My Never Ending LSX Parts List EmptyWed Oct 19, 2022 1:27 pm by scot
My Never Ending LSX Parts List EmptyTue Oct 18, 2022 8:58 pm by silverfox103
My Never Ending LSX Parts List EmptyTue Sep 28, 2021 11:01 pm by silverfox103
My Never Ending LSX Parts List EmptyFri Sep 24, 2021 9:53 am by ElKy
My Never Ending LSX Parts List EmptySun Sep 19, 2021 6:22 pm by black blur 96
My Never Ending LSX Parts List EmptySun Jun 20, 2021 11:37 am by scot
My Never Ending LSX Parts List EmptyFri Jun 11, 2021 10:41 am by scot
My Never Ending LSX Parts List EmptyWed Jun 09, 2021 9:41 pm by Chris Klein
My Never Ending LSX Parts List EmptyWed Jun 02, 2021 9:02 pm by Chris Klein
3 posters
PostSubject: My Never Ending LSX Parts List   My Never Ending LSX Parts List EmptyMon Sep 30, 2013 7:00 pm
Cleaning out the garage of all my excess. Feel free to make an offer, and if you are looking for something you don't see....just ask....I might have it.
All parts are located in the Springfield - Westfield MA area.
Thanks for looking,
Brandon
413-455-9795
-L92 Truck Intake Manifold Complete- 200.00
90mm Rectangle port truck intake.
-2004 4.8L LR4 Stock Camshaft- 40.00
-706 Casting Cylinder Heads *CORES*- 75.00
These heads are complete but in rough shape (corroded and filthy). They would be best for someone turning in for CNC work, or if you wanted a solid set to port.
-2005 Corvette Harness- 250.00
I don't know a whole lot about this, it is off a 2005 Vette and uses the three PCM connectors as opposed to the normal E38 2 connector.
-1999 6.0L Harness, PCM and MAF- 200.00
This is a complete un-cut setup from an early 6.0L. Everything is there and in excellent condition. Removed from a 4wd
-2004 4.8L/ 4L80E Harness, PCM and MAF- 250.00
This is a complete un-cut setup from a 2004 2wd van. Everything is there and in excellent condition. Removed from a van equipped with a 4L80E from the factory, (already setup to control the trans)
-Coil Harnesses- 50.00 per set
These are the small harnesses that separate from the primary, but daisy-chain each bank of coils together.
-Valve Covers- 25.00 per set
-Valley Cover Gen III- 25.00
-Front Cover Gen III- 30.00
-Complete Coil Assembly Standard- 150.00
Includes full set of 8 coils with bracket and harness.
-Complete Coil Assembly Heat Sink Style- 175.00
-Truck Oil Pan- 75.00
Includes windage tray and oil pump pick-up tube
___________________________________________
-Complete Truck Accessory Setup- 100.00
*Includes all the itemized parts below. Does NOT include a power steering pump or alternator)
*-Truck Alternator & Power Steering Bracket- 50.00
*-Truck AC Compressor Bracket- 30.00
*-Truck Water Pump and Clutch Fan- 25.00
*-Truck Crank Pulley- 30.00
-Complete DBC Truck Intake, Rails and Injectors- 80.00
-Truck EGR Exhaust Manifolds- 30.00
-Truck Non-EGR Exhaust Manifolds- 40.00
-LS4 Exhaust Manifolds and Cross-Over- 75.00
Good for a Budget Turbo setup.
-4L80E Flat Flexplate- 40.00
-4L60E Concave Flexplate- 30.00
My Never Ending LSX Parts List Temporary_zpse6efb410
My Never Ending LSX Parts List Temporary_zpsc3bd7624
My Never Ending LSX Parts List Temporary_zpsde596674
My Never Ending LSX Parts List Temporary_zps33d93a3c
My Never Ending LSX Parts List Temporary_zps37483971
My Never Ending LSX Parts List Temporary_zps19510921
My Never Ending LSX Parts List Temporary_zps58130dcc
My Never Ending LSX Parts List Temporary_zpsdd742f6fMy Never Ending LSX Parts List Temporary_zps7b2712d1
My Never Ending LSX Parts List Temporary_zps91d62ee6
My Never Ending LSX Parts List Temporary_zpsc231cb24
My Never Ending LSX Parts List Temporary_zpsfeb557b7
PostSubject: Re: My Never Ending LSX Parts List   My Never Ending LSX Parts List EmptyMon Sep 30, 2013 7:05 pm
anyone u know have a stock ls6 cam?
PostSubject: Re: My Never Ending LSX Parts List   My Never Ending LSX Parts List EmptyMon Sep 30, 2013 7:10 pm
No, but I sell the brand new LS9 cams very reasonably with new front cover kit, cam sensor, cam gear, gaskets and hardware.
PostSubject: Re: My Never Ending LSX Parts List   My Never Ending LSX Parts List EmptyMon Sep 30, 2013 7:32 pm
I heard the ls9 cam is no good with the 5.3 turbo
PostSubject: Re: My Never Ending LSX Parts List   My Never Ending LSX Parts List EmptyMon Sep 30, 2013 7:36 pm
http://ls1tech.com/forums/forced-induction/1566407-ls9-cam-not-good-turbos-3.html
read first post Wink
Granted its a 6.0L but plenty of guys have had really good luck running that cam in 4.8-5.3
Denmah (the junkyard god of boosted LSx) runs them pretty much exclusively.
His site is:
http://www.sloppymechanics.com/
__________________________________________________
Dont get me wrong....there are better options out there....but this is on the cheaper spectrum of things!
PostSubject: Re: My Never Ending LSX Parts List   My Never Ending LSX Parts List EmptyTue Oct 01, 2013 5:39 pm
iam sold on the ls9 cam. when can I come pick up the kit? lol
PostSubject: Re: My Never Ending LSX Parts List   My Never Ending LSX Parts List EmptyTue Oct 01, 2013 5:49 pm
How do you hook the Gen 3 cam sensor connector up to the front of the engine?
PostSubject: Re: My Never Ending LSX Parts List   My Never Ending LSX Parts List EmptyTue Oct 01, 2013 7:10 pm
I bet you would like pricing first lol. PM me...
The LS2 cover has a provision for a cam sensor. Then you just run the 3 bolt 1x cam gear I supply. The wires get extended from the back of the block to the front cover, and the rear cam sensor can stay in place, or some people sell billet plugs.
PostSubject: Re: My Never Ending LSX Parts List   My Never Ending LSX Parts List EmptyWed Oct 02, 2013 8:42 am
I need some L92 heads and an intake for my LQ9 Very Happy
PostSubject: Re: My Never Ending LSX Parts List   My Never Ending LSX Parts List EmptyWed Oct 02, 2013 8:52 am
I have an l92 truck intake, and new ls3
PostSubject: Re: My Never Ending LSX Parts List   My Never Ending LSX Parts List EmptyWed Oct 02, 2013 10:29 am
Any interest in some good 317 heads for parts swapping?
They work good on turbo 5.3's Very Happy
PostSubject: Re: My Never Ending LSX Parts List   My Never Ending LSX Parts List EmptyWed Oct 02, 2013 11:19 am
Well it should be close to this, shouldn't it?  Razz
"I am asking 225.00 for everything picked up in Westfield MA
Please call or text Brandon"
http://westernmass.craigslist.org/pts/4076376390.html
PostSubject: Re: My Never Ending LSX Parts List   My Never Ending LSX Parts List EmptyWed Oct 02, 2013 4:45 pm
Unfortunately I am sitting on two sets of them right now haha. Thanks for the offer though!
Close...but keep in mind that setup was used (and since been sold).
PostSubject: Re: My Never Ending LSX Parts List   My Never Ending LSX Parts List EmptyThu Oct 03, 2013 3:38 pm
I sent u a pm the other day with my cell number.
PostSubject: Re: My Never Ending LSX Parts List   My Never Ending LSX Parts List EmptyThu Oct 03, 2013 5:01 pm
I have no pms from you, try again and I will call.
PostSubject: Re: My Never Ending LSX Parts List   My Never Ending LSX Parts List EmptySun Nov 03, 2013 11:50 am
what do u have for 5.3 flywheel?
PostSubject: Re: My Never Ending LSX Parts List   My Never Ending LSX Parts List EmptySun Nov 03, 2013 8:43 pm
flywheel or flexplate?
I dont have any manual trans stuff, but I do have several stock 5.3/4.8 flexplates.
PostSubject: Re: My Never Ending LSX Parts List   My Never Ending LSX Parts List EmptyMon Nov 04, 2013 5:19 pm
lol yes flexplate. iam running my 96 4l60e
PostSubject: Re: My Never Ending LSX Parts List   My Never Ending LSX Parts List EmptyMon Nov 04, 2013 5:24 pm
30.00
» My MASSIVE Parts for Sale list. 90+ Parts TBI, LT1, Aftermarket and more.
» List of parts I need
» Old parts list revisited.
» PARTS LIST FOR THE ROUND UP!
» Official first mod day parts list
