SS spoiler mounting help...please EmptyWed Oct 19, 2022 1:27 pm by scot
SS spoiler mounting help...please EmptyTue Oct 18, 2022 8:58 pm by silverfox103
SS spoiler mounting help...please EmptyTue Sep 28, 2021 11:01 pm by silverfox103
SS spoiler mounting help...please EmptyFri Sep 24, 2021 9:53 am by ElKy
SS spoiler mounting help...please EmptySun Sep 19, 2021 6:22 pm by black blur 96
SS spoiler mounting help...please EmptySun Jun 20, 2021 11:37 am by scot
SS spoiler mounting help...please EmptyFri Jun 11, 2021 10:41 am by scot
SS spoiler mounting help...please EmptyWed Jun 09, 2021 9:41 pm by Chris Klein
SS spoiler mounting help...please EmptyWed Jun 02, 2021 9:02 pm by Chris Klein
3 posters
PostSubject: SS spoiler mounting help...please   SS spoiler mounting help...please EmptyFri Feb 17, 2012 4:05 pm
So I have an SS spoiler for the Caprice. Have any of you guys put one on a car that did not have one before. Any tips or tricks or measurements for me to make it not so nerve wracking scratch
PostSubject: Re: SS spoiler mounting help...please   SS spoiler mounting help...please EmptyFri Feb 17, 2012 4:09 pm
Maybe someone can take one off of their car and mark up a quick paper template for you.
PostSubject: Re: SS spoiler mounting help...please   SS spoiler mounting help...please EmptyFri Feb 17, 2012 4:14 pm
If it is just 3m stick on type, just pull back the tape backing to create a little pulling flap. No more. Then once the trunk lid is clean and dry, place the spoiler where you want it. The bottom edge should almost hit the body line. Once everything is centered and lined up, pull the tape backing starting with the bottom one while applying a small amount of pressure. Once all the backing is off just go around pressing firmly. Now let it sit in the sun for a few hours.
If it is a true SS spoiler with the two studs, I think you can find the template on the national forum, or google it. If that is the case, you do the same exact thing as I described above, plus drilling two holes, and painting the edges of the holes before installing the spoiler.
PostSubject: Re: SS spoiler mounting help...please   SS spoiler mounting help...please EmptyFri Feb 17, 2012 4:20 pm
I'm guessing it's drilling the stud holes thats making him nervous.
REMOVING these are a BITCH!
I have pulled it off Matts car but played with the holes for a Langless lookalike so I cant give you totally accurate dimensions.
If you want me to look & get it REALLY close....let me know, I'll do it monday.
I think I JB Welded the original holes so I should be able to get you close.
Just dont use the tape until your happy
You could also check the manual to see if dim's are in there.
PostSubject: Re: SS spoiler mounting help...please   SS spoiler mounting help...please EmptyFri Feb 17, 2012 4:27 pm
Bring it over to my house Rob. I will mark the locations. Wink
PostSubject: Re: SS spoiler mounting help...please   SS spoiler mounting help...please EmptyFri Feb 17, 2012 4:28 pm
We have a winner....do it
PostSubject: Re: SS spoiler mounting help...please   SS spoiler mounting help...please EmptyFri Feb 17, 2012 6:12 pm
I will take you up on that Bill. Just wanted to see if someone had an SS trunk lid that was trash for the measurements. I will give you a call when I'm ready.
PostSubject: Re: SS spoiler mounting help...please   SS spoiler mounting help...please EmptyFri Feb 17, 2012 6:27 pm
SS spoiler mounting help...please Spolier
Found this on the national forum, although the info was sketchy as to if it's right. scratch
PostSubject: Re: SS spoiler mounting help...please   SS spoiler mounting help...please EmptyFri Feb 17, 2012 10:16 pm
Well, you can check the distance between studs & then do the math to see if that centers it on the lid.
If THAT works you should be able to trust the up dimension.
PostSubject: Re: SS spoiler mounting help...please   SS spoiler mounting help...please EmptyFri Feb 17, 2012 10:19 pm
Exactly what I was thinkin elephant
PostSubject: Re: SS spoiler mounting help...please   SS spoiler mounting help...please EmptyMon Feb 20, 2012 8:58 am
Took some measurements on the spoilr and compared them to the diagram. It all seems to match up, so I think I can trust the rest. I will probably recheck it about 20 times before I actually drill the holes though. What a Face
PostSubject: Re: SS spoiler mounting help...please   SS spoiler mounting help...please EmptyMon Feb 20, 2012 10:40 am
I know what you mean but you can adjust the holes if its a hair off.
You have miles of room under there (read as fudge factor) , so dont be so worried.
» WTB - Jack, Handle and necessary mounting stuff
» rear sway bar mounting pieces desperately needed!!!
» FS: Langness Spoiler
» Impala spoiler
» LEDs in Spoiler
