No, it's not a B-body, but takes up as much space as one! I need some space and lost interest in this car.
Here's my ad from the Riviera forum:
At this point I have too many cars, so I decided to put my 95 up for sale. I finished doing a of work on it but lost interest in this project. I'm aking $1500 but am open to offers as well. The details:
1995 Supercharged
160k on the clock, engine has much less on it.
Engine: I installed this engine when I bought the car (had a knocking engine when I got it). I picked up this engine from the yard and found a tag on it stating its a GM reman from 2001. Bored .020 over according to the tag. The engine looked very clean, but I replaced some gaskets while I had it out. This includes the oil pan, timing over, valve covers, lower intake, and super charger to name a few. I also replaced the SC coupler, water pump, and installed delco plugs an wires. New crank sensor. The engine runs great and does not leak. I also replaced the PCM with a reman due to a CEL.
Transmission: shifts smooth, changed fluid and filter (even drained old fluid from TCC while I had the engine out. One oil cooler line does leak.
Brakes: Replaced all the brake lines from the ABS unit back, new master cylinder.
Body/paint: The paint job is a custom 2 tone that the PO had done by maaco a few years ago. It's in relatively good shape but does need touch up, especially around the rear window. Body has no rust on it, no dents. One of the side Riv emblems fell off. The T-type emblems are off an 87 Riviera T-type.
Wheels: Comes with the chrome factory wheels that are in good shape. One center cap is a Riv one, others are buick tri-shield ones. Tires have plenty of tread left.
Interior: Interior is in good shape, carpet could use a cleaning. The seats are in great shape, no rips. Driver's seat works fine, passenger won't move forward.
Options: This car seemed pretty loaded as it has a heated driver's seat, traction control, factory alarm (security light is on though), keyless (with one remote) auto dim DS mirror (turned amber), auto im rear view mirror, and sunroof (works).
Mechanically the car is great. Runs and drives real nice. I don't have it registered so I haven't taken it very far.
Comes with a clean CT title.
Known issues:
Power steering fluid leak: I think its a line leaking, but am not sure.
Auto level control leaks: Compressor works but comes on constantly.
Traction light is on: Comes on after about a mile of driving, ABS light stays off though.
AC system has a leak
Rear carpet is damp, not sure where the leak is
That is all I can think of at this time. If your interested in it please message me. I'd love to see this car go to a good home!
