A/C Delete Pulley AC Compressor Bypass EmptyWed Oct 19, 2022 1:27 pm by scot
A/C Delete Pulley AC Compressor Bypass EmptyTue Oct 18, 2022 8:58 pm by silverfox103
A/C Delete Pulley AC Compressor Bypass EmptyTue Sep 28, 2021 11:01 pm by silverfox103
A/C Delete Pulley AC Compressor Bypass EmptyFri Sep 24, 2021 9:53 am by ElKy
A/C Delete Pulley AC Compressor Bypass EmptySun Sep 19, 2021 6:22 pm by black blur 96
A/C Delete Pulley AC Compressor Bypass EmptySun Jun 20, 2021 11:37 am by scot
A/C Delete Pulley AC Compressor Bypass EmptyFri Jun 11, 2021 10:41 am by scot
A/C Delete Pulley AC Compressor Bypass EmptyWed Jun 09, 2021 9:41 pm by Chris Klein
A/C Delete Pulley AC Compressor Bypass EmptyWed Jun 02, 2021 9:02 pm by Chris Klein
SlowImpala
PostSubject: A/C Delete Pulley AC Compressor Bypass   A/C Delete Pulley AC Compressor Bypass EmptyFri Nov 16, 2012 9:10 pm
A/C Delete Pulley AC Compressor Bypass New still new in the box This listing is for one All-New Dorman A/C Compressor Bypass Pulley. What is an A/C Bypass Pulley?: An A/C bypass pulley is an alternative to expensive air conditioning repairs. Most late model vehicles use a single belt to drive the water pump, alternator, power steering pump, and A/C compressor. When an A/C compressor fails and locks up, it will break the belt and leave you stranded. Until recently, the only solution was to spend hundreds of dollars to replace the compressor and repair the A/C system. Our bypass pulleys have changed that. Simply unbolt your A/C compressor and bolt in one of our brand new bypass pulleys. This will get your vehicle going again for a fraction of the cost of an A/C repair. Our bypass pulleys are designed to bolt-on just as the original compressor did. You can even use the original compressor bolts and belt in most cases. If later you decide to repair your A/C system, simply remove the bypass pulley and bolt the compressor back in place. Our A/C bypass pulleys also offer a great weight savings for off-road and racing applications. pirat $45 bucks
» WTB or trade for a AC Bypass pully
» WFF a/c delete pulley
» Wheel wells, Mezeirre water pump, AC delete pulley, and other parts
» PS bypass ideas?
» Heater Water Bypass Tee!!!!!!!!!!!
