Backfireing under the hood on startup EmptyWed Oct 19, 2022 1:27 pm by scot
Backfireing under the hood on startup EmptyTue Oct 18, 2022 8:58 pm by silverfox103
Backfireing under the hood on startup EmptyTue Sep 28, 2021 11:01 pm by silverfox103
Backfireing under the hood on startup EmptyFri Sep 24, 2021 9:53 am by ElKy
Backfireing under the hood on startup EmptySun Sep 19, 2021 6:22 pm by black blur 96
Backfireing under the hood on startup EmptySun Jun 20, 2021 11:37 am by scot
Backfireing under the hood on startup EmptyFri Jun 11, 2021 10:41 am by scot
Backfireing under the hood on startup EmptyWed Jun 09, 2021 9:41 pm by Chris Klein
Backfireing under the hood on startup EmptyWed Jun 02, 2021 9:02 pm by Chris Klein
5 posters
PostSubject: Backfireing under the hood on startup   Backfireing under the hood on startup EmptyThu Oct 13, 2011 6:42 pm
Last couple days whenever I start the Caprice it pops from under the hood when I give it any gas for the first 30 seconds it is running. After that she is fine, normal. Any input?????
PostSubject: Re: Backfireing under the hood on startup   Backfireing under the hood on startup EmptyThu Oct 13, 2011 7:05 pm
LT1 car? if so..... sounds like an opti.....
PostSubject: Re: Backfireing under the hood on startup   Backfireing under the hood on startup EmptyThu Oct 13, 2011 7:47 pm
Check your air intake elbow for holes, also check the MAF and IAC. Any Sticking valves?
PostSubject: Re: Backfireing under the hood on startup   Backfireing under the hood on startup EmptyThu Oct 13, 2011 8:05 pm
OPTI!!!!!!!!!!!!!
PostSubject: Re: Backfireing under the hood on startup   Backfireing under the hood on startup EmptySun Oct 16, 2011 2:16 pm
So just cause it was easy and inexpensive I replaced the fuel filter. Still doing it though. Weird, it only does it for the first 60 seconds after cold start then runs and starts easy after warmed up, responsive as normal. I have looked all around the engine compartment nothing disconnected or cracked. I believe it has the original opti in it. 80k miles and 17+ years old, sounds like that may be my next option. Any other ideas before I get into it would be appreciated. scratch scratch scratch
PostSubject: Re: Backfireing under the hood on startup   Backfireing under the hood on startup EmptySun Oct 16, 2011 2:36 pm
OPTI!!!!!!!!!!!!!
Sleep
PostSubject: Re: Backfireing under the hood on startup   Backfireing under the hood on startup EmptySun Oct 16, 2011 3:35 pm
OPTI!!!!!!!!!!!!!
Sleep
Sounds like possibly a "lean-pop" backfire.
Check for anything that delivers the necessary rich fuel mixture required when cold.
The computer needs to know various temps though-out the engine systems.
O2, coolant temps, A/F ratio, Etc. The FSM (factory service manual) has excellent procedures for tracking down the cause.
The normal hot engine fuel ratios will be too lean while flowing through the cold intake runners, condensing on the cool surfaces.
PostSubject: Re: Backfireing under the hood on startup   Backfireing under the hood on startup EmptySat Oct 22, 2011 10:06 am
Put in a new coolant temp sensor. Everything ok now. Cheap fix, very happy. cheers Thanks for the advise guys.
PostSubject: Re: Backfireing under the hood on startup   Backfireing under the hood on startup EmptySat Oct 22, 2011 10:50 am
Nice!
» High idle at startup
» What do you think of this hood?
» Looking for Impala hood
» WTB: impala hood
» WTB LTZ Hood emblem
