In total there are 10 users online :: 0 Registered, 0 Hidden and 10 Guests :: 1 Bot
running issue EmptyWed Oct 19, 2022 1:27 pm by scot
running issue EmptyTue Oct 18, 2022 8:58 pm by silverfox103
running issue EmptyTue Sep 28, 2021 11:01 pm by silverfox103
running issue EmptyFri Sep 24, 2021 9:53 am by ElKy
running issue EmptySun Sep 19, 2021 6:22 pm by black blur 96
running issue EmptySun Jun 20, 2021 11:37 am by scot
running issue EmptyFri Jun 11, 2021 10:41 am by scot
running issue EmptyWed Jun 09, 2021 9:41 pm by Chris Klein
running issue EmptyWed Jun 02, 2021 9:02 pm by Chris Klein
 running issue
4 posters
running issue Empty
PostSubject: running issue   running issue EmptySun Feb 03, 2013 8:47 am
I recently started driving the impala again. had no license for 2 months so the car sat. now that iam driving it, once and awhile when I go to start it it will just crank over and not start, if I put the petal to the floor and hold it then it will start.. and it cut out on me the other day driving down the road. had to put it N and rev it up to get it to stay running.. not sure if my coil could be shiting the bed or what..
running issue Empty
PostSubject: Re: running issue   running issue EmptySun Feb 03, 2013 8:50 am
Could be a bad coil, or the grounds at the coil. Or an opti. Or fuel pump... Could be a lot of things. Sad
running issue Empty
PostSubject: Re: running issue   running issue EmptySun Feb 03, 2013 8:53 am
ya, fuel pump,opti,wires are all new within a few years. coil is about 3 years old.
running issue Empty
PostSubject: Re: running issue   running issue EmptySun Feb 03, 2013 9:12 am
Check the grounds at the coil. They tend to break there and you can't see it unless you separate them and really look for it.
running issue Empty
PostSubject: Re: running issue   running issue EmptySun Feb 03, 2013 9:37 am
ya we had that issue on my moms wagon.. iam goin to dig into a little today. just did intake gaskets and oil filter adapter gaskets yeturday. more work in the garage..
running issue Empty
PostSubject: Re: running issue   running issue EmptySun Feb 03, 2013 6:47 pm
ok I think I figured out my problem.. now its another problem.. when I at a light in drive the car starts to surge and the idle bounces up and down.. sometimes it stalls
running issue Empty
PostSubject: Re: running issue   running issue EmptySun Feb 03, 2013 8:12 pm
Did you do anything (check, clean or adjust) to the TB or IAC?
running issue Empty
PostSubject: Re: running issue   running issue EmptySun Feb 03, 2013 9:22 pm
Check the wires to you fuel injectors for breaks and/or corrosion,
Any CEL's?
running issue Empty
PostSubject: Re: running issue   running issue EmptyMon Feb 04, 2013 8:34 am
I just did intake gaskets, throttle body gasket and a few other things. cleaned everything out.. what is the iac?
running issue Empty
PostSubject: Re: running issue   running issue EmptyMon Feb 04, 2013 9:40 am
Idle air control
Bottom of the TB
I'll see if I can find the link on resetting it
If I remeber correctly people make a big deal of saying NOT to touch it
Then...I saw the procedure & it seemed to say it resets itself...
IDK...I have info somewhere (also the manual if need be)
running issue Empty
PostSubject: Re: running issue   running issue EmptyMon Feb 04, 2013 10:01 am
They say don't push the pintle back in with your thumb because it can cause damage. But I have done it numerous times with no issue. If you gently rock it back and forth while pushing in it should go all the way in and reset itself. if it doesn't move at all it's junk!
running issue Empty
PostSubject: Re: running issue   running issue EmptyMon Feb 04, 2013 10:11 am
That sounds right....then after the motor runs it adjusts the # of steps it needs to idle & not surge
running issue Empty
PostSubject: Re: running issue   running issue EmptyMon Feb 04, 2013 1:59 pm
ill have to look into it.. I didn't take it off I only umplugged it and did a new throttle body gasket
running issue Empty
PostSubject: Re: running issue   running issue EmptyMon Feb 04, 2013 2:01 pm
If you didnt mess with it or spray down into it I doubt thats an issue.
Just make sure you didnt bend any pins or yank any wires when you pulled them to do the intake
This is where a scan can keep the headaches to a minimum
running issue Empty
PostSubject: Re: running issue   running issue EmptyMon Feb 04, 2013 2:09 pm
Stupid but did you hook the egr tube back up?
running issue Empty
PostSubject: Re: running issue   running issue EmptyMon Feb 04, 2013 2:15 pm
Ya, when those tubes get old, they get hard & dont seal very well
I put a clamp on them (never to be seen again once buttoned up)
running issue Empty
PostSubject: Re: running issue   running issue EmptyMon Feb 04, 2013 2:55 pm
ill look over everything. I did clean the throttle body out.. might have messed with it
running issue Empty
PostSubject: Re: running issue   running issue EmptyMon Feb 04, 2013 3:01 pm
Did you clean the o2's? Sometimes the PCM reads a certain air/fuel for so long because of dirty intake/tb that when you clean it the o2's are too clogged to read how clean the air/fuel mix really is.
Also make sure you check those fuel injector connections and wires, I've had loose and broken wires there before, and it caused surging and stalling like that,
running issue Empty
PostSubject: Re: running issue   running issue EmptyThu Feb 07, 2013 5:56 pm
didn't touch the o2's ill go over the injector wires this weekend. ill have nothing else to to since ill be trapped
running issue Empty
running issue
» Alignment issue
» shift issue
» Not a B-body, but a GM Issue
» Serious alignment issue need help!!
» Fuel Issue - need guidance
