My Personal Engine 2006 L33 Aluminum 5.3 EmptyWed Oct 19, 2022 1:27 pm by scot
My Personal Engine 2006 L33 Aluminum 5.3 EmptyTue Oct 18, 2022 8:58 pm by silverfox103
My Personal Engine 2006 L33 Aluminum 5.3 EmptyTue Sep 28, 2021 11:01 pm by silverfox103
My Personal Engine 2006 L33 Aluminum 5.3 EmptyFri Sep 24, 2021 9:53 am by ElKy
My Personal Engine 2006 L33 Aluminum 5.3 EmptySun Sep 19, 2021 6:22 pm by black blur 96
My Personal Engine 2006 L33 Aluminum 5.3 EmptySun Jun 20, 2021 11:37 am by scot
My Personal Engine 2006 L33 Aluminum 5.3 EmptyFri Jun 11, 2021 10:41 am by scot
My Personal Engine 2006 L33 Aluminum 5.3 EmptyWed Jun 09, 2021 9:41 pm by Chris Klein
My Personal Engine 2006 L33 Aluminum 5.3 EmptyWed Jun 02, 2021 9:02 pm by Chris Klein
PostSubject: My Personal Engine 2006 L33 Aluminum 5.3   My Personal Engine 2006 L33 Aluminum 5.3 EmptySat Jul 27, 2013 10:27 pm
I have decided to sell the motor out of my car.
I am going to start swapping various ls based engines into my chassis during the spring and summer months so customers can hear the engines run and experience the power for themselves. Sense I am going this route, I really don't need a full time motor of my own, and I figure I can free up some funds for my company.
The engine is a 2006 all aluminum 5.3. It has 14x,000 miles on it and runs like a top. Doesn't burn oil, doesn't tick, doesn't leak....I just turn the key and it goes every time.
2006 L33 (24x/1x)
799 Casting Cylinder Heads (similar to 243 Corvette castings)
Stock cam specs:
114 LDA 116 INTAKE CENTERLINE
1.70 ROCKER RATIO
Lift:
@Cam @Valve
EXHAUST: 0.283 0.480
INTAKE: 0.283 0.480
My Personal Engine 2006 L33 Aluminum 5.3 Temporary_zps33faaafb
My Personal Engine 2006 L33 Aluminum 5.3 Temporary_zpsa0ceb497
My Personal Engine 2006 L33 Aluminum 5.3 Temporary_zps70f96102
My Personal Engine 2006 L33 Aluminum 5.3 Th_5-18_zps819854ce
This engine is BONE STOCK right down the factory cam. I have run a best of 13.0@106 in a 3600lb car with this motor through a TH350. It will run this number all day long too, not a one hit cool-down wonder. It is a really great piece and runs awesome.
Before I dropped it into my caprice, I changed the valve cover gaskets and grommets, valley cover gasket, intake manifold gaskets, and installed new plugs and wires. Coil covers, front cover and valley cover all have stainless socket cap hardware. Since I have had this engine in my possession, I have only used Amsoil and Delco Filters.
Right now it is painted a Fordish Gray color. The engine will come with a brand new GM Musclecar Pan Kit (I need to keep my F-Body pan that is on it now).
I have it listed as a long block, but the sale does include complete drive by cable intake manifold, return style fuel rails with AN fitting adapters, injectors, coils, flexplate and spacer (flexplate and spacer is setup for TH350/TH400)
No accessories, no harness or pcm. I can supply these things for extra if you need them.
1200.00 pretty firm
call or text me
413-455-9795
» Ok then, let's try it this way... WTB: Aluminum driveshaft
» LT1 Aluminum Heads
» My personal dream car is finally on the market
» Aluminum lt1 heads for sale.
» Aluminum LT1 "643" heads FS
