| fuel disconnect | |
| Subject: fuel disconnect Mon Jan 23, 2012 1:10 pm | |
| ok I need to know if this is the correct tool to remove the quick connect fuel lines were the rails are?
http://www.autozone.com/autozone/accessories/OEM-Fuel-line-disconnect-tool-for-GM-Ford-and-Chrysler/_/N-26c9?itemIdentifier=246367_0_0_ | |
| Subject: Re: fuel disconnect Mon Jan 23, 2012 2:04 pm | |
| That's the tool for it alright, although I think I had a scissor one like that and it was junk, I have the small one with the rubber band now and it's never let me down. | |
| Subject: Re: fuel disconnect Mon Jan 23, 2012 2:41 pm | |
| - Ironfistdog wrote:
- That's the tool for it alright, although I think I had a scissor one like that and it was junk, I have the small one with the rubber band now and it's never let me down.
UGH! Do NOT buy the scissor one! It will bend and snap as soon as you try and use it! Quick disconnect my foot! I tried doing a fuel filter in the cougar two years ago with that and I ended up late for work and the filter is still in the shed. Long story short, don't waste your money! | |
| Subject: Re: fuel disconnect Mon Jan 23, 2012 2:48 pm | |
| so maybe these? I think besideds the sissor one these are the only other ones there. http://www.autozone.com/autozone/accessories/OEM-5-16-3-8-1-2-5-8-3-4-and-7-8-in-A-C-and-fuel-line-disconnect-tool-set/_/N-26c9?itemIdentifier=2356_0_0_ | |
| Subject: Re: fuel disconnect Mon Jan 23, 2012 2:51 pm | |
| I use this one: | |
| Subject: Re: fuel disconnect Mon Jan 23, 2012 2:53 pm | |
| what size are the lines? are they 5/16 or 3/8? if i only neeed one size id be happy. | |
| Subject: Re: fuel disconnect Mon Jan 23, 2012 2:54 pm | |
| I believe it's a 3/8.... I'm almost positive! Don't have the tool in front me, | |
| Subject: Re: fuel disconnect Mon Jan 23, 2012 2:55 pm | |
| thanks man guess ill just go down to auto zone and advanced and check in person if they have it. | |
| Subject: Re: fuel disconnect Mon Jan 23, 2012 2:59 pm | |
| I got mine at advance almost 4 years ago still using the same one. On ls1/lt1.com it says you need 5/16 AND 3/8 two different lines, but that's BS cuz I hbe one tool and it works on both lines. Maybe buy the 5/16 and just keep it opened a little to do the 3/8 line, the whole set is like $10 I think. | |
| Subject: Re: fuel disconnect Mon Jan 23, 2012 4:40 pm | |
| thanks for the input. maybe tommorow ill run down and check a set out. | |
| Subject: Re: fuel disconnect Mon Jan 23, 2012 5:49 pm | |
| Just go to auto zone and rent a fuel line disconnect kit. You pay $15 then when you return it get your $15 back. It comes with both sizes needed. | |
| Subject: Re: fuel disconnect Mon Jan 23, 2012 6:37 pm | |
| - mega wrote:
- ok I need to know if this is the correct tool to remove the quick connect fuel lines were the rails are?
http://www.autozone.com/autozone/accessories/OEM-Fuel-line-disconnect-tool-for-GM-Ford-and-Chrysler/_/N-26c9?itemIdentifier=246367_0_0_ That's the one I've had the best luck with. Have broken all the other ones. | |
| Subject: Re: fuel disconnect | |
| fuel disconnect | |
