| | sKIPPING sOUND! | |
| Subject: sKIPPING sOUND! Sun May 03, 2009 8:59 pm | |
| i had the skipping sound for awhile now but since i put the summit turbo muffs on the skip is louder. its only coming out the right side of the exhuast pipe.. what the hell could be the problem? | |
| | | Guest Guest
| Subject: Re: sKIPPING sOUND! Sun May 03, 2009 9:19 pm | |
| - BoSStonsSS wrote:
- i had the skipping sound for awhile now but since i put the summit turbo muffs on the skip is louder. its only coming out the right side of the exhuast pipe..
what the hell could be the problem? That would be the hesitation you have. So now we know it is in the right bank of cylinders. You need to look for a bad plug, plug wire or injector on that side, or even wiring on that side. I know you had a tuneup, but it still could be a loose plug wire or a cracked spark plug. In the past I have swiched one bank of injectors with the other and discovered the problem moved to the other side. This told me the problem was infact a bad injector. |
| Subject: Re: sKIPPING sOUND! Sun May 03, 2009 9:22 pm | |
| I still say it's a bad plug wire...
Check to see if any are contacting the exhaust manifold. I bet one is. Maybe number 6? | |
| | | BoSStonsSS
| Subject: Re: sKIPPING sOUND! Sun May 03, 2009 9:33 pm | |
| Ill Check in the AM
thanx
so if the plugs check out .. check the injectors by switching the sides | |
| | | Guest Guest
| Subject: Re: sKIPPING sOUND! Sun May 03, 2009 10:00 pm | |
| - BoSStonsSS wrote:
- Ill Check in the AM
thanx
so if the plugs check out .. check the injectors by switching the sides You might want to wait til saturday for that. I will bring the Vasaline. |
| | | | BoSStonsSS
| | | | Guest Guest
| | | | bammax
| Subject: Re: sKIPPING sOUND! Mon May 04, 2009 10:14 pm | |
| You sure it's not that god awful speaker dragging under the car? It was only held in by half a broken door panel after all Quick test, does the noise you hear synch up to the music your listening to? | |
| Subject: Re: sKIPPING sOUND! | |
| | | | sKIPPING sOUND! | |
