Remind me about senders EmptyWed Oct 19, 2022 1:27 pm by scot
Remind me about senders EmptyTue Oct 18, 2022 8:58 pm by silverfox103
Remind me about senders EmptyTue Sep 28, 2021 11:01 pm by silverfox103
Remind me about senders EmptyFri Sep 24, 2021 9:53 am by ElKy
Remind me about senders EmptySun Sep 19, 2021 6:22 pm by black blur 96
Remind me about senders EmptySun Jun 20, 2021 11:37 am by scot
Remind me about senders EmptyFri Jun 11, 2021 10:41 am by scot
Remind me about senders EmptyWed Jun 09, 2021 9:41 pm by Chris Klein
Remind me about senders EmptyWed Jun 02, 2021 9:02 pm by Chris Klein
3 posters
PostSubject: Remind me about senders   Remind me about senders EmptyWed Nov 30, 2011 12:35 pm
RMW sender unit.
Are the TBI & LT1's different?
PostSubject: Re: Remind me about senders   Remind me about senders EmptyWed Nov 30, 2011 4:11 pm
Think I answered my own question with a little looking around.
Senders for the 305 & 350 wagons are the same.
Fuel pumps are different. LT1=more pressure req'd.
I'd be foolish not to do the pump seeing as I'm in there.
Fortunately I found a sender & pump complete next town over.
PostSubject: Re: Remind me about senders   Remind me about senders EmptyWed Nov 30, 2011 4:13 pm
That is correct. Senders are the same on all wagons. Only difference is the LT1 pump is a higher volume.
PostSubject: Re: Remind me about senders   Remind me about senders EmptyWed Nov 30, 2011 4:14 pm
Thank you
PostSubject: Re: Remind me about senders   Remind me about senders EmptyWed Nov 30, 2011 4:17 pm
They are different. There are 3 different ones 91/92, 92/93 and 94-96
PostSubject: Re: Remind me about senders   Remind me about senders EmptyWed Nov 30, 2011 4:19 pm
Maybe for sedans. That or the part numbers changed. Because I know one sender is OCC only for whatever reason. But I know the wagons use the same sender across the board as when I did mine a couple LT1 guys bought them since Advance carried them.
PostSubject: Re: Remind me about senders   Remind me about senders EmptyWed Nov 30, 2011 4:27 pm
There is 3 different harness codes. BAK, BAP and BAH
I know because when I did the one in the 92 I couldn't order it till I got the code.
91 is one code
92 can be either 91 OR 93 code (mid year switch)
93 is one code
And 94-96 is all the same code ( believe BAK)
PostSubject: Re: Remind me about senders   Remind me about senders EmptyWed Nov 30, 2011 4:34 pm
91 is one code
93 is one code
Correct. But for whatever reason they all interchange. Or at least the aftermarket Spectra one does. However, the confusing part is in like RA's catalog for instance, they have units for OCC's only, LT1 cars only, and a bunch of other combinations. That said, the TBI unit WILL fit in an LT1 someone on Longroof just put one in his '94 Roadmaster.
They are probably all the same damn thing, but I know the BAP/BAH are usually grouped together and the bak is by itself, the sedan has codes BEX and BAJ I think. It probably just has to do with fuel pumps included or something no idea. Rather be safe than sorry is all.
PostSubject: Re: Remind me about senders   Remind me about senders EmptyWed Nov 30, 2011 4:37 pm
Oh no I agree. And I do think at this point they should clarify what parts really fit what cars.... I do know the difference between the sedan units and the wagon one is the harness length.
Speaking of sending units, I get to drop my tank AGAIN this weekend. I shit another Bosch pump. Finally smartened up and bought a Delco. Laughing Laughing
PostSubject: Re: Remind me about senders   Remind me about senders EmptyWed Nov 30, 2011 4:43 pm
Yes, that is correct.
93 back rely on harness codes (I didnt care, but I saw it)
94-96 didnt use them
Justin, Your wagon is now custom...Spectre P/N FG127A applies to 93, FG127B 94+ Hows it working for you?
PostSubject: Re: Remind me about senders   Remind me about senders EmptyWed Nov 30, 2011 4:53 pm
Just fine. One piece of advice, be careful putting the new sender in, the fuel level arm can snap out of place kinda easy but goes back on without issue if it does. Works fine thou. Well, minus the shitty ass Mexican fuel pump. Rolling Eyes
PostSubject: Re: Remind me about senders   Remind me about senders EmptyWed Nov 30, 2011 4:56 pm
Wish I knew that Justin, I sent the stock fuel pump from the 53k DGGM car to TX last week.
PostSubject: Re: Remind me about senders   Remind me about senders EmptyWed Nov 30, 2011 4:57 pm
Just don't buy a Bosch one and you'll be good. Laughing
» Gas tanks, senders, and gauges oh my!!
» Remind me how to install u-joints/driveshaft
BADASS of New England :: 91-96 B & D-body tech :: Wagon section-
