| Getting out of the B-body game. All parts must go! | |
+5jvette65 phantom 309 MASShole9C1 Grumpy toomanytoyz 9 posters |
| Subject: Getting out of the B-body game. All parts must go! Tue Sep 20, 2011 11:34 am | |
| The "Big Motor": Stock refreshed bottom end HV Melling big block oil pump Ported aluminum heads - don't remebrr the flow #'s but was better than AI. Comp 305 cam Crane 1.6 roller rockers SVO red top injectors Complete oil pan to injectors. About 20k miles. AWESOME engine. Put down almost 350 to the wheels on my impala. $2200 or bo
Built impala disc rear end. Tru-trak posi, 3.42s, Moser axles, new bearings and seals, aluminum cover with preload for bearing caps. 1 ton yoke for 1350 ujoints. Very stout. Disc to disc. $1200 or bo
4L80E from 2003 van. $400
Rebuild kit for above tranny. Many upgrades. $150
Edge 2800-3200 stall converter for 80 with small flywheel bolt pattern. Brand new. $600
UMI Performance upper and lower rear control arms. Standard length. Brand new. $200
Panther (marauder) Addco rear sway bar and all to mount. $150
15x8 wheel vintiques ralley wheels. 4"bs. Chrome. With caps. Firestone Firehawk Indy 500's. 295/50's and 255/60's. $400
Forged rods and dished pistons for lt1. Stock bore. Stock length rods. $500
SVO green top injectors. Used for dyno tune and swapped out. $250
C5 vette 13" front brake kit. Just trim your spindles and bolt it on. New rotors, hubs. Used calipers. Adapter bracket. $400
F2B kit with aluminum flywheel inspection cover. Brand new. $300
Charcoal cloth bonnies. Front and rear. From my impala. $100
Ruby red non-limited cloth roadie front seats. $50
Monte carlo steering wheel with radio controls and airbag coil. $50
Z28 cluster. No lense. $50
275/60 BFG drag radials on steel wheels. $100
Many misc parts, alternators, intakes, power steering pumps, starters, etc. Come by and make offers.
I'm sure theres a lot more. If you remember something I have and didn't list it, gimme a shout.
Thanks for looking.
-B
Six oh three four eight nine nine seven eight four | |
Grumpy
| Subject: Re: Getting out of the B-body game. All parts must go! Tue Sep 20, 2011 12:26 pm | |
| front seats .. Ruby RED.. leeme see when I can get up there.. | |
| Subject: Re: Getting out of the B-body game. All parts must go! Tue Sep 20, 2011 12:41 pm | |
| - Grumpy wrote:
- front seats .. Ruby RED.. leeme see when I can get up there..
Driver's seat is cut to a 40%. Will need a center console. Bonnies wre that way too. I will add more as i think of it in new replies... ALL PRICES ARE OBO. Buyer to pay actual shipping and paypal if applies. Cheap ebay orange 1.6 rr's. SA IIRC. $150 S10 non shift center consoles. $30 Fbody console. 6 speed. $30 Ruby red steering wheel, roadmaster, with rivier center section with radio controls. No air bag coil. $40 S10 long overhead grey console with pigtail. $40 | |
| Subject: Re: Getting out of the B-body game. All parts must go! Tue Sep 20, 2011 8:23 pm | |
| What color is the Monte steering wheel? 100% functional? And is there a write up for the mod? | |
| Subject: Re: Getting out of the B-body game. All parts must go! Tue Sep 20, 2011 8:54 pm | |
| - MASShole9C1 wrote:
- What color is the Monte steering wheel? 100% functional? And is there a write up for the mod?
Black. Has a couple scratches. I'd SEM it before i used it. And yeah, plenty of write-ups. Check with Steve in Maine. He's done them before. I actually got it from him for my ss. | |
| Subject: Re: Getting out of the B-body game. All parts must go! Tue Sep 20, 2011 10:04 pm | |
| Subject: Re: Getting out of the B-body game. All parts must go! Tue Sep 20, 2011 10:48 pm | |
| Dibs on the Monte steering wheel so far... | |
jvette65
| Subject: Re: Getting out of the B-body game. All parts must go! Wed Sep 21, 2011 9:19 am | |
| Subject: Re: Getting out of the B-body game. All parts must go! Wed Sep 21, 2011 10:56 am | |
| Decided this after the SS newsletter? OK be like that. | |
| Subject: Re: Getting out of the B-body game. All parts must go! Wed Sep 21, 2011 12:37 pm | |
| Subject: Re: Getting out of the B-body game. All parts must go! Wed Sep 21, 2011 1:13 pm | |
| all done with b-bodys? hope ull still be around? and as for that motor is it a 94-5 motor or 96? | |
| Subject: Re: Getting out of the B-body game. All parts must go! Wed Sep 21, 2011 7:58 pm | |
| ROFLMAO!!!! You are a photoshop king, my friend! And Mike, it is a 95 motor. | |
| Subject: Re: Getting out of the B-body game. All parts must go! Thu Sep 22, 2011 7:06 pm | |
| Did you give up on the F body search Bill? Do they make a conversion kit for the 4L80 to mate up with the LTI? | |
| Subject: Re: Getting out of the B-body game. All parts must go! Thu Sep 22, 2011 7:16 pm | |
| Not so much a conversion kit as just gathering the correct parts. I have everything needed to put one in a B-body. The tranny, the kickass converter with the lt1 flywheel bolt pattern, the Bowtie Overdrives crossmember, and even the larger yoke for the 1350 u joint for the rear end. You just need to install it, measure for the driveshaft and have one made. How is it controlled? Swap two pins on the tranny connector and our pcm controls it. | |
FREE7466
Posts : 8 Join date : 2011-08-08 Age : 44 Location : VIRGINA
| Subject: Re: Getting out of the B-body game. All parts must go! Tue Nov 08, 2011 1:58 pm | |
- The "Big Motor":
Thanks for looking.
-B
Six oh three four eight nine nine seven eight four HEY LET ME KNOW IF YOU HAVE A DASH BEZEL FOR A 93 BUBBLE CAPRICE LTZ MODEL | |
| Subject: Re: Getting out of the B-body game. All parts must go! | |
