| Backfireing under the hood on startup | |
| Subject: Backfireing under the hood on startup Thu Oct 13, 2011 6:42 pm | |
| Last couple days whenever I start the Caprice it pops from under the hood when I give it any gas for the first 30 seconds it is running. After that she is fine, normal. Any input????? | |
| Subject: Re: Backfireing under the hood on startup Thu Oct 13, 2011 7:05 pm | |
| - cloud 9 wrote:
- Last couple days whenever I start the Caprice it pops from under the hood when I give it any gas for the first 30 seconds it is running. After that she is fine, normal. Any input?????
LT1 car? if so..... sounds like an opti..... | |
| Subject: Re: Backfireing under the hood on startup Thu Oct 13, 2011 7:47 pm | |
| Check your air intake elbow for holes, also check the MAF and IAC. Any Sticking valves? | |
| Subject: Re: Backfireing under the hood on startup Thu Oct 13, 2011 8:05 pm | |
| Subject: Re: Backfireing under the hood on startup Sun Oct 16, 2011 2:16 pm | |
| Subject: Re: Backfireing under the hood on startup Sun Oct 16, 2011 3:35 pm | |
| - bowtiepimp wrote:
- IMPALADAKID wrote:
- OPTI!!!!!!!!!!!!!
Sounds like possibly a "lean-pop" backfire. Check for anything that delivers the necessary rich fuel mixture required when cold. The computer needs to know various temps though-out the engine systems. O2, coolant temps, A/F ratio, Etc. The FSM (factory service manual) has excellent procedures for tracking down the cause. The normal hot engine fuel ratios will be too lean while flowing through the cold intake runners, condensing on the cool surfaces. | |
| Subject: Re: Backfireing under the hood on startup Sat Oct 22, 2011 10:06 am | |
| Put in a new coolant temp sensor. Everything ok now. Cheap fix, very happy. Thanks for the advise guys. | |
| Subject: Re: Backfireing under the hood on startup Sat Oct 22, 2011 10:50 am | |
| Subject: Re: Backfireing under the hood on startup | |
