021 9:53 am by ElKy
Fuel pressure readings EmptySun Sep 19, 2021 6:22 pm by black blur 96
Fuel pressure readings EmptySun Jun 20, 2021 11:37 am by scot
Fuel pressure readings EmptyFri Jun 11, 2021 10:41 am by scot
Fuel pressure readings EmptyWed Jun 09, 2021 9:41 pm by Chris Klein
Fuel pressure readings EmptyWed Jun 02, 2021 9:02 pm by Chris Klein
2 posters
PostSubject: Fuel pressure readings   Fuel pressure readings EmptyWed Jun 24, 2015 1:50 pm
This is the '94 RMS
Idle 35-36 PSI
Hit the throttle (quick snap) in park jumps to 45
Let off throttle drops down to 33 then back to 36
Hold throttle down in park 33-34 PSI then rises to 36 PSI once let off
Idle with no FPR vacuum 46 PSI
Unplugged FBR throttle snap 46 PSI
Plug FPR back in PSI drops to 36 again
KOEO PSI jumps to and stays at 44 PSI
I know the fuel filter is ooooooold and needs to be replaced, but can't say it'd clog to cause this issue.
Can't take a drive and watch gauge. Hose isn't long enough. Trying to borrow one...
Thoughts?
PostSubject: Re: Fuel pressure readings   Fuel pressure readings EmptyThu Jun 25, 2015 8:07 pm
I had a car run on 20psi
thats not your problem IMO
PostSubject: Re: Fuel pressure readings   Fuel pressure readings EmptyThu Jun 25, 2015 8:09 pm
It's not the problem, but it's a problem.
20psi doesn't sound like that car ran good at all if you're talking about an LT1.
PostSubject: Re: Fuel pressure readings   Fuel pressure readings EmptyThu Jun 25, 2015 8:11 pm
Trying to remeber now if that was the operating or prime psi
I just remember saying after seeing it...wow...still running without issue
Think it was an intermittant start
» no injector pulse
» Stumped on low fuel pressure- HELP!!
» Fuel Bib???
» Fuel Pressure Regulator AC Delco
» Fuel Issue - need guidance
