| Moog cargo springs, $38.44 | |
| Subject: Moog cargo springs, $38.44 Mon Jun 25, 2012 9:59 am | |
| On e-Bay - Moog CC623 wagon cargo springs, $38.44 a pair shipped. And yes, it is is a pair, even though the listing says "Qty in Package: 1." | |
IMPALADAKID Admin
| Subject: Re: Moog cargo springs, $38.44 Mon Aug 13, 2012 8:49 pm | |
| Mike Did you buy these? How are they? My stock springs barely hold the car up. Add a cup of coffee, and it drops like a rock. | |
| Subject: Re: Moog cargo springs, $38.44 Mon Aug 13, 2012 9:05 pm | |
- Add a cup of coffee, and it drops like a rock.
So when you put that boat motor in you must have scraped the frame clean. I have these in my wagon. It "raised" it from 19 with the original stockers to 22" in the rear. That was when I had 225/70's on it too. | |
IMPALADAKID Admin
| Subject: Re: Moog cargo springs, $38.44 Mon Aug 13, 2012 9:21 pm | |
I have these in my wagon. It "raised" it from 19 with the original stockers to 22" in the rear. That was when I had 225/70's on it too. You have no idea how bad it was. My sig pic is wrong, because with the newer engine, the wheels are too forward on the trailer causing it to teeter totter. In that pic, there is less than 10 lbs of tongue weight. I just adjusted that to bring 10% of the total weight to the tongue. About 120 lbs. So they jacked your wagon up 3 inches? What the hell would they do on a sedan? | |
| Subject: Re: Moog cargo springs, $38.44 Mon Aug 13, 2012 9:29 pm | |
So they jacked your wagon up 3 inches? What the hell would they do on a sedan? Actually... I'm a bit off on my #'s Height before: Height after: | |
YachtDriver
| Subject: Re: Moog cargo springs, $38.44 Mon Aug 13, 2012 11:02 pm | |
| I have a set of these in the lowmile project. Gives it the stock height without the air shocks or air bags. | |
| Subject: Re: Moog cargo springs, $38.44 Mon Aug 13, 2012 11:50 pm | |
- Mike
Did you buy these? How are they? My stock springs barely hold the car up. Add a cup of coffee, and it drops like a rock. I had no idea the l99 car has stock springs installed... | |
| Subject: Re: Moog cargo springs, $38.44 Tue Aug 14, 2012 12:01 am | |
| How do you guys running these like the ride? I have the TRW variable rate cargo coils in my Impala, I had them in the last one too. The rear departure angle is so long that the tailpipes would scrape everything. For some reason on this yellow one the ride seems stiff and bouncy, but I feel like something else might be causing it, the springs currently in my car were IN the last Impala I had, and swapped them in place of an identical set just to see if the ride changed. | |
IMPALADAKID Admin
| Subject: Re: Moog cargo springs, $38.44 Tue Aug 14, 2012 5:18 am | |
| I wounder how stock tow package wagon springs would work? | |
| Subject: Re: Moog cargo springs, $38.44 Tue Aug 14, 2012 6:21 am | |
- Mike
Did you buy these? How are they? So far, mine are giving me a lower ride. But that's because they're still in the box and weighing down the old springs | |
| Subject: Re: Moog cargo springs, $38.44 Tue Aug 14, 2012 2:51 pm | |
| Mike, get those springs in already lol. Its like, the easiest job. Easier than fronts atleast. | |
| Subject: Re: Moog cargo springs, $38.44 Tue Aug 14, 2012 3:46 pm | |
- I wounder how stock tow package wagon springs would work?
I think these *are* the tow pack springs. When I bought mine these were listed as the optional "variable rate" spring and then the stock ones were a separate part number. | |
| Subject: Re: Moog cargo springs, $38.44 Tue Aug 14, 2012 5:01 pm | |
| - MASShole9C1 wrote:
- Mike, get those springs in already lol. Its like, the easiest job. Easier than fronts atleast.
That would require him to stop driving and stalking B-Bodys | |
| Subject: Re: Moog cargo springs, $38.44 Tue Aug 14, 2012 5:12 pm | |
That would require him to stop driving and stalking B-Bodys How true this is | |
| Subject: Re: Moog cargo springs, $38.44 Wed Aug 15, 2012 8:23 am | |
- That would require him to stop
driving and stalking B-Bodys commuting Fixt | |
| Subject: Re: Moog cargo springs, $38.44 | |
