| 1A2 springs | |
+5Ironfistdog SPCS IMPALADAKID Cadet57 No Moa 9 posters |
| Subject: 1A2 springs Tue Aug 07, 2012 9:32 am | |
| I need to get the 1a2 back up, it's so damn low I can't get in the garage without scraping. So are the wagon rears different? I have a couple sets of 9c1 fronts, but I don't know what the rear uses. | |
| Subject: Re: 1A2 springs Tue Aug 07, 2012 1:51 pm | |
| 25 views and not a wagon guy in the bunch? Someone has to know this shit. lol | |
| Subject: Re: 1A2 springs Tue Aug 07, 2012 2:15 pm | |
| - No Moa wrote:
- I need to get the 1a2 back up, it's so damn low I can't get in the garage without scraping. So are the wagon rears different? I have a couple sets of 9c1 fronts, but I don't know what the rear uses.
CC623 is the "heavy duty" wagon rear spring. There was a seller on ebay with them for $39.99 a pair. | |
| Subject: Re: 1A2 springs Tue Aug 07, 2012 3:47 pm | |
| Cheapest i found on sleezebay was 55.00. Am i to assume there are the same as the 9c1's? The listing shows they are, but i want to be sure. | |
| Subject: Re: 1A2 springs Tue Aug 07, 2012 3:49 pm | |
| That, I do not know. However, when you put CC623 into Rockauto it lists them as wagon specific for all years/models. I have them in my wagon and they are stiffer than stock. | |
IMPALADAKID Admin
| Subject: Re: 1A2 springs Tue Aug 07, 2012 5:35 pm | |
| 1A2 used stock wagon springs. | |
SPCS
| Subject: Re: 1A2 springs Tue Aug 07, 2012 6:15 pm | |
- 1A2 used stock wagon springs.
Suspension Code for all Wagons is F40. (Suspension System, Front & Rear, Heavy Duty) | |
| Subject: Re: 1A2 springs Tue Aug 07, 2012 10:26 pm | |
| Are those springs you got after market lowering springs? Or are they just so shitty they ride low? I'm interested in going in the reverse direction with mine | |
| Subject: Re: 1A2 springs Tue Aug 07, 2012 11:16 pm | |
| Why not try a pair of the moog load leveling springs, someone on ebay had them for $40 a pair. A few guys on the longroof forum bought them and liked them, should raise that ass a little http://www.ebay.com/itm/CC623-Moog-Coil-Springs-Variable-Rate-/150837704425?hash=item231ea0b6e9&item=150837704425&pt=Motors_Car_Truck_Parts_Accessories&vxp=mtr | |
| Subject: Re: 1A2 springs Wed Aug 08, 2012 12:20 am | |
| What are the spring codes on the SPID label? 6xx, 7xx, 8xx and 9xx. 5 different front springs for wagons: TN, TS, TM, TL, and TY. Same rate as sedan springs, 77 N/MM. These 5 are also listed for non SEO sedans. 3 different rear springs for wagons: RR, RP, and RN. None of these seem to be listed for sedans. The wagon spring rates are higher, 37 N/MM. | |
| Subject: Re: 1A2 springs Wed Aug 08, 2012 8:53 am | |
| Going to put the rims and tires on this week, was going to do springs also if the 9c1 ones fit. I'll see what the SPID says. | |
| Subject: Re: 1A2 springs Mon Aug 13, 2012 9:20 am | |
| I have the CC623s in the back. Unfortunately, they're in the box in the back. I'll give a full report once I pick up isolators and get them installed. | |
| Subject: Re: 1A2 springs Mon Aug 13, 2012 9:56 am | |
| - boojum wrote:
- What are the spring codes on the SPID label?
God damn, look how high that wagon sits. Someone should tell the owner to drop the nose. Oh, and get rid of the ugly ass silver tape. | |
| Subject: Re: 1A2 springs Mon Aug 13, 2012 2:49 pm | |
| It needs aluminum wheels for sure | |
| Subject: Re: 1A2 springs Wed Aug 15, 2012 12:13 am | |
| - mp775 wrote:
- I have the CC623s in the back. Unfortunately, they're in the box in the back. I'll give a full report once I pick up isolators and get them installed.
Mike...were those the cargo springs you posted an ebay link to before? - Cadet57 wrote:
- .... Someone should tell the owner to drop the nose. ....
Dont bother...he doesnt listen. | |
| Subject: Re: 1A2 springs Wed Aug 15, 2012 7:38 am | |
- Mike...were those the cargo springs you posted an ebay link to before?
Those are the ones. $38.44 a pair, shipped. | |
| Subject: Re: 1A2 springs Wed Aug 15, 2012 1:55 pm | |
| Glen, I've got a pair of those ^^^ You need them? | |
| Subject: Re: 1A2 springs Wed Aug 15, 2012 4:16 pm | |
- Glen,
I've got a pair of those ^^^ You need them? I will let you know sir, i might have found a complete set. | |
| Subject: Re: 1A2 springs Wed Aug 15, 2012 4:22 pm | |
| OK If you dont, Bill M may need them. LMK whenever you get it figured out | |
| Subject: Re: 1A2 springs | |
| 1A2 springs | |
