General Auto Salvage in Claremont EmptyWed Oct 19, 2022 1:27 pm by scot
General Auto Salvage in Claremont EmptyTue Oct 18, 2022 8:58 pm by silverfox103
General Auto Salvage in Claremont EmptyTue Sep 28, 2021 11:01 pm by silverfox103
General Auto Salvage in Claremont EmptyFri Sep 24, 2021 9:53 am by ElKy
General Auto Salvage in Claremont EmptySun Sep 19, 2021 6:22 pm by black blur 96
General Auto Salvage in Claremont EmptySun Jun 20, 2021 11:37 am by scot
General Auto Salvage in Claremont EmptyFri Jun 11, 2021 10:41 am by scot
General Auto Salvage in Claremont EmptyWed Jun 09, 2021 9:41 pm by Chris Klein
General Auto Salvage in Claremont EmptyWed Jun 02, 2021 9:02 pm by Chris Klein
7 posters
PostSubject: General Auto Salvage in Claremont   General Auto Salvage in Claremont EmptyMon Sep 02, 2013 8:22 pm
...Anyone ever deal with them? Reputable? Reasonable prices? They have one of the mysterious '96 G30 vans with Vortec heads that I would like to acquire.
PostSubject: Re: General Auto Salvage in Claremont   General Auto Salvage in Claremont EmptyMon Sep 02, 2013 8:49 pm
The mysteriousness of those vans I believe is that the engine is a Vortec, but it has a special TBI intake that allows a TBI to bolt to it instead of the whole EFI setup the other Vortecs had. I think the heads are the same as other Vortec engines. You'd actually be better off taking the whole engine and putting it in your car since it likely has a roller cam too, kehd. Very Happy
PostSubject: Re: General Auto Salvage in Claremont   General Auto Salvage in Claremont EmptyMon Sep 02, 2013 8:54 pm
But I already have a motor Cool
General Auto Salvage in Claremont 1186066_10151636379703553_878420172_n
PostSubject: Re: General Auto Salvage in Claremont   General Auto Salvage in Claremont EmptyMon Sep 02, 2013 9:11 pm
Aint that always the way?
PostSubject: Re: General Auto Salvage in Claremont   General Auto Salvage in Claremont EmptyMon Sep 02, 2013 10:25 pm
You don't have a rollah cam though, kehd (less'n the Goodwrench engines for some reason came with one, some of the truck blocks had provisions to install one but it's hit or miss and you never know).
PostSubject: Re: General Auto Salvage in Claremont   General Auto Salvage in Claremont EmptyMon Sep 02, 2013 11:04 pm
Correct me if I'm wrong but the provisions cant be had for the price of a drill and tap right? If so just do that lol.
PostSubject: Re: General Auto Salvage in Claremont   General Auto Salvage in Claremont EmptyMon Sep 02, 2013 11:15 pm
With the truck TBIs, some of the blocks had like pads or whatever that you could drill and tap to do the roller cam.  But a lot of the blocks just had nothing cast there! lol  It's very odd how GM did that, some were probably blocks meant to be in cars.  They should have just done the damned roller cams in everything but nooooooooooooooooooooooooooooooooooooooooooo...
Justin, if that bastard TBI Vortec engine is complete and usable I'd get a price from them on it, you never know.  Then you could do a dual engine set up on the wagon or something of this nature.
General Auto Salvage in Claremont MG_2710-685x456
PostSubject: Re: General Auto Salvage in Claremont   General Auto Salvage in Claremont EmptyTue Sep 03, 2013 1:15 pm
I still need to get the trans seperate so I can pull the casting number off the back of the block. But im wondering if its a roller since it was swapped around 96-97 with this Goodwrench crate. Also, according to this thread on 3rd Gen, the vans were a "regular" TBI motor block wise, the only difference was the heads and manifold.
http://www.thirdgen.org/techboard/tbi/336915-1996-g30hd-vans-vortec.html
That said, I'm also wondering, since the only G30's that got them were the 8501 GVW models if they got the flat cams like the 3500 trucks did.
PostSubject: Re: General Auto Salvage in Claremont   General Auto Salvage in Claremont EmptyTue Sep 03, 2013 1:48 pm
Justin,
Step 1: get another modded shopping cart
Step 2: support tranny
Step 3: gather rags for the waterfall of tranny fluid when you disconnect
Step 4: unbolt the TC & tranny
Step 5: seperate, catch, curse, catch, wipe & mop (while cursing more)
Step 6: figure out wtf you have & move on
Hope this helps
Your welcome
If I was closer I'd give you some crovo help. Razz
PostSubject: Re: General Auto Salvage in Claremont   General Auto Salvage in Claremont EmptyTue Sep 03, 2013 4:22 pm
Justin,
Hope this helps
Your welcome
I'm getting there. Im going to go invest in some speedy dry before I do this.
Also, pulled a valve cover, found a casting #
The googles tells me the following:
Quote :
22 350 5.7 89-93 7 V8 OHV, RWD, TBI, roller lifters, center bolt valve covers, high swirl intake ports, right hand dipstick 14093638 14011148 10054727 14088526 14088535 14102193 14102191 10110810
PostSubject: Re: General Auto Salvage in Claremont   General Auto Salvage in Claremont EmptyTue Sep 03, 2013 4:27 pm
Nice. If that's the case that would be awesome.
PostSubject: Re: General Auto Salvage in Claremont   General Auto Salvage in Claremont EmptyTue Sep 03, 2013 4:32 pm
Based on the chart it came from, seems 87 was the year that some trucks either had rollers, or provisions for them, 86 and older had flat. http://www.jimsperformance.com/blocks.html
Also, some more "evidence", the TBI Caprice and the 3500 truck use the same head. And since we know the TBI's are roller...
PostSubject: Re: General Auto Salvage in Claremont   General Auto Salvage in Claremont EmptyTue Sep 03, 2013 4:39 pm
Before the catch and swearing, pickup one of the tailshaft plugs (tranny butt plug Laughing ) from harbor freight.
PostSubject: Re: General Auto Salvage in Claremont   General Auto Salvage in Claremont EmptyTue Sep 03, 2013 4:41 pm
Huh Huh, Dave said butt huh huh Laughing
PostSubject: Re: General Auto Salvage in Claremont   General Auto Salvage in Claremont EmptyTue Sep 03, 2013 4:48 pm
I assumed it already had that.....or reasonable facsimile....seeing as its already sitting on his garage floor.
Unless you meant....Embarassed ...no....Shocked ....your not recommending.....affraid .....what are you from MAINE?
PostSubject: Re: General Auto Salvage in Claremont   General Auto Salvage in Claremont EmptyTue Sep 03, 2013 4:49 pm
This thread has taken a terrible, terrible turn.
PostSubject: Re: General Auto Salvage in Claremont   General Auto Salvage in Claremont EmptyTue Sep 03, 2013 5:00 pm
The general consensus I've seen over the years on the truck forums is that the 1986 and older small blocks have no provisions at all for the factory roller cams...the TBI truck motors had the provisions on some of the motors, and that was mainly toward the middle of 87-95 production and later...but a popular Goodwrench engine to be swapped in was roller. All car TBIs had the roller cam and I also think the 4.3 TBI truck engines had roller cams in them at least by the early 1990s?
I have heard of people using parts from LT1s to swap over the factory roller cam, I guess the incentive was because doing an aftermarket roller cam swap is very expensive or some shizz. I saw on one site where some guy claimed to have seen factory rollers a lot in trucks and vans but it turned into an argument, lol.
Furthermore, I'm pretty sure for a while, a popular Goodwrench crate engine was literally the 350 that came in the B and C bodies from 1990-1993, the L05 car TBI long block. I think they might've stopped making it though...
PostSubject: Re: General Auto Salvage in Claremont   General Auto Salvage in Claremont EmptyTue Sep 03, 2013 5:02 pm
Butt plugs? Is this drivetrain swap being performed in the parking lot of Amazing on Route 1 in Peabody, kehd?
PostSubject: Re: General Auto Salvage in Claremont   General Auto Salvage in Claremont EmptyTue Sep 03, 2013 5:20 pm
face palm in and out
That is a joke not everyone on here will understand fully, but by now they all know the gist of it..
PostSubject: Re: General Auto Salvage in Claremont   General Auto Salvage in Claremont EmptyTue Sep 03, 2013 5:50 pm
What I've read and seen, all 87+ 1 piece main seal blocks, have provisions for roller cams. They have the bosses in the lifter valley and larger lifter bores. You may have to drill and tap the bosses on the non-roller blocks.
I have a roller cam 305 from a camaro, if anyone wants it....lol
PostSubject: Re: General Auto Salvage in Claremont   General Auto Salvage in Claremont EmptyTue Sep 03, 2013 5:51 pm
Isn't this a Brad story?
PostSubject: Re: General Auto Salvage in Claremont   General Auto Salvage in Claremont EmptyTue Sep 03, 2013 10:19 pm
Someone please fill me in, spare no details Laughing
PostSubject: Re: General Auto Salvage in Claremont   General Auto Salvage in Claremont EmptyWed Sep 04, 2013 11:28 pm
On topic: I spent all of high school scrounging that yard, got lots of great parts when you could still pull your own. In the last few years it's been hard to find anything reasonably priced there, good luck if you go for it.
Back to butt plugs....
» Bow auto
» EZ auto in nh??
» Roadmaster Limited in Salvage Yard Tan/Tan
» Anyone Want a $50 off a $100 or More Purchase at Advance auto?
» New Concepts from the General: Iroc-Z, Cheyenne
